Question about Epson ACULASER CX11NF All-In-One Printer
Epson cx11nf printing problem
Hello, all my printouts are faint down one edge. I have done a "Epson test print for colour laser printers" and it shows all colours including black are affected.
I can scan the printout and send it to someone if need be.
Regards
Jason
PS I have changed the pcu but it made little difference.
  • 3 more comments
  • Anonymous Jul 14, 2008
    Our printer does the same thing. We have rebooted the printer and tried to get it to calibrate. But, it seems to keep doing it.  Big problem.. very expensive boat anchor.
  • Anonymous Aug 25, 2008
    I have this same problem. I have done the head cleaner slide, and it still is effected.
    It will abruptley change color as in printing from red to yellows. Seems that yellow is controling the far right of my pages....
  • Anonymous Sep 03, 2008
    I just tried solution # 1...or at least I would like to. I found the tab where you said it is, but there is no handle! Solution # 2???
  • furniture32 Sep 03, 2008
    I had the same problem. I was a little confused about how to clean the print head, but it worked for me also. You won't see the handle at first when you open the little door on the side of the printer. You also have to open cover "A" and pull a little lever forward to reveal the head cleaner handle. I found the instructions at the following link: http://files.support.epson.com/pdf/cx11n...
  • Anonymous Dec 13, 2008
    This only works for about 5 or 6 pages and then it starts again... Help!!
Hi!
The problem occure when you replace the toner cartridge. It is very easy to damage the surface on the drum that are tightening against the cartridge. It happens when you make the last twist on the handle on the cartridge. After this damage the toner are leaking out on the print head. As I see it´s a bad construction from the start by Epson.
Posted on Jan 12, 2010
On the right hand side of the printer towards the back, but on the right hand portion of the printer there is a tab you can open it is about 3/4 inch wide and 2 inches long. After you pop the tab off, there is a handle. Pull the handle out SLOWLY all the way. This will wipe off the printing head like a windshield wiper. Insert the handle back in slowly, and whallah!!!
Fixed me real good!!!
Posted on Jul 25, 2008
When i print or photo copy anything it does not turn out properly therer are lines across and the colour is all over the place... how do i do a test on it thanks
Dear donovanwill,
Hello! Thank you for using FixYa.
If you have installed the full Epson software suite that came with this MFP, you should be able to follow the instructions below to run a cleaning and test.
1. Click on your Start button.
2. For Windows XP: Go to Printers and Faxes For Windows 7: Go to Devices and Printers.
3. Locate the printer and right-click on the icon. For Windows XP: Choose the option for "Properties". For Windows 7: Choose the option for "Printer Properties".
4. You should see a "Utilities" File tab at the top of the Properties window.
5. Now select the "Nozzle Check" option. At this point, click "Print" and the printer will print a test page for you to determine whether cleaning is necessary. 6. If you notice any gaps or other irregularities in the printout, click "Clean" and the printer will perform a cleaning cycle. If the printout is satisfactory, click "Finish" and you will be done. Have a great day!
Sep 01, 2011 | Epson Stylus Multifunction Inkjet Printer/...
After changing the ink catridges and resetting the drum fuse lately (note: it is known that the fuse will be blown off after certain number of prints but otherwise is in good condition), my Epson Acculaser...
The repeating image is a ghost image, and here is described what it can be. Probably if you solve this, you also solve the red-dot problem. If possible, I would suggest to replace the wiper blade.
Repeating images on laser printerThis likely means a faint ghost of the main printout at a distance equal to the circumference of one of the rollers or photosensitive drum.
Depending on where the problem originates, this could be a bad wiper (cleaning) blade, faulty corona, or incomplete fusing.
  • If the distance between successive images is equal to the circumference of the photosensitive drum, it is a wiper blade, erase lamp, or corona problem.A residual latent image or residual toner is sticking to the drum and not being properly cleared.
  • If the distance between successive images is equal to the circumference of one of the fuser rollers, then the fusing may not be complete due to damaged rollers or an incorrect temperature setting.
It is easy to determine where the problem is located: Interrupt a printout in mid-stride (where part of the paper is between the toner/developer and fuser. If the un-fused image has ghosting, it is a fault in the area of the drum
Jul 08, 2011 | Office Equipment & Supplies
My Samsung CLX3160 prints very faintly (colour & b/w)
I have instructions on how to clean the developer blades. It should fix the faint printing that you are experiencing. It is posted in my Tips section.
Jan 08, 2010 | Samsung CLP 300 Laser Printer
My Epson Stylus Color 760 printer tells me there's still ink
If your ink was installed Feb. 2007, then most probably it got expired as you said you have done test prints but with faint samples.
It is advisable to install new and genuine epson ink cartridge.
Jul 24, 2009 | Office Equipment & Supplies
White scratches and a "breaking" mark on printout
Epson CX11NF printer problem-repair solved
To clear stripe....Open the front cover and look on the inside of the right side of the printer....There you will see a pictorial instruction showing the PRINTER HEAD cleaning procedures.
Follow them (remove tab/plug on right side, pull out on head lock arm on inside right, then fully pull out the printer head arm inside the port on the (outside of printer) right side.....Then push it back in, replace tab cover, push the lock back in (inside right-front) and problem solved.....
God Bless,
Happy Epson CX11NF User
Oct 14, 2008 | Epson ACULASER CX11NF All-In-One Printer
Light stripe down right side of colour print out
I had the same problem and managed to clear it by cleaning the print head. You can fiind instructions on how to do this in the pdf manual on the Epson web site at ftp://download.epson-europe.com/pub/download/314/epson31436eu.pdf - go to page 351 and it should get you through it OK.
Nigel
May 08, 2008 | Epson ACULASER CX11NF All-In-One Printer
Printing problems
According to the manual, "If there are white vertical lines on your printout, you will need to clean the print head."
I had that problem and cleaning the print head solved it.
Mar 07, 2008 | Epson ACULASER CX11NF All-In-One Printer
Printing faint
hi
I believe this is a timing problem, you have done alot yet the same problem recurs . Compare the toner drum assembly holder positioning with another similar printer to justify its timing. Remove this holder drum and inspect the metallic contact tracks behind it.
keep me posted on this
labatt
Jan 29, 2008 | Epson AcuLaser C900 Printer
Epson al cx11nf print problems: Lines on side of output
This could be caused by a dirty lens on the laser unit. Try cleaning the laser window. Open the front panel (where you change the toner) and the right you will see a blue lever/handle - pull it out towards you. Now on the right side panel of the printer you will notice a little plastic panel about 2"x0.75" - open that and you will see inside another handle. Pull this handle out and back in a few times. This draws a cleaner pad across the lens. If toner has fallen onto the lens it makes the are it has fallen onto create blank lines on the print. If this does not solve your issue then the next suspect would be the PCU. Just get another one (same as C1100 if you can borrow one) and try it.
Apr 28, 2007 | Epson ACULASER CX11NF All-In-One Printer
Colour lines across the page
Hey Paul, Can you post a scan of the printed paper? It may help diagnose your problem. The most common cause of lines accross the page is either the PhotoConductor Unit or the 2ND BTR Assy.
Nov 30, 2006 | Epson Aculaser C1100 Printer
Epson ACULASER CX11NF All-In-One Printer Logo
1,069 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
