Whats the routine for fitting a new expansion tank? HELP At what pressure should the overpressure relief valve lift?
    Sergeant:
  • 182 Answers
Hello, not know the size of your system I can only give you the standard answer. Most expansion tanks are sized by the amount of water they will hold, however a rule of thumb has been a smaller 4 zone system will have a 7 gallon tank with 12 psi charge. Larger systems will sometime go has much as 30 gallons but, the charge is still 12psi. The relief valve should be a 30psi set but, again on larger systems it will be 50 psi. The 12psi is a standard auto fill valve max and you want to match the charge of the expansion tank to the auto fill valve setting. Hope this helps.
Posted on Dec 30, 2010
  • Tim Dehnke Dec 30, 2010
    I will add this about the relief valve, if it is leaking it will most likely be due to the expansion tank being full of water and not half air. most tanks have a rubber bladder in them and sometimes that leaks and fills with water and cause the heating system to leak while they are heating up.
  • 43,501 Answers
Just turn off the water relieve the pressure and then turn out the old tank and turn in the new one...make sure the water is not too hot that it will burn you...
The relief valve should lift at 30 psi....
heatman101
How to fix leaking pressure relief valve on hotbwater service
Depending on how old. Cycle the valve a couple of times by pulling the lever and letting it snap back. this might let it clear debris that is on the seat.
Nov 20, 2017 | Water Heaters
GE Smart Water Model # GE40M06AAG
Bad relief valve or too much pressure in the tank. Does water heater system have a pressure blotter tank that allows for expansion(an expansion tank)
May 05, 2017 | Water Heaters
Cant find the valve to let air pressure from my radiator for my water to flow right
FILL COOLANT SYSTEM UP BY POURING COOLANT IN THE EXPANSION TANK UNTIL COOLANT LEVEL STOP DROPPING IN THE EXPANSION.WHEN YOU POUR COOLANT IN EXPANSION TANK AIR BLEED OFF THROUGH THE SMALL COOLANT LINES GOING TO EXPANSION TANK.WITH PRESSURE CAP OFF RADIATOR COOLANT LEVEL IN EXPANSION IS AT FULL COLD MARK.WHAT YOU TO DO CRANK ENGINE UP LET IDLE WARM UP UNTIL COOLANT DROPS IN EXPANSION TANK KEEP ADDING COOLANT UNTIL STOP DROPPING STAY AT FULL COLD MARK.WHEN COOLANT LEVEL START RISING IN EXPANSION TANK.PUT PRESSURE CAP BACK ON RADIATOR.WHILE ENGINE IDLING WATCH TEMPERATURE GAUGE.IF START CLIMBING TURN OFF ENGINE LET IT SIT FOR LITTLE WHILE TAKE A LARGE RAG OPEN RADIATOR PRESSURE CAP A LITTLE AT A TIME TO KEEP FROM GETTING SCALDING TO RELEASE AIR IN COOLANT SYSTEM.WHEN PRESSURE IS RELEASED OPEN PRESSURE CAP ADD MORE COOLANT IN THE EXPANSION TANK.CRANK ENGINE AGAIN LET IDLE WHEN TEMPERATURE GAUGE START CLIMBING. TURN OFF ENGINE WAIT FOR WHILE BEFORE OPEN RADIATOR PRESSURE CAP.WHEN YOUR THERMOSTAT OPENS WHEN TOP RADIATOR HOSE IS HOT AND ENGINE COOLANT TEMPERATURE GAUGE STOP CLIMBING AND COOLANT LEVEL STOP DROPPING IN THE EXPANSION TANK.ALL AIR IS EXPELLED FROM COOLANT SYSTEM TO KEEP ENGINE FROM OVERHEATING.
Jun 10, 2011 | 2001 Cadillac DeVille
We have a brand new rheem 40 gal elec water heater, after installation we have water leaking from the base of the relief valve, pooling up in the plastic fitting and making it way over the side all over...
Water heater should be set in a drip pan.
Otherwise, put 1 gallon bucket under TP release pipe to catch water.
http://waterheatertimer.org/Water-at-bottom-of-water-heater.html#drip-pan
When you say relief valve, I assum you are talking about brass valve located on top of tank or near top of tank. This is TP valve and a pipe connects to this valve and runs down to within 6" of bottom of tank. TP valve has a small lever on it.
If you are talking about tank drain valve located at bottom of tank, then add a comment.
Following information is for TP valve.
Dripping TP valve can be caused by 3 different thing:
1) Obstruction inside TP valve. Open TP valve for a moment to flush away particles and slowly lower lever back down. See if water stops dripping, if not, then replace TP valve
2) Defective TP valve: replace TP valve. Turn off electricity to water heater. Let heater cool for several hours so you do not get scalded. Close shut off valve located above tank on cold side. Open tub spout to relieve pressure, open tank drain or open TP valve and empty water below TP valve level. If TP is located on top of tank, not much water has to be drained. Tank is under press when hot, so be careful. Put teflon tape on new valve and install with big pipe wrench by turning clockwise until TP valve is very tight.
3) Overheating tank. TP valve is temperature-pressure valve. If tank water is over 150 degrees, the TP valve starts drizzling hot water to relieve tank pressure.
Lower tank pressure two different ways:
a) turn down thermostat
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html
b) install expansion tank on incoming cold water line
http://waterheatertimer.org/Water-at-bottom-of-water-heater.html#expansion-tank
Dec 19, 2010 | Rheem Water Heater Pressure Relief Valve
It will not build pressure in the tank.
There is a pressure relief valve somewhere around the motor. Make sure it is closed. If the relief valve isnt leaking air while the compressor is running you probably have a loose hose on the line going from the compressor to the guages or the overpressure valve. Something under the motor/compressor cover.
Jun 30, 2010 | Porter Cable C2002 150 Psi 6 Gal...
Hot water coming out popoff vavle put new one on still does same.
If you have public water, it may have a check valve on it. Many municipalities have done so. If so, when the water heats, the associated expansion will push water out of the temperature/pressure relief valve. The solution is to install an expansion tank. You'll need to know your water pressure and water heater tank size. To check the pressure, get a gauge that attaches to the garden hose outlet and turn it on. That pressure reading will determine what you have to set the pressure in the expansion tank to. Good luck.
Mar 07, 2010 | Electrical Supplies
Too much water draining from Vulcan Electric H/W relief valve.
Dear Julie. Do you have an expansion tank installed? If so it is probably waterlogged. If you come home shower etc. use lots hot water then go to bed or leave the cold water in your tank heats and expands as it heats. In the old days a toilet ballcock valve would relieve this pressure but modern toilets with diaphragm valves wont so the pt valve relieves pressure. Installing an expansion tank on the cold water line near the heater will absorb the extra water & stop the pt valve from activating.
Dec 29, 2009 | Water Heaters
Over Pressure
I suggest trying to adjust the pressure switch, however, it is more likely that the pressure switch is bad and will need replaced. These can be purchased at most hardware stores or www.mcmaster.com. After you install it, you will need to readjust it to the pressure it was originally set to so as to not overpressurize the tank. Overpressure is very dangerous so do not use the compressor until it is repaired.
Best wishes!
May 10, 2009 | Air Tools & Compressors
Hydronic Boiler relief valve problem?
Check the pressure guage. Typically the pressure in a water boiler should not be more than 20 psi. If you are approaching 30, the relief valve is doing it's job. I would replace or adjust the automatic water feed if the pressure is high. Always replace the boiler relief valve. Tap on the expansion tank, it should sound hollow. Replace it if it is full of water. If you have one of the old expansion tank that has no bladder in it, drain it.
Dec 03, 2007 | Heating & Cooling
Gravity feed boiler/ american standard model#g27dpgc
your make up water pressure is greater than the safety relief pressure. The safety should be 30psi lift. the makup usually goes through a regulator called an automatic makeup valve. these valves operate infrequently on a closed system and get rusty. They stick. If yours is stuck open, then your makeup water pressure which is probably greater than 30psi is overpressuring your boiler.
Nov 11, 2007 | Heating & Cooling
Heating & Cooling Logo
54 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
