Question about HP PSC 1315 All-In-One InkJet Printer
I have receive a print cartridge error message (Print cartridge error) and red light blinked.
  • HP Master
  • 7,733 Answers
Printer blinking red and showing letter E
Error description:
The Attention (red) light is blinking. There are six possible causes that will display the Attention light pattern:
-Paper out
-Door open
-Print cartridge missing
-Paper jam
-Paper sensor jammed
-Duplexer error
Solution :
After the cause of the problem has been addressed, pressing GO will cause the printer to attempt to recover from the cause of the error. If the printer is unsuccessful, it will continue to display the Attention message until the cause is remedied.
Pressing JOB CANCEL will cancel the print job and the printer will return to the Ready state (Ready light on) unless there is a paper jam still in the printer or the print cartridge is not in the printer.
For more details visit the link below :
Resolve Printer issue
Jun 09, 2011 | HP DeskJet F380 All-In-One Printer
I put in new ink cartridges and now there is an E and 2 red blinking lights
Which lights are blinking red? What is the rate of the flashes? I'll assume that one of the blinking lights is the power light (just means error).
If the either of the ink cartridge lights is blinking rapidly, the cartridge may not be seated correctly. Try reseating the cartridges and then press OK to clear the error. If it is a less rapid flash it could be that the print head isn't reading the cartridge ink level correctly. Please note: refilled or non-Epson cartridges may not be read correctly due to information stored in a chip on the cartridge or in the printer.
In this case the problem may be in the print head and Epson doesn't recommend cleaning this yourself. You can replace it. (On other inkjets, pop out the cartridges, remove the print head and wipe with soft, lint-free cloths or q-tips dampened with bottled or distilled water (wring out excess water). On each section, you wipe away from the nozzles. Then wipe off the inside of the print head carriage (contacts) as well. Dry everything with a dry cloth and reassemble the printer.)
If the Check paper light is blinking check for a paper jam or the printer looking for a different paper size.
I hope this helps.
Oct 06, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Toner cartridege
make sure that use only the HP genuine cartridges. If u uses the refillled cartridges it will damage your printer.
May 07, 2010 | HP PSC 1315 All-In-One InkJet Printer
Will not print. color ink cartridge light keeps
..."Open the ink supply andgently move the ink cartridges to the left. Then reach in to the rightside and you'll find a small (1/2 x 1 inch) sponge. Push it down andoff/on the machine. try it now. or ...go to where I found out more than I should know about Canon's and where I got my quote...http://www.fixyourownprinter.com/forums/inkjet/39177 good luck.
Oct 21, 2009 | Canon PIXMA MP240 All-In-One InkJet...
Printer mechnical error
Resolving a blinking light When an error occurs, the power light will blink continuously and an error message will appear on the computer screen. Read the onscreen error message explaining the problem and follow its solution. If no error message appears, go to the Maintenance section in the Printer Assistant and click any of the four main buttons. This will prompt the software to check the status of the printer and the error message should then appear. The following table lists possible causes and what to do to correct the problem. Symptom Possible cause What to do to correct the problem Power light is blinking Printer cover is open Close the cover. Printer is out of paper Insert appropriate media in the In tray. Printer has difficulty picking up label media
  • Change the printers print mode setting.
  • Change the printer's paper type selection.
  • Use a different brand of label media.
There is a paper jam Follow each of these steps until the problem is resolved:
  1. Remove the paper from both paper trays.
  2. Press the Power button once. Wait a moment for the paper jam to clear.
  3. If printing labels, verify that a label did not become detached while passing through the printer. If the paper jam was not resolved, continue on to the next steps.
  4. Remove the rear access door.
  5. Remove the paper jam through the opening at the back of the printer.
  6. Replace the rear access door.
  7. Reload the paper into the paper In tray.
  8. Print the document.
There is a problem with a print cartridge Follow each of these steps until the problem is resolved:
  1. Remove and then reinsert the print cartridge(s) into the printer.
  2. Clean the print cartridges automatically using the Clean Cartridges option in the Printer Assistant.
  3. Manually clean the print cartridges and print cartridge cradles:
    • Open the printer cover and wait until the carriage moves to the center.
    • Press the Power button to turn off the printer.
    • Disconnect power cord from the back of the printer.
    • Remove the print cartridges and place them on a piece of paper with the nozzle plate facing up.
    • Lightly moisten a cotton swab with distilled water.
    • Clean the face and edges of the print cartridges with the swab. Do not touch the print cartridge ink nozzles or copper contacts.
    • Wipe the underside of the print cartridge cradle walls using a clean, moistened swab.
    • Reinsert the print cartridges.
    • Close the printer cover.
    • Connect the power cord to the back of the printer.
    • Press the Power button to turn on the printer.
  4. Calibrate the print cartridges.
  5. If the light is still flashing, replace the print cartridges.
Power light is blinking and/or there are missing lines or banding issues on the printout The print cartridge has partial loss of electrical interface with the carriage connections
  1. Print a printer self-test by holding the power button down with a pencil and opening and closing the top cover four times.
  2. Check the nozzle self-test pattern in the self-test print out. If one or more of the solid rectangular areas are missing, an electrical contact problem may be present.
  3. Remove and then reinsert the print cartridge(s) into the printer.
  4. Print the document.
  5. If the problem persists, follow the steps listed above for cleaning the print cartridges and print cartridge cradle.
  6. Try printing again. If the problem continues, replace the print cartridges.
Sep 10, 2009 | HP DeskJet 3650 InkJet Printer
Error 50 c
  1. Power off your printer.
  2. Use both hands to lift up the scanner unit until the scanner support holds it open.
  3. Turn the printer on. The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
  4. Remove the color print cartridge.
  5. Lower the scanner unit until it is completely closed.
  6. If the error message reappears, replace the black print cartridge with a new print cartridge.
    If it does not repeat steps 1-3 and then go to step 7.
  7. Reinstall the color cartridge and remove the black print cartridge.
  8. Lower the scanner unit until it is completely closed.
  9. If the error message occurs again, replace the color cartridge.
  10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
Hope this helps.
  1. Lower the scanner unit until it is completely closed.
  2. If you receive the error message again, replace both cartridges.
Jul 29, 2009 | Lexmark X6170 All-In-One InkJet Printer
I have a ML-2510, I turned it on and both the red light and green light flash constantly. Will not feed or print.
The green light blinking means that it is accepting or printing data.
But, the red light is for the error messages. This blinking means there is a toner problem. 1. remove toner cartridge from printer and gently shake to redistribute any that is left, or
2. You simply have to replace the toner cartridge with a new one - this one has been exhausted.
Jul 09, 2009 | Samsung ML-2510 Laser Printer
Printer light blinking
Customer Support SUPPORT"; //--> print.jpg Print | email.jpg Email | --> pagelink.jpg Link null.gif KnowledgeBase 433-75x75.gif Product
Product
--> Lexmark Z615 Country / Region:
Country / Region:
--> United States Language:
--> Language:
English Need to download
a driver?
--> Save my information--> Lights Flashing on the Lexmark Z815/ Z816 Color Jetprinter ID: ENUS17112 This document does not apply directly to your Lexmark Z615
  1. First count the number of times the light on the front of your printer flashes.
  2. Then refer to the table below for information about the error condition and recommended recovery procedures.
    Number of Flashes Error Condition Error Recovery 2 Carrier Stall:
    The movement of the print cartridge carrier has been obstructed. Remove any objects blocking the carrier path.
    4 Print Incomplete:
    The print cartridge carrier stopped in the middle of a print job due to obstruction. Remove any objects blocking the carrier path.
    12 Cartridge Short:
    The printer has detected a short circuit in a cartridge.
    1. Turn the printer off.
    2. Open the front cover.
    3. Turn the printer back on.
    4. Remove the color cartridge.
    5. Close the cover. If there are no flashing lights, the color cartridge is short-circuited.
    6. Remove the black cartridge and then reinsert the color cartridge.
    7. If there is no error indicated by flashing lights, the black cartridge is short-circuited.
    8. If you continue to receive an error indicated by flashing lights, both cartridges are short-circuited.
Apr 22, 2009 | Lexmark Z640 InkJet Printer
Power and error botton blinking epson cx 2900
Could be ink cartridge no contact, or it is dirty. Or if you try to print and this printer that flag a message " end of service life......parts." . You should reset it counter using third party software. In kinda connection with ink pad.
Apr 18, 2009 | Epson Office Equipment & Supplies
Toner end life
it is printing with this blinking or not?
Jan 04, 2008 | Samsung ML-2510 Laser Printer
HP PSC 1315 All-In-One InkJet Printer Logo
114 people viewed this question
Seeker5211
Seeker5211
