Question about Brother P-Touch 3600 Label Printer
Please help me. i use a P-touch 3600 printer. i have been printing in Gothic fonts for a while...unfortunately i can't remember the previous setting. so when i want to print barcodes it comes up with an error message: TEXT TOO LONG. Not sure what it meand or where to set it the way it was. and i can't find the reset button as it say in the manual
Metawatch
  • 96 Answers
SOURCE: not printing
Machine Error 46 – Purged Ink Box Full MFC620CN/420CN/410CN/210C and FAX2440C
The machine counts all purge (cleaning) operations in order to prevent the internal ink absorber box from overflowing with purged ink. An “initial purge”, for example, advances the purge counter by 187 + 420 = 607. When the purge counter approaches 6400, an internal "Machine Error 46" is generated. Further purge operations are prohibited, and therefore the printer becomes unuseable.
When an internal Machine Error 46 is generated, the user will see an “Unable to Clean” external message and will be unable to use the printer. The “Unable to Clean” external message can relate to many different internal error codes however.
The user can establish the internal Machine Error Code as follows: pull the mains cable out of the machine (power off), hold down the Menu/Set key, re-insert the mains cable into the machine (power on). The internal Machine Error Code will be displayed.
If there is a Machine Error 46, it is necessary to dismantle the printer, replace the ink absorber box (or possibly break the ink absorber box open and clean its absorbent sponges under a tap), re-assemble the printer and reset the purge counter to zero.
Resetting purge counter MFC620CN/420CN/410CN/210C and FAX2440C
1) Enter machine maintenance mode (on MFC210C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the “up arrow” key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine's log information list (function code 80).
3) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
Carry on printing !!
Posted on Feb 09, 2008
  • 54 Answers
SOURCE: printer Busy or Error
First you check the printer que if any que is there then delete the que, second check the printer n/w setting correct it & lastly restart the printer spooler services. I think you problem will solve.
Posted on Mar 01, 2008
SOURCE: My Brother MFC-465CN is printing text with alignment off and double text.
connection
Posted on Sep 10, 2008
SOURCE: how to switch from "offline" status to "online" status
I had the same problem with a Brother MFC-6490CW AIO printer. Here is how I resolved it:
Open the printers folder.
Right-click on the Brother printer and display the Properties page
Select the Ports tab.
In my system (Vista Premium), the selected port was a WSD port (whatever that means). Further down the list, there was a TCP/IP port that was obviously created by the Brother installation software. I selected the Brother-created TCP/IP port (which deselected the WSD port), applied the changes, and suddenly my printer was online. No idea what the difference between these two ports is, but I'll stick with the TCP/IP port until further notice.
Posted on Mar 02, 2009
SOURCE: Brother DCP-145C Print in black and white..?
As far as i know it will not work for color print unless all the cartridges are full. It will still print in b&w- go to properties of your printing document and change to "greystyle" but this will only work if you don't/have not turned off the machine at the power point. Once the machine is reset it wants to confirm all new cartridges and wont allow a black print until they are all in and full. So you cant use cartridges that have run out to "trick it".
I'm not sure if this is the intent of brother ( my guess is yes) a design oversight or a genuine precaution measure for consistency by not letting the printing heads dry out.
The yellow always runs out first, so stock up on them if you do alot of color printing- but the cartridges only last for 6 months so don't go crazy.
Brother if your reading this- Most of us don't care about color~! We just need a printer for uni and information. Make it work on our price range please!
Posted on Mar 07, 2010
Suddenly the font size on my printer increased greatly.How can I get it back to normal????
Printers do not understand fonts. They print dots, and they print them wherever the application that created the document, modified by the print spooler settings tells them. Thus there is nothing wrong with the printer. Check the print driver (spooler) settings. Do you have them set to "enlarge to fit page/shrink to fit page"? Do you have the wrong size paper selected? That, along with the previous problem, can cause major issues.
Sep 10, 2016 | HP Photosmart 5520 e-All-in-One Printer
I print labels with my Microline 320 Turbo. I put a new ribbon in and the labels are so wet and bold and after sitting for awhile they bleed until you can't read them. I have the lever on the print head...
This results from theway the print head is striking the paper. If you have it set to NLQ. it will be heavy, you can set it to a draft mode or SSD:
Print the Menu Settings, to see what your settings are:
Printing the settings is the only way to have a record of
the settings.
1 Make sure paper is loaded in the printer.
2 Enter the Menu Mode (SHIFT + SEL).
3 Press PRINT (PARK key).
Print Quality
! Important!
Front panel settings for print quality and character
pitch are overridden by software commands.
The lights will always reflect the printer's state.
Press PRINT QUALITY to select:
NLQ: Near Letter Quality
• Highest quality, slowest speed
• Courier or Gothic fonts
• Recommended for correspondence
UTL: Utility
• Medium quality, medium speed
• Gothic font only
• Recommended for internal documents and high-volume
data.
HSD: High Speed Draft
• Lower quality, faster speed
• Gothic font only
• Recommended for drafts.
SSD: Super Speed Draft
• Lowest quality (12 cpi only), fastest speed
• Gothic font only
• Recommended for fastest output of drafts.
Super Speed Draft
To use Super Speed Draft (SSD), enter the Menu Mode and
make changes as follows:
1 Press SHIFT + SEL.
2 Press GROUP twice.
3 Press SET until DRAFT prints as the setting for the Print
Mode.
4 Press ITEM.
5 Press SET (SSD prints).
6 Press SHIFT + SEL to exit Menu Mode and save your
changes.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 01, 2011 | OKI MICROLINE 320 Turbo Matrix Printer
P Touch 1880 indicates MAX font size, but prints smaller sized label. If I print one word at a time, it prints in MAX size. If I print two or more words, it prints smaller font. Weird, new problem.
Sounds like you may have a maximum length set that keeps you from printing over a certain length of label and it is adjusting your font size to fit that length. You may need a manual to figure out how to reset the length.
Jan 14, 2011 | Brother P-Touch 1180 Label Printer
Printing envelopes from stamps.com from the MP tray on a Canon Imageclass 4350d - after printing I get a message asking "use current size". If I say yes it prints again, if I say no it prints again.
This can likely be solved with one of the following solutions.  If these do not work, please feel free to contact me at social(at)stamps.com. Thanks! This can likely be solved using one of the following solutions. If these do not work, please feel free to contact me at social(at)stamps.com.
1) Change the Printer Options - Enable L90 Only
2) Set Paper Feed to "MP Tray" and Change Printer Options to Enable EF only
3) Change paper size on printer to "B5"
Thanks!
Chuck
Stamps.com
!-- /* Font Definitions */ @font-face {font-family:"Cambria Math"; panose-1:2 4 5 3 5 4 6 3 2 4; mso-font-alt:"Calisto MT"; mso-font-charset:0; mso-generic-font-family:roman; mso-font-pitch:variable; mso-font-signature:-1610611985 1107304683 0 0 159 0;} @font-face {font-family:Calibri; panose-1:2 15 5 2 2 2 4 3 2 4; mso-font-alt:"Century Gothic"; mso-font-charset:0; mso-generic-font-family:swiss; mso-font-pitch:variable; mso-font-signature:-1610611985 1073750139 0 0 159 0;} @font-face {font-family:Consolas; panose-1:2 11 6 9 2 2 4 3 2 4; mso-font-charset:0; mso-generic-font-family:modern; mso-font-pitch:fixed; mso-font-signature:-1610611985 1073750091 0 0 159 0;} /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-unhide:no; mso-style-qformat:yes; mso-style-parent:""; margin:0in; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:Calibri; mso-fareast-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;} p.MsoPlainText, li.MsoPlainText, div.MsoPlainText {mso-style-noshow:yes; mso-style-priority:99; mso-style-link:"Plain Text Char"; margin:0in; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.5pt; font-family:Consolas; mso-fareast-font-family:Calibri; mso-fareast-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;} span.PlainTextChar {mso-style-name:"Plain Text Char"; mso-style-noshow:yes; mso-style-priority:99; mso-style-unhide:no; mso-style-locked:yes; mso-style-link:"Plain Text"; mso-ansi-font-size:10.5pt; mso-bidi-font-size:10.5pt; font-family:Consolas; mso-ascii-font-family:Consolas; mso-hansi-font-family:Consolas;} .MsoChpDefault {mso-style-type:export-only; mso-default-props:yes; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:Calibri; mso-fareast-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;} @page WordSection1 {size:8.5in 11.0in; margin:1.0in 1.0in 1.0in 1.0in; mso-header-margin:.5in; mso-footer-margin:.5in; mso-paper-source:0;} div.WordSection1 {page:WordSection1;} -->
Aug 25, 2010 | Canon ImageCLASS MF4350d Laser All-in-One ...
I cant figure out my brothers code to his itouch
font.f1 {font: 12.0px Helvetica} Thanks for asking your question with Fixya Support. I will be glad to assist you.
font.f1 {font: 12.0px Times} • If you cannot remember your pass code, you will unfortunately have to restore your iPod Touch which will wipe everything off the iPod and restore it back to factory settings.
The only positive side to this is that your music, video, contacts and calendar settings will still be in tact but you may lose text messages mail and so on.
One more possibility: if you were able to recently sync your iPod with iTunes before you forgot your passcode, when you perform a restore, iTunes will put all of the data of your last sync in iTunes (before the passcode issue) back onto your iPod.
• This is the process which will allow you to regain access to your iPod Touch.
I hope this helps.
Regards,
-Mactechtrainer
May 27, 2010 | Apple iPod Touch 8GB 32GB 64GB 3rd...
Please my Ipod touch said Tap to Unlock
One more possibility: if you were able to recently sync your Pod with iTunes before you forgot your passcode, when you perform a restore, iTunes will put all of the data of your last sync in iTunes (before the passcode issue) back onto your iPod.
• This is the process which will allow you to regain access to your iPod.
I hope this helps.
font.f1 {font: 12.0px Helvetica} Regards,
-Mactechtrainer
May 27, 2010 | Apple iPod touch
How to unlock a ipod 8 g
font.f1 {font: 12.0px Times font.f1 {font: 12.0px Helvetica} Thanks for asking your question with Fixya Support. I will be glad to assist you.
One more possibility: if you were able to recently sync your iPod Touch with iTunes before you forgot your passcode, when you perform a restore, iTunes will put all of the data of your last sync in iTunes (before the passcode issue) back onto your iPod.
Processes for backing up, restoring and updating iPod Touch
I hope this helps.
Regards,
-Mactechtrainer
May 11, 2010 | Apple iPod touch
How to set it 20 characters per inch
Where do you want to set the font?
Do you want the font as the default font on the printer or do you want the application to call the font?
Application wise, to get a 20 cpi character font, you need to place the font change into the document.
Remember, even if you set the default font as a 20 cpi, if the application calls for a 10 cpi font like Courier, the printer will change the default font to the 10 cpi font for the life of the current print job unless there are additional font calls within the print job.
The software (Application always overcomes default settings)
Don
Feb 15, 2010 | Panasonic KX-P3626 Matrix Printer
How to identify current font settings
Try printing the menu like this -With power on press the "Shift" tand "Select" button, a red menu light will pop up on the touch panel ! than press the "Print" button on the touch panel-this will print out the current settings of your printer.
Good luck
Dezzi
Sep 21, 2007 | OKI MICROLINE 520 Matrix Printer
Brother P-Touch 3600 Label Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
