Question about Bosch Washing Machines
Hi there! We have a Bosch Vision 500 front load washer. We purchased it in the US and moved abroad so we have no warranty on it. In our first attempt to use it after replacing a faulty door lock it came with, it did not fill ( but started to spin). When the time to drain came, it showed error 13. The water pressure seems to be low and we wonder if it would cause no filling at all or just slow filling. Any ideas out there? Thanks! We are our wit's end with this washing machine!
  • 17 more comments
  • Barrett Palumbo
    Barrett Palumbo Dec 30, 2010
    what voltage and cycles do you use, and did you convert the unit..
  • sgdelima Dec 30, 2010
    Hi, the model is Bosch Vision 500 WFVC544AVC. Our manual says error 13 means pump is blocked. That is not the case however, because the water hasn't even gone inside the machine. What is the pressure switch and where is it located?
    Hi Barretdenco
    the machine is 110 w and our current town uses 220 but yes we have had a 110 W outlet put in especially for the washing machine by a certified electrician so that isn't the issue
    New info: we only have cold water in our house. The problem appeared while trying to wash with cold water. If we connect our water supply to the hot water inlet ( we think part 407) it works. We don't think it's possible for part 406 to be dirty as it is a brand new washer.
    Not too sure what 436 and 433 have to do with it- aren't those outlet mechanisms? And how do we get to them?
    Also, would there be a problem if we just left cold water supply connected to the hot water inlet ( for example, are there certain cycles that don't use hot water and would therefore not be useable?)
    OK, but why would the latch and pressure switch only have problems with the cold water? Doesn't this point to a problem exclusively with the inlet valve for the cold water? And if so, what should we do about it?
  • sgdelima Dec 31, 2010
    Hi, Daniel
    we got the cold water inlet valve out. It looks good ( we can't see any dirt or rust). Is there anything we should be looking at or a way to test it? Thanks
    So- we have the valve out. How can we check/ test it?
    Hi, Dan
    I have no idea what "test the two terminals" means, sorry! What should I use to test the terminals with?
    OK- so you mean put ir back inside the machine and test it with a voltimeter, right?
    First our inlet valve has 3 wires leading to it, not 2 or 4.
    It has two thingamagigs which we guess are the solenoids.
    Our multimeter does not have a ohms X1 setting. In the ohm settings the options are 200, 2000, 20 K, 200K, 2000k. Please advise what to do.
    Hi
    we tried the multimeter in the lowest range of ohms possible ( a little symbol) and got no change in the number- 1
    No readings in 20K. We tried all the ohm options and the reading it still at 1 on all of them. : (
    by the way, for compariosn's sake we tried to read the hot water valve ( which is working) but sill the multimeter won't budge.,
    But the hot water valve is functioning and is also not being read by the multimeter. Doesn't make sense.
    So...is there a repair for the valve ? We can't get spare parts where we live except if we import them and it takes a long time
    actually, it just started working. Happy new year.
    miraculously. we just put everything back in and closed the machine up and now it works.
    So- reporting back. After taking the water inlet valve out and checking it and being led to conclude it needed to be replaced (which would have been a major problem since Bosch won't help us since we moved abroad with the brand new machine), we put everything back together and IT WORKS! Just like that. We have no idea what worked, but it works.
  • 4,323 Answers
Hi
The problem seems to be with the water inlet valve or the pressure switch that is bad and causing this issue. However, please post back with the model no so that I can tell you what error code 13 means and what part is causing this issue. Hope this helps...
Daniel
Posted on Dec 30, 2010
  • 8 more comments
  • Daniel Scott
    Daniel Scott Dec 30, 2010
    Please check this http://c.searspartsdirect.com/lis_png/PL..." target="_blank" rel="nofollow" >picture, part#406,407 is the valve that you can clean and part#436 is the pressure switch that needs to be checked along with the latch mechanism which is part#433
  • Daniel Scott
    Yes you are right there are certain cycles that use hot water and won't take water when required causing this issue. Part#433 which is the latch send signal to the control that the door is closed and then the water will enter the unit to start the cycle. Part#436 is the pressure switch which controls water pressure inside the unit if this goes bad water wont flow in the unit.
  • Daniel Scott
    Yes that is the reason I told you to check the water inlet valve first.
  • Daniel Scott
    Daniel Scott Dec 31, 2010
    Test its two terminals and tell me the reading that you are getting
  • Daniel Scott
    Sorry....use a voltmeter to test the water inlet valve
  • Daniel Scott
    Yes right....There will be two wires
    connected to the water inlet valve. If your dishwasher's water inlet valve has
    two solenoids, then there will be four wires. Label the wires so that you will
    be able to correctly reconnect them later. The wires are connected using
    slip-on connectors. Grasp the connectors and pull on them firmly in order to
    disconnect the wires from the valve's terminals. Do not pull on the wires
    themselves. You may want to use a pair of needle nosed pliers to help you. Use your multi tester to
    test the valve for continuity. Set the device to the ohms setting x 1. Touch
    each of the meter's probes to a terminal. If you receive a reading of infinity,
    it means the valve's solenoid is faulty and the valve needs to be replaced. If
    your valve has two solenoids (four terminals), test the second pair of
    terminals in the same manner. If either pair of terminals receives a result of
    infinity, replace the water inlet valve.
  • Daniel Scott
    Try the multimeter in 20k
  • Daniel Scott
    The valve is bad and should be replaced
  • Daniel Scott
    Sorry no repair only a replacement
  • Daniel Scott
    LOL....something might have come loose and when you put it back it worked.....Happy New Year :)
How do I find the codes on my washer bosch 500
On http://www.onlineonderdelenshop.nl/blog/storingcode-fout-code-bosch-siemens-wasautomaten-wasmachine/ you can find some Bosch codes in Dutch with some explanations.
Oct 19, 2014 | Bosch WFVC540SUC Vision 500 Washer in...
Cannot remove filter for bosch wfvc544auc
the best way is to remove the pipe to the pump then slowly remove bits then the filter will come out
be gentle do not force it
Feb 11, 2014 | Bosch WFVC544AUC Vision 500 Series 27"...
Front load washer Bosch Vision 300/500/DLX will not drain getting a code of E27 can you help. Can't find the code # in the booklet that came with it.
A code E27 means a problem with the door lock. Try unpluging the machine for an hour and see if it resets the lock.
If not remove the cover on the lower right corner you will see a white plastic pull cord. Pull the cord and pull open the door. If that doesn't reset the door lock you will need to replace the lock.
Nov 22, 2012 | Bosch WFK 2401
Noisy pump in bosch nexxt 500 washer
no its usually not that loud at all contact bosh direct to have them send you a new one or call them if its still warrantied
May 01, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Bosch 500 series Front Load Washer Door hanging a bit lower than when purchased
Even if you do not realise it most people lean on the door as they open it, to rectify with the door open but almost in the closed position lift the door by pulling up on the door catch end, this will straiten the hinge, very common problem Regards Engineer
Jul 26, 2007 | Bosch WFMC 3200 Front Load Washer
Washing Machines Logo
233 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
