Question about Whirlpool Dryers
Whirlpool dryer the heating element will not shut off. I suspect a thermal fuse but took them in and they said they were okay. I am going to check and see if the element goes to ground on the case as they recommended. Any suggestions?
  • 413 Answers
There have been many cases in recent months where the heater coil is shorting to the case. In many cases, this issue will only appear when the heater gets hot. If the dryer is getting hot when not running, replace the heater even if it appears good when cooled down. You received good recommendation....
If you need further assistance, let me know
Regards,
reg501
Posted on Jul 08, 2008
My basement recently flooded. Now my electric dryer runs but doesn't heat up. I checked the thermal fuse, t-stat's. and heating element. All checked out okay. I also checked each side of the outlet. Had...
The centrifugal start switch on you motor may be corroded and not flipping over to the run windings and closing the circuit to the element. Does the dryer run for over 5 minutes without the motor thermally overloading?
Mar 24, 2011 | Whirlpool Dryers
Dryer wouldn't work last week. Found the Thermal Fuse with no continuity and replaced it. After drying one load of clothes yesterday, dryer won't work again. I suspect the thermal fuse again. What else ...
Or your breaker. The dryer will work just won't heat with the thermal cutoffs or element or the breaker. Dryer won't do anything if the thermal fuse is bad. You might also want to check the outlet from L1 to N and L2 to N for 110 on each side. Good luck.
Aug 22, 2010 | Whirlpool Dryers
My whirlpool dryer does not heat. I have checked the breaker.. what else can I do?
turn the power off,, remove the back of the dryer usually screws all around.... Check your heating element for breaks or damages,, check your thermostats there should be 3,, check your thermal fuse .
no heat on a electric whirlpool dryer is either an element, fuse, or thermosat. U can check all these with a metere for continuity. put one lead on each connection if it reads sometin it is okay if it reads nothin than it is defective and u should replace it....
if u like you can go to sears.com go to parts and service far right upper corner usually, go to parts,, then u should be in parts dirrect enter your model number usually on inside on sticker when open door this way u can get a parts breakdown and get part numbers and prices on potential parts hope this helps let me know how it goes bro good luck
Feb 02, 2010 | Whirlpool Dryers
Dryer wont start
Okay...your dryer is one of the more easier dryers to access the heating circuits. All you have to do is unplug the dryer and remove the back panel. The heating circuits will be on the right hand side (as viewed from the rear). The heating element is inserted inside the heater box with the thermal cut-out (TCO) mounted on the top portion of the heat box. The hi-limit thermostat will be located adjacent to the heating element ceramic terminals. You mentioned a thermal fuse also. It is a small white plastic (sometimes gray) looking component mounted on the blower fan housing on the lower left hand side of the dryer (as viewed from the rear).
If the dryer does not run at all, the THERMAL FUSE is a good diagnosis on your part.
If the dryer runs, but does not heat, the THERMAL CUT-OUT, heating element or hi-limit thermostat are your likely problems.
The following link provides you with some necessary guidelines on how to troubleshoot if needed:
http://www.fixya.com/support/r385301-thorough_dryer_advice
Most dryer problems are related to overheating caused by poor ventilation, or overloading. If you need a drawing of your dryer heat components you can reference searspartsdirect.com. Just type in the model number you provided (include the prefix "110", this identifies the manufacturer as Whirlpool). The number should be written as follows: 110.66801691. Look under the "Bulkhead" heading for an exploded view diagram of your dryer. The Thermal Fuse is listed as item 59 (part #3392519). I hope you find this information helpful. Let me know if you have any questions.
May 03, 2009 | Kenmore Dryers
Dryer all is working but not heating
Hi!
First of all please check the thermal fuse. If it is out okay (by-passed or tested with an ohmmeter), then check the heating element. This can be checked by removing one of the wires on the heater and testing it with an ohmmeter. Or,removing the element and visually inspecting it.
Thanks
Rylee
Mar 18, 2009 | Whirlpool Dryers
Dryer runs but will not heat. Replaced fuse and
your cycling thermostat needs changed too. the thermal fuse is your last safety measure that goes, which means your cycling thermostat is not shutting down the heat element once it detects the right temp hot air in the blower housing so it let the heat element glow until either the high-limit sensor shuts the heat down or the thermal fuse blows. Change the cycling thermostat and good luck
Mar 06, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool Duet Dryer - Working but no heat
it sounds like your heating element is gone bad. there is no heat if they burn out or get corroded
Jun 28, 2008 | Whirlpool GEW9250 Electric Dryer
My dryer is not heating up ... only blowing cool air.. i have a whirlpool gold.. i've checked the circuit breaker - dryer vents - what else can i do .. or do i need to call ...
ckd element and thermal fuse on top of element most likely suspect is element especially if you have a poor vent system
Apr 26, 2008 | Dryers
Whirlpool dryer
First make sure you have power to the unit through the plug. If power is present, then you most likely have an open Thermal Safety Fuse. The Thermal is a Safety feature that shuts off the power to the Heat Element in the event the Blower is not blowing or the Lint Vent becomes clogged not allowing air to flow over the Heat Element. NO air flow, Heat Element over heats, Thermal Safety Fuse opens, power shuts off. If the Thermal Safety Fuse is open find out why. Was the blower not working? Was the Lint Filter clogged? ( Lint Filter should be cleaned after each use to assure continued air flow.) Was Lint Vent Clogged? This is the Vent Hose that goes from the Dryer to the outside of your house. It should be checked for free air movement. The next thing-- Could be a defective Timer or Control Module.
Find where you lost power and WHY!!
Jan 27, 2008 | Dryers
Whirlpool Gold Ultimate Care II: No heat
didc, on a gas dryer, if the thermal fuse blows it will still rotate, but will not heat. Since this is a gas dryer, see if the ignitor is glowing. If it is, then you know the thermal fuse is good. If not, the thermal fuse may be blown or the ignitor itself and thus the reason for no heat. Catriver.7152136.jpg
Jan 01, 2008 | Whirlpool GGQ8831L Gas Dryer
Dryers Logo
54 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
