Question about Pioneer Televison & Video
Here's my delema...........I have a Pioneer subwoofer HTP102-SW and want to conect to my Pioneer AC receiver. Subwoofer has 8 speaker ports (L+R output & L+R input). Do the speakers connect to the subwoofer or the receiver and which ones. Do I connect the speakers to the receiver and place another speaker wire in the same port and place it in the subwoofer? I'm lost, please help.
  • 675 Answers
The left and right outputs from the receiver go to the left and right inputs on the subwoofer and then you wire the left and right speakers to the left and right outputs on the subwoofer....it is sort of what we calll daisy chained
Posted on Dec 30, 2010
Can u hook it directly to a lg tv tried but sounded really bad
What are your front channel speakers connected to? Or are you just using the TV speakers for that? Most TVs don't have a dedicated subwoofer output and that's a necessary level of pre-amp out to give the subwoofer proper low frequency signals. If you have an amp/receiver then it probably has a subwoofer output.
Feb 23, 2016 | Pioneer SW-8MK2 Andrew Jones Designed...
How to hook up psw350 polkaudio powered subwoofer
A powered subwoofer is fed the sw line output provided by the receiver. If lacking, then the woofer might have connections to it from the speaker outputs of your receiver.
Connect them in phase, make sure your sw is in phase with other speakers and balance the sw output.
Sep 20, 2015 | Audio Players & Recorders
Will a pioneer receiver vsx d309 run 2 8 ohm speakers and 1 jl audio w3
It will drive the speakers but not the subwoofer. U need to connect the subwoofer pre- output from your amplifier to another amplifier that will drive the subwoofer.
If you connect the subwoofer directly to your amplifiers speaker output it will force the subwoofer to play the entire spectrum of frequencies (not designed to do that) consequently causing damage to the sub and maybe even the amp. So use the sub pre out.
hope this helped
....andy....
Dec 29, 2013 | Pioneer Car Audio & Video
Pioneer VSX-822-k Subwoofer problem
Go to manual setup, selct the subwoofer and set it to Pus.
Jul 29, 2012 | Pioneer Vsx-822-k 5.1-channel 3d-ready...
How to connect my subwoofer to my vsx-405 receiver
Hello
Try to download the user manual to Pioneer VSX & THX user manual. click here to down load the same. You will get details of it connections from the manual.
http://www.dataentryjobs.us/67948.html
Feb 24, 2012 | Pioneer VSX-405 Receiver
I just bought a subwoofer and I cannot get it to work. I changed the receiver setting to SW = YES. Where is the correct place to plug it in the receiver, there are two subwoofer outlets.
Here's your manual. Check Pg. 9 for correct Sub Woofer connection. Leave the SW=YES setting as is if you any small speakers in the system. It can be set to SW=PLUS if you want all bass signals sent to the Sub Woofer. It should only be set to SW=NO if no Sub Woofer is connected. Experiment between the YES and PLUS settings and leave it where it sounds best to you.
If this was helpful, please rate it "4 thumbs up" - thanks & good luck!
Aug 04, 2011 | Pioneer VSX-D514 Receiver
Ok i just got the sub from a sony sswg450 i want to know is there some way to hook it up to my Pioneer home Receiver
Did you get a manual with it? According to the Sony site this speaker originates in Sony MHC-GX450.
"This product bundle includes the following models:
HCD-GX450 - STEREO MINI SYSTEM
RM-SC3 - REMOTE CONTROL for Shelf Mini Systems
SSRG444 - FRONT SPEAKER FOR MHCGX450
SS-WG450 - SUBWOOFER FOR MHCGX450"
Find the manual here and learn a bit about your seprated sub...
http://esupport.sony.com/US/perl/model-documents.pl?mdl=MHCGX450
See page 7.
As can be seen, the subwoofer has two connections to the mothership, very unlike the standard speaker level (+/-) speaker wire or RCA-Line-Level subwoofer out that 'normal passive or active subwoofers use, respectively.
Not knowing which of those your unspecified Pioneer receiver supports, it is impossible to say. Does your Pioneer have that control jack?
Mini-systems are generally not designed to be pieced out and used with grown-up gear. The absence of standardized connections is the clue.
Apr 17, 2011 | Sony MHC-GX450 CD Shelf System
No Sound from Subwoofer
The original Pioneer subwoofer has its own amplifier built in to the speaker, so the only cable required on the original speaker is a single RCA cable. To connect a different brand subwoofer to the Pioneer you will have to make sure that you have a subwoofer with the same specs. It will need its own built in amp to work, as you can only connect it with one RCA
Jul 31, 2009 | Pioneer VSX-818V-K Receiver
Speaker wire for subwoofer
Usually, a subwoofer will have its own built-in power amplifier. Thus, it will be designed to plug into a standard RCA jack (the type used for DVD players, etc). rather than having wires to connect to a speaker terminal block. Look for a jack on the back of the receiver called "Subwoofer", or simply "SW". If your subwoofer has 2 single wires, it WON'T work with your reveiver's subwoofer output, as this output only carries a line-level signal and is not amplified. You would need a separate power amplifier for this type of SW. If your SW speaker has a DVD-type plug, it should work fine with the receiver's SW output jack.
Jan 02, 2009 | JVC RX-554V Receiver
Televison & Video Logo
133 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
