Question about Whirlpool LER5636P Electric Dryer
I have Model # LER5636EQ3 dryer it all of a sudden quit working in the middle of a drying cycle. I Checked fuses in house all OK. Checked to see if other cycles worked will not start or make a sound at all.
    President:
  • 1,554 Answers
This problem is commonly caused by a blown thermal fuse located on the blower housing. The thermal fuse is wired in series with the motor and the motor activates a centrifugal switch for the heating element when it runs. These setup makes the dryer fail to start and the heating element not to turn on if the thermal fuse is blown. The dryer seems to no work at all. Verify the condition of the thermal fuse by bypassing it and starting the dryer.
Disconnect power then access and bypass the thermal fuse on the blower housing. The blower housing is located on the rear left bottom of the dryer cabinet. Remove the rear panel to access the blower housing and so the thermal fuse.
Bypass the thermal fuse by disconnecting the wires and connecting them together. Insulate them properly and plug the dryer back in. The thermal fuse is indeed blown and needs to be replaced along with the cycling thermostat if the dryer starts. Do not use the dryer with the thermal fuse bypassed due to fire hazards.
The thermal fuse and cycling thermostat are part numbers 3392519 and 3387134, respectively.
Posted on Dec 31, 2010
Whirlpool dryer wont start LER5636EQ3
The thermal fuse it probably the problem,jump it out to make sure but DO NOT leave it that way if it does work or you could burn your house down.Thwen be sure the vent is clear and the thermostat is cycling the burner.Good Luck
Jul 22, 2014 | Whirlpool Dryers
I have a Whirlpool electric dryer, model #LER5636EQ3. Several years ago, we replaced a part due ti the dryer not heating. It worked great, well a few years ago, the dryer began taking 2 cycles to get the...
BY THE TIME YOU PUT MORE MONEY IN IT, HAVE YOU PUT TO MUCH IN IT ALL READY.. YOU CAN CALL WHIRLPOOL FOR IDEAS OR THERE SERVICE TECH FOR APOINTMENT. NO MATTER WHAT IT WILL COST. WEIGHT YOUR OPTIONS GOOD LUCK
Jun 23, 2017 | Dryers
Dryer quit heating suddenly.
The fuse is located on the blower housing and if it was blown the dryer would not run at all. The limits is mounted on the heater housing and that could kill the heat as well as a blown heating element. I worked on a similar dryer not long ago with a heating problem and did a video:
DRYER NO HEAT
Jul 08, 2012 | Dryers
Magic chef dryer quit working
There is a thermal fuse inside the dryer usually located behind the back cover on the upper part of the combustion chamber. When this fuse "blows" it turns off power to the whole dryer. This keeps your house from burning to the grown, and you from dying. The fuse "blows" for a reason, most likely to is lint build-up in the dryer and/or dryer vent system. The good new it only cost a few dollars to get a new one. The bad news is you need to find out why it "blew", the dryer got to hot for a reason.
Mar 04, 2010 | Magic Chef CYE2000 Electric Commercial...
Dead!! No electrical.Have checked house circuit
check thermal fuse,also see if dryer needs to be cleaned out,clean out lint duct vac out cabinet and go outside and make sure the flapper is opening sometime you need to blow out the vent line,leaf blower works great for this
Nov 07, 2009 | Kenmore 62602 Electric Dryer
Dryer ran fine. Next load it would not start. It is a 220V, 5 cycle-3 temperature unit. Model # LER5636EQ3 TYPE: 178-00
Check your door switch to make sure its ok. Whirlpool has a fuse on the back of the machine inside. Fuse will be white in color. If that is open, check for a clogged vent or ck your hi-limit thermostat. If everything else is ok you have a bad timer.
Sep 10, 2009 | Dryers
Roper dryer model REX 3514RQ1. dryer works for/then quits. help!!
I have seen this before. You have got to remove the housing for the filter. Blow out the area around the blower and get the junk out of there. Wash out the filter housing.
Jul 06, 2009 | Dryers
Kitchenaid Superba Dryer also stopped working (3 years old)
Yes it is, you can bypass it for testing purposes only, also clean out your vent too the outside it is probably clogged that is what usually blows them out.
Jul 24, 2008 | Dryers
Dryer heats up but clothes won't dry
Sounds like to me, that you need to check the vent going outside from the dryer. I had the same problem, and found a birds nest in the dryer vent on the outside of my house restricing air flow. If that doesn't fix the problem, look into a new heating element and or thermostats for the dryers. The old ones could just not be getting hot enough anymore. Good luck.
Apr 08, 2008 | Whirlpool LER5636P Electric Dryer
Machine fuses house RCD if a drying cycle is selected
Suggest you turn the power off, remove the top cover, diconnect the live and neutral connections to the dryer element (likely to be two of each flavour of connection if the machine has high and low dry settings). Pop a bit of insulating tape around the wire ends so you don't short anything out. Now try to put the machine through a drying cycle. If it works (albeit cold) without tripping the house power, you need a new dryer element. If the house power still trips, turn the power off again and without reconnecting the element wires, disconnect and tape the live and neutral wires from the blower motor. Again, try to run a drying cycle. If this stops the house power tripping, then it looks like a motor problem (though this would be quite unusual). If the house power still trips, you need to have a careful look at all the wiring between the main timer, the dryer timer, any hi/lo heat switch, the blower motor and the element with its associated thermostats and thermal cutouts (all located near the element on the air duct). Look in particular for chafes where wires go round corners, and where wiring crosses from the case to the suspended machinery in the middle of the machine. Pop any follow-on queries in the comments section of this question - I'll keep half an eye on it. A.
May 19, 2007 | Hotpoint Aquarius WD63 Front Load...
Whirlpool LER5636P Electric Dryer Logo
1,460 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
