Question about ASUS PSU | A-45GA 450W RT (A45GA) Power Supply
Suddenly power failure ,when the power returning the pc switched ON the SMPS fan and PC also not working.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 71 Answers
My advise to you is to never turn of your computer!
the constant start and stop put stress on your power supply not to mention dust build up and if not properly cleaned the startup process can cause a short which I've seen so many times.
I have a computer which is 8 years old I never wanted to turn it off but leaving for two weeks vacation I turn it off. On my return the startup it shorted yeah dust build up.I had to replace the power supply, still running now. (A warm drive is a happy drive)
Posted on May 28, 2014
2 Suggested Answers
pravinbhavsa
  • 348 Answers
SOURCE: PC smps power supply problem
ok you open the pcb check the fuse first then replace it if faulty if it burns again then check 4 diodes then see if 200v big capacitor is expanded or not if so then replace it if not then check diodes after transformer if short then replace it
Posted on Nov 21, 2008
I have Sony VGC-RB30 and after power failure it is don't start at all, I can heat clicking and green button at back is flicking, what should I do?
first you have to remove the 24 pin conncter to your motherboard from the smps and short the green and black pin and see wether the smps is working if not working change them if working remove the the four pin conector to the motherboard from the smps and switch on the computer if the processor fan is working connect back the 4 pin connector to your motherboard and switch on the computer if not working the power section in the mother board has failure you can get assistance from a chiplevel service personal
Mar 27, 2011 | Sony VAIO® VGC-RC310G PC Desktop
When i on my pc hp dc7100 it is red light blinking please solve my problem.
first remove the cover of your computer after switching off the system and removing the power plug the power the system and see whether the processor fan is working if not power off the system and remove the 24 pin connector from the smps to the motherboard and short the green and black pin of the conector from the smps and see the smps fan is working if not replace the smps if working then remove the memory from the slot and clean them or change the memory to which match the dimm slot an connect the connector and switch on the computer
Feb 27, 2011 | HP Compaq dc7100 Ultra-slim PC Desktop
I trun the pc on and nothing happens
Feb 26, 2011 | Acer Aspire™ T180 PC Desktop
Hi my hp pavilion laptop DV5000 on start up has black screen and one long beep then 3 shot beeps then one long beep and another 3 short beeps. The lights stay on but nothing happens. The pc has been...
Feb 26, 2011 | HP Pavilion M9040N Elite Desktop PC
Sir i am using asus motherboard(ASUS M2N68-AM SE2) in my pc, when i switch on my pc the processor fan and smps fan is rotating for few seconds(4 to 6 Seconds) and it stopped rotating. 1. the monitor shows...
remove all the ram from motherboard and switch on the system and see it is working or not like just on and fan are rotating and the smps fan is also working and your system is giving beep sound for ram.try with other smps also some time problem with power supply also. Remove the connector of power switch and restart switch and directly try to on from shorting the connector with the help of pen or screw driver point. Some time faulty switch also give problem. Just try all these possibilities.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Jan 03, 2011 | ASUS M2N68-AM SE2 Motherboard
Switched it off last night. this morning no power. won't switch on. not lead have tested. thanks
Verify whether the SMPS fan is working or not, working of this fan indicates that power output +12V is OK, if not you need to check the SMPS, probable reason SMPS fuse blown.
If you observe SMPS fan rotates for few seconds and then stops, this indicates minor repair is required, let me know the symptoms.
Oct 09, 2009 | Acer Power S290-EC3600P PC Desktop
SMPS problem?
the problem is with yur smps i think.yur turn on button is directly connected with the smps i think.if the smps fails to run yur system will hang.please wipe and dust yur smps completely and see if the system is working.. or else you should change yur SMPS..
Jul 05, 2009 | Gateway GT5428 PC Desktop
Computer power problem
For solving your problem do the following:
1. Check that the power cable is connected properly to the monitor
2. See that the SMPS of the CPU is working
3. Check that the power output from the SMPS is upot 12V
If not change the SMPS it may be due to failure of SMPS.
Let me know if your problem is solved and rate me as FIXYA!
May 13, 2008 | Compaq Presario 5000 PC Desktop
Dot station 2300 does't start
if your smps working properly in another pc your motherboard is faulty. you have repair it. but beofre this you should chek power cable or your power point.
Dec 27, 2007 | HP Compaq Presario SR1720NX (EL435AA) PC...
Computers & Internet Logo
57 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
