My Philips 47 inch PFL9632 D/10 has a problem. The background of the picture which should be black sometimes starts showing red or green vertical lines. Plus the parts of the picture which should be black or dark colour are showing shades of red or green. The problem is intermittent sometimes the picture is perfect than all of a sudden it deteriorates as described above. What is my problem?
  • 3 more comments
  • toniocachia Dec 31, 2010
    Was hoping for more details.
  • toniocachia Jan 02, 2011
    If by no input screen you mean setting the tv on a channel which has no channel reception than yes, if the screen has the red lines whilst watching a TV channel and than you change the channel to for example EX2 which has no reception the red lines are still present.
  • toniocachia Jan 03, 2011
    Hi the problem was the cable that connects between the T Con Board and the Main Board.
    The connector going into the T Con board was loose I plugged it in well and now the TV is back to normal...
    Since I have never moved the TV from its place and its been at me for over a year. I suspect this was an error from the factory.
  • toniocachia Jan 04, 2011
    Very helpful pointed me immediately in the right direction, Saved me a lot of cash as I avoided paying the exorbitant dealer charges for collection inspection etc.
    Job done at home in 20 minutes.
  • 11,800 Answers
Image corruption caused by either an overheated/failing image processor or a bad connection between the mainboard and the T-con board. You will have to open the back of the tv and inspect and reseat the cable that connects the 2 boards. Then clean and inspect the status of the radiator located on the processor: if it's in a correct position, if it's firmly attached and if the air vents are clean.
If no improvement is observed then the defect is advanced beyond recovery, you will most likely be forced to replace the mainboard. This is a job that's better to leave it to a pro.
Posted on Dec 30, 2010
  • Azrael SRL Dec 31, 2010
    The image processor stores the data for the image pixels in an memory buffer part of its chip. The data for the pixels is stored in an bitmap format: each pixel is defined only by its color that is encoded in a standard hexa way., see here
    http://html-color-codes.com/
    The hex id for black is 000 which is composed only from 0 bits. If the processor overheats the memory cells that hold those 0 bit code will shift on their own to 1 , the end result being that what was supposed to be black now is another color. This shift happens in all the data for the pixels in the buffer, just that the result is clearly visible only in dark parts of the image.
    The same process happens if the data connection between the processor and the T-con board (the board that transforms the image data in actual commands for the pixels on the LCD panel) is faulty and the data flow is corrupted.
  • Azrael SRL Jan 03, 2011
    Since your problem has been solved would you accept my answer?
  • 4,889 Answers
When the problem appears check whether the weird colors exist on the no input screen or not and let me know. This will help us zero in on the exact location of the problem.
Posted on Dec 31, 2010
  • eagle338
    eagle338 Jan 02, 2011
    Perfect. Thats just what I needed to know. You have a malfunctioning T-con board. It is very easy to replace and inexpensive(costs about 50-75$). If you would like to fix it yourself, then remove the back cover of the tv and get me the partnumber of the board from which 2 ribbon connectors go into the LCD panel so that I can find you a replacement.
    Sai.
  • eagle338
    eagle338 Jan 03, 2011
    Glad to hear that! I knew it was a problem with the t-con, just missed out on the loose connector thing.
    Please do accept the solution since my advice did point you in the right direction.
    Sai.
Model 42LG70. Why is nothing on screen except for horizontal green and pink pixel line?
Black square on the screen Vizio Gallevia 47" 1080p - Fixya
www.fixya.com/support/t355299-black_square_screen_vizio_gallevia_47
Jan 16, 2008 - Black square sized app. 10"x10" pops up on the bottom right corner of the screen and won't go away. .... Model 42LG70. Why is nothing on screen except for horizontal green and pink pixel line? I am looking at replacing the ...
bad screens display vertical lines with a white background ...
https://www.ifixit.com/.../bad+screens+display+vertical+lines+with+...
iFixitJun 17, 2014 - I am now replacing a screen on a different G2 and I am on the secondscreen. ... A touchscreen smartphone made by LG Released: 09/2013 Model: VS980..... on the rigth side, from the top to the botton has 6/7 black lines.Missing: 42lg70 ‎pixel
Broken LG LCD TV Capacitor Black Screen My Wont Turn ...
? 6:27
https://www.youtube.com/watch?v=EbGiXqBAvvo
Aug 25, 2010 - Uploaded by FixItUrselfDummy
Broken LG LCD TV Capacitor Black Screen My Wont Turn On ...How I fixed my LG TV, Won't turn on or show picture Model: LG42LC7D ...Missing: horizontal ‎pink ‎pixel ‎line
Jan 05, 2016 | LG Televison & Video
I have a Bravia KDL 40BX421 that suddenly has green vertical lines on the bottom 1/4 of the screen. These lines are in a background bar that is mostly a reddish shade.
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/.../1127410-thin-vertical-lines-cover-screen-samsun...
Mar 7, 2009 - 30 posts - ‎25 authors
Hi guys, Ive had this TV for about a year now - all of a sudden thin vertical lines havecovered my screen (show in link below) No matter what ...Missing: 40bx421
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Apr 25, 2014 - Uploaded by ShopJimmy.com
TV Repair help with troubleshooting lines on your TV Screen. ... hi i have a sony bravia mdel # KDL46EX523. i have horizontal multi colored lines ... My TV has the following symptoms: - Horizontal lines from top to bottom of .... thick(like 1-1/12 inch) and a couple of green vertical lines next to the black one.Missing: kdl ‎40bx421
Flat Screen TV Has Lines Going Through Screen - Possible ...
Dec 16, 2015 | Televison & Video
There green tint in my picture on all my connections on vizio 47
Try shielded video cables and make sure you have your cables hooked up correctly. Sometimes you can conect them wrong, specially the red one. If you are using componet in on your tv, make sure the red one is not connected to your audio. The green tint is because you are missing red in your picture.
Mar 16, 2009 | Vizio VO47L 47 in. LCD TV
Picture not centered on my philips 47'' lcd tv
NOTE:(Edited and copied from another thread on Fixya.com, c7carl)
Picture is not centered on monitor leaving a 2 1/2 inch; black border on Philips LCD
By dmorrow54 on Nov 13, 2007
Again, nothing in manual for Philips LCD will correct the fact that the picture in HD-D mode will not center. The picture runs off the monitor on the left (facing the monitor) with a 2 1/2" black border on the right (facing the monitor). Using the format button on the remote of directional arrows will not correct the issue. The wide-screen/ full-screen function with format does nothing. Moving into TV mode, the format function works to display screen in several ways 4:3, 19:2, super-zoom, wide-screen, full-screen. Help, please. posted 3 years ago
Guest
  • Rank: Guide
  • Rating: 0%, 0 Votes
I have a Philips 30 inch LCD and solved the problem by using the circular arrow button on the TV remote. Pointing it at the TV and clicking "right" (3 o'clock on the button), the picture moved right. Same thing on for "left". Worked for me.
Add a comment
    • c7carl
    • 5 minutes ago
    WOW! It works!! The picture on my Magnavox (aka Philips) 37MF321D had shifted to the right. I figured I had a big repair bill coming up soon. But hey! Just used the TV remote as described by "Guest', and re-centered the picture to the left. Wallah! Thanks ""Guest" whomever you are! Reply
    Posting advertisements, profanity, or personal attacks is prohibited. Click here to review our Terms of Use.
    Comment:
Feb 05, 2009 | Philips 47PFL5603D 47 in. LCD HDTV
Too much green color
Problem solved. I tried playing DVD and the TV picture was fine. So I double-checked cable wires from cable box - one of the wires was loose (obviously it was the red color input). After tightening, the TV picture is good as new.
Mar 20, 2008 | Sony FWD-50PX1 50 in. HD-Ready Plasma...
Sony Trinitron K29 inch CRT TV screen shows green shade!
i have the same problem with my sony trinton tv 36 inch if you know how to fix this please email me on amir.dhawan@gmail.com
Dec 30, 2007 | LG Flatron 295LM 22" LCD Monitor
Picture shows only about a 2-3" blue,green,or red vertical line down the middle
If your seeing vertical line across the screen you need to check the components in the vertical stage as well as the vertical IC could be bad, or the yoke could open.
Also check if any voltage reaching the vertical stage.
Good luck.
Was this help full.
Oct 31, 2007 | Panasonic PT-47WX53 47" Rear Projection...
Vertical line up and down middle of TV screen
i think this is the called picture in jail. this might be due to 1 power supply reg.poor or filter cap dry. 2 loose or dry joint nera hor. output section or capacitor in eht section.
Sep 21, 2007 | Mitsubishi CS-35505 35" TV
Televison & Video Logo
Top Televison & Video Experts
