Question about Canon iR1600-2000 PS
Canon ir1600 photocopying machine giving rom error.what could be the problem? error appears when the copier is switched on
  • Canon Master
  • 7,733 Answers
How do I solve a system error E000 on canon iR1600 photocopier?
First you need to clear that error from service mode. If problem persist replace the fixing unit
Jun 15, 2015 | Canon Office Equipment & Supplies
My photocopier (Canon iR1600) displays a message that the output tray is full when i try to photocopy
hi . check the flag sensor in the output tray . if you move the flag sensor up it should come down when you loose it
Mar 06, 2013 | Canon iR 1600 Copier
I have Cannon 3300 digital photocopier but as soon as I switch on machine an erron appear E000002-0000 and machine is not operating
Hello
what you need to do is just resetting your machine. 1. Press * 28 * on your machine in a quick move. 2. Select copier 3. Select Err. 4. Select Clear then press O.K 5. Turn your machine off for 1 minute and turn it on again.
The error code will not be there anatmoreand your machine will be functioning well.
otherwise
This code also for Heater Coil Fault. Replace the Fixing Element Coil.
Hope this helps
Jan 22, 2011 | Canon imageRUNNER 3300 All-In-One Laser...
Want to correct a system error E000 on canon IR1600 photocopier
E000 indicates a low temperature problem in the fuser unit.
  • Check the fuser for any jammed paper and remove it
Check and replace with spare part if needed:
  • the thermo lamp,
  • the thermistor in the fuser unit
A code reset is needed:
  1. Press ADDITIONAL FUNCTIONS, #
  2. Go to #7 PRINTER, press OK
  3. Go to #4 PRINTER RESET, press OK
  4. YES = (*)
  5. Power cycle the unit.
Jan 05, 2011 | Canon iR1600-2000 PS
How to photocopy double sided A4 sheets?
you copy first side normaly. then on left side open bypass deck.Put the paper, so that the side on wich you want to print is down. Automatically when you put paper in bypass, the machine ask you wich format is it ( eg. A4 ), confirm with OK, then you need to tell machine wich type of paper ( eg. plain paper ) and OK. then green copy key.
May 02, 2009 | Canon iR 1600 Laser Photo Printer
Sir,My IR1600 dosnt fuction or now dosenot start to work
Hi, do you have an error message like E100 ? Please be specific.
Mar 22, 2009 | Canon imageRUNNER 1600 Laser Printer
Technical suport
Try checking the fuser section,
1- bad thermistor
2-bad thermofuse
3-bad fuser lamp
Aug 07, 2008 | Office Equipment & Supplies
CANON IR 2000
Canon iR1600/2000 not a double-sided copying machine. Can print one side then reverse copies in paper cassette and copy side 2 onto it.
Jan 31, 2007 | Canon imageRUNNER 2000 Copier
Computers & Internet Logo
297 people viewed this question
Top Canon Computers & Internet Experts
Computer Links
Tony
old marine
old marine
Are you a Canon Computer and Internet Expert? Answer questions, earn points and help others
