Question about Linksys Wireless-G Broadband Router
I have a LINKSYS model: WRT5462 V1 router and i have internet connection when i directly connect my laptop to my DSL machine. My laptop can detect the wifi signal but it says LOCAL ACCESS only. how do i fix it? i cannot use my wifi functions on any device even itouch. Thanks for the help
  • 600 Answers
Your only connected to the router ot the internet--the router did not assign an Ip address
Have the wireless router set up and configured to broadcast the signal (not hidden) ....first we have to determine if the problem is at the router or at the laptop AND at what point its getting stuck ... so first try this
try resetting the router (disconnect the power to it for a few minutes) next --be sure the wifi switch is enabled on the netbook---next---go to CONTROL PANEL>NETWORK CONNECTIONS--right click oin your wifi card and choose properties--highlight INTERNET PROTOCOL and choose properties and be sure "OPTAIN IP ADDRESS AUTOMATICALLY" is checked--Does the laptop "SEE" the router?
You will need your SSID to logon to the router(internet)
follow this link to a troubleshooting flow-chart
http://www.daileyint.com/hmdpc/laptop/wireless.gif
If this was helpful, please indicate so, if not -comment back so we can dig further to resolve this.
Posted on Dec 30, 2010
    Sergeant:
  • 210 Answers
Hi, First you have to configure the router. to configure connect the patch cable to your laptop, connect the other end to the #4 ethernet slot of the router. Open a internet web browser type at the address bar the IP address 192.168.1.1 the router will open and will as for user ID admin Password is admin or password. You can change the password of the router, SSID and security enable and use passphrase or key. I hope this information will help you solve the problem. Have a Happy New Year... HRH
Laptop not seeing router cable company shut off service by mistake, main computer has access but laptop does'nt I have a wireless G WRT5462 V1
You will need to check the wireless settings of the router.
If your network is secured then make sure that you are typing the correct network key.
also make sure that the DHCP server is enabled on the router.
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Apr 22, 2010 | Linksys Wireless-G WRT54G Router
HOW TO USE INTERNET IN MORE THAN ONE PC FROM LINKSYS WIRELESS G B
You have two ways on how you can get other computer online through this router. First, you can wired them (using an Ethernet cable) to one of the Ethernet ports on the back of the router. They are the ones labeled 1, 2, 3, and 4.
Second is through wireless, but those computers that will connect through wireless must also have a wireless adapter to be able to pick up the signal that this router is broadcasting.
Feb 12, 2010 | Linksys Wireless-G WRT54G Router
My linksys WRT150N router won't recieve internet signal from my dsl modem. The router sends out a signal to my lap top, but no internet connection can be made.
Try connecting your laptop directly to the dsl modem to make sure that it is working correctly.
If the dsl modem is working correctly then:
1. Turn off the power on the router and dsl modem.
2. After about 2 minutes, turn on the dsl modem.
3. Wait another 2 minutes, then turn on the router.
Occasionally you need to do this to get them back in synch. If this doesn't work you may need to use the software utility to reconfigure the router.
Dec 27, 2009 | Linksys Wireless-N WRT150N Router
Setting up Linksys Wireless Router for Satellite
In Windows, run "cmd". Type "ping google.com". If you can ping google.com, the problem is with the websites you are trying to surf. If you cannot ping google, there is a problem with your connection. This sounds like a used wireless router
You might need to configure it. See this: https://www.linksys.com/us/support-article?articleNum=139668#H2
Oct 16, 2017 | Gateway Belkin 54g Wireless DSL/Cable...
I have a cisco linksys wrt54g2 v1 that I have hooked up to my verizon dsl modem. My computer says I am connected but it wont let me get on the internet. If I plug the ethernet cable from the modem to my...
Connect the cable from the LAN port on the DSL modem to any of the 4- LAN ports on the Linksys Swicth (not the port Labelled Internet), then from any of the remaining 4 ports then connect your computer. Also try using a cross-over cable to modem from the DSL LAN port to the Linksys.
Oct 24, 2009 | Linksys Wireless-G WRT54G Router
DSL line disconnects on WRT54GS only
Try to change the LAN IP address of your router to 192.168.2.1 by accessing the router's Setup page. You also need to set your Westell modem to "full-bridge mode". You need to ask assistance from your ISP to bridge the modem. After that, set-up the Linksys router to PPPoE then power cycle it.
Apr 15, 2009 | Linksys Wireless-G WRT54G Router
Setting up a lan and internet thru MTNL triband
I suggests you to go for Linksys. It's a good product when it comes to wireless internet. Linksys router must be plugged in to the modem. On the back of the router, you can plug the vista on port number 1 then your win XP machine can go wireless at the same time.
Sep 16, 2008 | NetGear DG834G Router
Linksys Wireless-G Broadband Router Logo
503 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
