Question about Logitech Cordless Click! Mouse
Logiteck cordless click mouse not working
The mouse is completely gone off:
the battery is fine , i'ver tried various usb ports
tried the reset switch under mouse
what can i do
  • Anonymous Jul 09, 2008
    I am having the same problem. The green light goes on on the mouse for 10 seconds, then shuts off.
  • 741 Answers
You need a starting point. Need to find out if it is the mouse or the usb port. You stated you already checked the batteries and switch under the mouse and tried different USB ports. There are no other things to try. So I would guess the mouse is defective and bring it back. The only way to find that if it is the mouse or the usb port is to try a mouse that you know works. If it works then we know it is the mouse and you can return it, if it does not work then you know its the usb port.
Posted on Jan 04, 2009
Hi -- My problem with the Logitech wireless mouse is not working at times. Changed batteries and hit the reset button. thanks. Elaine
Check your USB port. There may be a light on the dongle (the part that plugs into the USB.
Is the light on? If you know this is working and you have changed batteries the mouse should work. Try the other USB port as an alternative.
Jun 17, 2011 | Logitech Cordless Mouse
Wireless Logitech mouse with NO connect button on it. Only buttons on it are Power and Reset (and one to open battery case). Cannot figure out how to connect to receiver. Was previously connected, but I...
Ok, try this in the steps ordered
1 remove the receiver from the USB port
2 remove the battery from the mouse
3 turn on the pc
4 after everything is loaded on the pc, plug the mouse receiver into the USB port
5 put the battery back in to the mouse and let it "find" the receiver.
If these steps don't work, try doing the steps and use a different USB port. If that doesn't work try a different battery in the mouse.
If none of this works and the receiver hasn't been bent (happens allot in laptops), then it sounds like your mouse took a dump.
Mar 18, 2010 | Logitech Cordless Mouse
My cursor wont move...and the usb isn't registering...
righkt click on my computer icon then click on property then hardware ->devicemanager .
Then uninstall all usb drivers then restart the computer .
Then try in all usb port .
Aug 14, 2009 | Logitech Cordless Mouse
Wireless mouse wont connect.
Hi there.
Some wireless mice seem to go into some kind of sleep mode, in other words if you leave them for an amount of time they disconnect, the way to reconnect is to right click while moving the mouse.
Also check to make sure that the batteries in the mouse are seated properly.
Good luck
Jun 01, 2009 | Logitech Cordless Desktop EX110
Logitech V220 cordless mouse won't work
The V220 is a quite nice rodent, my favorite. Check 3 things.
1) Is the battery facing the right way? Minus end goes in first. Green LED should turn on for a few seconds after the battery is installed.
2) Is the mouse ON? The switch under the mouse is supposed to turn on automatically when the receiver is removed. This does not always work.
3) Unplug the USB Receiver. Connect it to a different USB port. Run the Logitech Connect utility.
If the mouse still does not work, uninstall the Setpoint software and reboot. It is possible that the driver did not install correctly. After reboot, try Step 3 again.
Setpoint software is only needed if you want to use the wheel click or horizonal scroll features.
If all else fails, try installing your V220 on a different computer.
Mar 01, 2009 | Logitech Cordless Mouse
Mouse not working
if you have a reset button on bottom of mouse press
I'm assuming usb if there's a button on the usb press that to reset
did you restart pc after install
let me know if this helped
what os do you have
Jan 18, 2009 | Logitech Cordless Mouse
Logitech cordless click N231 mouse
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver burron and then press the button on the mouse. This should be fdone when ever you change batteries or glitch. Hope this helps you. Bud
Dec 30, 2008 | Logitech Cordless Mouse
Cordless Desktop EX 90 Mouse Not Working
have you checked that it is the USB port if it is not in the USB port it will not respond
Feb 22, 2008 | Computers & Internet
Wireless Mouse gets stuck
Take a eraser and use it to rub the contact points on your batteries clean. This seems to be the issue where your sensiativity will change by it self the the mouse has a 20 - 30 pause to reset it's self as if you just stuck a different battery in it.
Apr 16, 2007 | Logitech Inc G7 Cordless Laser Gaming...
Logitech Cordless Click! Mouse Logo
107 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
