Question about Dimplex DS5603 Heater
Change of bulb dimplex BFD2OR series F serial no 0008337 - how do I do this?
How to get to and change the bulb on my Dimplex heater. Serial # 18406D2F 297
Remove the bottom panel in the back. Make sure 60 watts or less. the lesser wattage gives you a ember effect.
Jan 30, 2015 | Dimplex Heating & Cooling
How do you change the light bulb in a dimplex gem 20 heater?
Hi, First ALWAYS disconnet from the mains!
To change the bulb on your Dimplex you'll firstly need to remove the log effect, there are 2 small black head pozi type screws hidden at the front one on the left and one on right which your bulbs are under situated in their holders (as there are 2 of them) they are mini screw types as opposed to the standard baynot type replace the defective bulbs with like for like once fitted reconnect the mains and try if working, JOB DONE! Page 14 on the link shows exactly how to do it Regards Steve.
http://www.dimplex.com/cms/publications/7400070000r01.pdf
Aug 07, 2014 | Dimplex Compact Electric Flame Stove...
Dimplex heaters CHB20BR owners manual how to change the light bulbs?
Changing the bulbs in your model is quite different than changing the ones in a full electric fireplace. Yours requires a bit more dismantling and removal of parts. So, I have provided a link to the Owner's Manual just in case you have misplaced yours. What you need to know is on Page 14 of the manual.
For future reference, I suggest that you download and print the manual. Then keep it in a safe, accessible place.
I hope this helped you and thanks for choosing FixYa.
Sep 23, 2011 | Dimplex DFI2309 Electric MidSize Heater
How do I change the bulb in my dimplex wynford inset fire?
On the back of the cabinet, about 3" to 4" up from the bottom, you should see a removable rectangular panel. Removing it, will give you access to the bulbs. Which are 60 watt, small base chandelier bulbs.
Turn the unit OFF & Unplug it, before removing the rear access panel.
Hope this helped you and thanks for choosing FixYa.
Aug 24, 2011 | Dimplex DS5603 Heater
Bottom bulbs don't work
Sounds light the 2- 60 watt small base, chandelier bulbs need changing. To access the bulbs and change them does require some dismantling of the base of the insert.
In case you have misplaced your Owners Manual, I have included a link to it that you can download and print for future reference. Pay particular attention to Page # 5 - Maintenance - Changing Light Bulbs.
http://partner.dimplex.com/files/domain4103/7205650100r04.pdf
Hope this helps you solve the problem. Please let me know. Thanks
May 07, 2011 | Dimplex DFI2309 Electric MidSize Heater
How to change bulbs on Dimplex HTN 20
If you have a compact fireplace in a cabinet mantle, you will need to remove the front Plexiglas and frame from the front of the firebox. Remove the logs, then the 1- piece ember bed (it just lifts out). This will give you access to the light bulbs.
If you what looks like an old wood stove, you access then from the rear of the unit. Remove the bottom access panel by unscrewing the 4 screws that hold it in place. You can then reach the light bulbs to change them.
In both cases, the replacement bulbs are small base chandelier bulbs.
Hope this helps to solve your problem.
Mar 11, 2011 | ACE Dimplex (r) Compact Electric Fireplace...
The heater on my dimplex fire appears to be working however i replaced dud bulbs with new bulbs, and they are not working?
dear sir/madam
have you checked for the power supply before changing the bulbs,if not please check it then you come back to us we will help you.
Aug 06, 2009 | Dimplex DS5598 Mid-Size Heater
Dimplex DS5603 Heater Logo
59 people viewed this question
Top Dimplex Heating & Cooling Experts
paulcarew
ashburton
Kory Ronning
Are you a Dimplex Heating and Cooling Expert? Answer questions, earn points and help others
