Question about Kenmore 62622 Microwave Oven
721.64682300 run for 30 second before giving me the F-9. Do you have a solution?
  • Kenmore Master
  • 9,011 Answers
Your model number prefix of 721 means it's made by LG / Goldstar.
F9 code on an LG means either a bad door switch or a loose door switch mount.
Even though a door switch clicks, it may still be bad inside.
This can be caused by slamming the door or by habitually opening the door while it's cooking without hitting the Stop pad first.
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa.
You can probably find exploded views and order parts by entering your model number here at the Sears parts site.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 13, 2008
Genius S333 refer to manual error after 3 seconds
If microwave runs only without turn table, I am suggest to check if turntable electric motor has got short circuit. If yes, I have some left.
Nov 13, 2013 | Microwave Ovens
Error code -SE-
Hi maaki41,
The error code SE stands for a keypad is held down for longer than 10 seconds. If you were not holding down a button then you have a defective key pad because of the sensor error. You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central.
Hope this helps.
Thank you for using FixYa.
May 17, 2011 | Maytag Over-the-Range Microwave
What is the se code that comes up on the oven, and it wount work? How can we fix this error code?
Hi longislandlu,
SE stands for "Sensor Error". This appears if the keypad is held down for longer than 10 seconds but if not held down this means that your humidity sensor has shorted and needs to be replaced. You will need to uninstall the entire unit and remove the outer shell to access the sensor that needs to be replaced. It will be mounted somewhere around one of the vent on the cavity of the microwave. You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central.
Hope this helps.
Mar 31, 2011 | Samsung SMH9187ST Microwave Oven
My kenmore microwave runs for about 5 seconds and then it quits and says F-9, how do I fix this?
F9 means the main board is going into either over current or low current mode and the probable cause is magnetron problems.
I would call an engineer to give you a repair price.
Mar 03, 2011 | Kenmore 63682 / 63684 / 63689 Microwave...
Our microwave has an error code -SE- and will not work what is this and how do we fix it.
Hi wmp_44,
Hope this helps.
Feb 18, 2011 | Samsung SMH7174BC Microwave Oven
Kitchenaid microwave runs for a few seconds and then shows error code F7. Kitchenaid Phone Center never heard of this error.
Hi alykat737,
This error code F7 on KitchenAid microwave is about a function key that is stuck on ERC. You will have to Replace control board (also called ERC or clock) to fix the problem. In case you will have to buy a replacement part you may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central.
Hope this helps.
Feb 06, 2011 | KitchenAid KHMS2050S 1200 Watts Microwave...
Power level
Press he power button and select a number 1-9. If you press 20 it will use 0 as the power. The numbers correspond to percentage of time the cooking energy is applied during the cycle. 5 is 50% so it will be cooking for 30 seconds out of each minute. 2 would be 20% and 9 = 90%. Hope this helps... Eric
Jun 07, 2010 | Rival MT660 Microwave Oven
Model 72180883400
F-9 error code indicates a defective control board, inverter or line voltage too high. f the microwave runs for about 7 seconds with a ticking sound..then stops and shows "F-9", it is the magnetron that has failed. The fact that the unit starts and runs with the TICKING SOUND means the control board is sending signal to inverter board and the inverter board is sending signal to magnetron. Magnetron is covered by full 5 year warranty, inverter board is only 3 years.
Sep 01, 2008 | Kenmore 62702 Microwave Oven
We set the cook time and push START, the oven runs for 30 seconds then stops,then (F-9) appears in the display window. What does this mean? Please send me an answer! Thank You, Tom Clegg PS...
What brand is your microwave? I looked under panasonic and kenmorer because of the numbers you gave but can find nothing under either. I need:
The Brand (complete Name)
The model(Complete model name
Model #
Please have another look. :0)
Aug 12, 2008 | Microwave Ovens
Shuts down after running about 8-9 seconds.
We'd need the full model number to be sure, but it sounds like an inverter failure. Due to the lethal voltages involved, I do not recommend that a person without training and experience ever work on these models. I would call Sears for service. See http://www.sears.com
Sep 15, 2007 | Kenmore 80883 Microwave Oven
Kenmore 62622 Microwave Oven Logo
177 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Jaime Hernandez
Jim Thurston
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
