Question about Transcend 4GB JetFlash 110 USB 2.0 Flash Drive (TS4GJF110) Media
My 4giga writes 0 byte and asks me d' to insert a disc in E
  • 44 Answers
SaveMyUsb.com can recover data from most damaged faulty and corrupt flash memory devices including memory cards and usb flash drives for just £39 - give them a try it worked for me!
Posted on Jan 01, 2011
I Have WD 500 GB hard disc, suddenly un-detected and become 0 bytes!!
Very comm in with wd drives. You need repair the firm ware and it may start working for about 10-15 days.The fw repair has to be done by a data recovery expert.
Aug 20, 2017 | Western Digital My Book Essential Edition...
I just purchased a verbatim dvd-r 4.7 gb yesterday,when i`m about to use it the properties says that it as 0 bytes...am i being fooled here??
No, that's exactly correct; until you write a filesystem (with data, since a DVD-R gives you one shot unless you manage deferred finalizing) there are 0 bytes and 0 filesystems for them to occupy there. Media info in the writer might let you know it's an unwritten disk with 4.7GB capacity, but it depends on what you use. Just don't try to write 4.8 GB and expect 90% success; if it doesn't fit, OS tend to call it a bad disc rather than attempt forensic recovery.
Sep 10, 2011 | Computers & Internet
Burn fail or cd skip
Kind of sounds that way. They are pretty inexpensive now days, and simple to install.
Good luck
Mar 17, 2009 | Gateway M680X PC Notebook
Pen Drive is Not able to write the data
i had purchased a pen drive of Moser Baer AZ-601USB device. previously it was working good, but since last 3 days i could not open my pen drive..it asks for formattin. i have formatted it , but after that it says your pen drive is write protected. so i could not open and use my pen drive....
so plz solve my problem to open my pen drive.
Dec 20, 2008 | Electronics - Others
Pioneer bus cable wiring
You asked for it...
..it's a little complicated.
The pioneer IP bus uses a 2 wire differential signal for communication.
An equal level on both lines is a logical low while a high is encoded as a voltage difference of some 100mV.
I think a CANbus tranceiver should work here.
The data transfer is initiated by either the cd changer or the radio.The initiator generates a high pulse ( ca. 170us ) and a following low pulse ( ca 20us ).
Then the data transfer starts, a 1 is encoded as a high-low sequence with a duration of ap. 20us for both levels and a 0 consists of a 33us high and a 7us low pulse.
The data is now transfered in bytes with MSB first, the 8th bit is an odd parity bit.At the end of the 3rd and all following Bytes there is an additional bit inserted after the parity where the receiver acknowledges the transfer.
This is done by holding the data lines in a high state after the initiator sets them low.If this ack is missing the transfer is stopped.
The timings may vary because the real data is encoded in the pulse to space length relation.
The first 3Bytes seem to be some kind of device address.The changer I used transfered a 0x88,0x68,0x00 here while the radio sended 0x88,0x08,0x06.
The next 4 bits were always high. After that a size byte and then size bytes were transfered. The last byte in the transfer is a checksum generated adding the values of all data beginning with the 4bit sequence ( = 0x0F ).
In the following part I only will write the raw data excluding size and cheksum field.
Each command transfered was first answered by some acknowledge packet consisting of a single 0xA1.
(which looks like: 0x88 0x08 0x06 0xF 0x02 0xA1 0xB2 -> 0xB0 is the checksum ).
For now I just figured out some very basic things like the fields where time, track and disc number are encoded and also some
key codes the radio sends. There are many more fields in the packets where i still don't know the meaning of.
(I just got the radio from a friend for some days and so I couldn't do so much more on it ... however .. if somebody is intrested in some
more information and is wiling giving me a radio and a changer for some weeks I'll try to do some more .... )
I have also designed a small circuit using a AT90S2313 controller which can be used for logging the transfer through the pc serial port and also
to send commands.
The following packet sended by the changer contained the time disc and track information.
Byte 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 Info command modus mcd disc min sec track cdt Data 0x61 0x10 0x06 0x01 0x20 0x04 0x16 0x01 0x06 0x01 0x00 0x00 0x01 0x00 0x3F 0x00 0x00 0x00 0xC0 0x48 modus:
Value 0x02 0x07 0x08 0x10 0x11 0x13 0x14 0x15 0x16 Info ready track blink pause ready and disc blink disc blink load and disc blink eject and disc blink load eject cdt: bit0: (1:cdtext),(0:normal)
The text information was encoded within this packet
Byte 0 1 2 3 4 5 6 7 8 9 10 11 12 13-22 Info command modus disc track text seqence number text Data 0x61 0x10 0x06 0x01 0x20 0x04 0x38 0x09 0x00 0x06 0x00 0x00 0x00 0x00
Recommend link: Vitaliy's Page @ http://www.vitat.spb.ru/ with IP bus interface on AVR basis and more IP bus informations
Some transfer log files are available.
Jul 20, 2008 | Car Audio & Video
Facing problem with my dvd writer
Can I have more detail like the model of your laptop. I really wanted to check that it is a DVD writer or not.Second it can be that that it doesn't support the type of DVD+R or DVD-R you're trying to use.But first check out that your model support writting to DVD or not.
takecare.
Apr 16, 2008 | Acer Aspire 5500 5570-2609 Laptop
E drive - D drive not reading blank discs
i'm assuming your drives are dvd compatible? Got the right drivers for them?
check here for that
Mar 09, 2008 | Dell Dimension 4600 PC Desktop
YAMAHA CRW8424 gives Track following error..
PROBLEM DEFINITION: Basically, it is a hardware error that occurs when a drive is not capable of following a data track on a CD-R or CDRW or on the other hand, poor power flow may cause the problem SOLUTION: 1. Try use another disc, a disc with a different band. 2. If one doesn't work, you may have to open your system and use a different power connector, making sure no other devices are using the power connector in the same strand. 3. Lastly, if neither the above doesn't work, you may have to send your drive in for servicing as the head may be dirty or misaligned.
Aug 05, 2007 | Yamaha CRW 8424 Burner
Electronics - Others Logo
42 people viewed this question
Top Transcend Electronics - Others Experts
Alun Cox
Are you a Transcend Electronics - Other Expert? Answer questions, earn points and help others
