Question about Frigidaire PLD2855RFC Dishwasher
We just bought a house with a unit that was never used. We plugged it in and the unit appears to not be receiving current as there are no lights or display on the front panel. The outlet is functioning with GFI. What else should we check?
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
As a rule, dishwasher's are wired direct into the power, and are not plugged in.
2nd GFI's are not good for dishwasher's the motors like to trip them.
you can remove the lower panel and check the power, to the right. If you have the proper tools.
If you have power at the connection, under the machine, then you must have a defective control board.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Posted on Dec 30, 2010
Bought a denon ceol n8 , now when I turn it on it says updating, then update failed
I had the same problem.
Confirm that the receiver is linked by wire (I think that's best than Wireless) and reset the microprocessor (page 49 of the manual: Unplug the power; than, plug the power while pressing Volume UP and DOWN on the main unit; when the power indicator lights white, release the buttons - "Initialized" appears on the screen). When Quick Set up appears, run it to connect to the Network. After the network is connected, upgrade the firmware (see page 14 of the manual for that).
That worked fine for me.
Dec 01, 2012 | Audio Players & Recorders
Tom not working red light when plugged in
Contact me at: dworakowski.lukasz@gmail.com
Nov 04, 2011 | Tomtom XL 350 GPS Receiver
Onkyo receiver TX SR 605 saying no signal input from cable when everything appears to be plugged in correctly and powered on and it was working 10 minutes ago. All other connetions (Apple TV, dvd player)...
Hello, I am sorry about your issue. Please plug the cable box into a known good HDMI port on the receiver. Confirm that there are no issues with the cable or plugs. Thank you, CB
May 30, 2017 | Onkyo TX-SR605 Receiver
Line fuse rating?
usually fuses have voltage and current ratings mark on them you just have to look for it or sometimes near the fuse housing.or you can use the formula power consumption of the unit divided by the voltage rating of the unit. I (amp) = Power(watts) divided by Voltage(110V) X power factor(PF). use 0.866 for PF
Feb 02, 2010 | KLH Audio Players & Recorders
Charging doesn't display map when charging
I learned that with the unit off - hold the on button down - don't release it. A PRE-BOOT MODE message will appear at the bottom and may flash. Continue holding down the start button. The first time I did it a series of dots came on the screen and I was instructed to touch each one. After that it started as normal. I plugged into a wall charger and but git the pc and nuvi icons again. I repeated the process - holding the on button on and let the PRE-BOOT MODE appear and kept holding but this time a different message came on and then the PRE-BOOT MODE appeared again. I let it go and took the unit to my car and plugged it into the Garmin car charger and it worked as it used to - normal. However, when I plugged it back in the house to the wall charged I got the pc and nuvi icon again. It appears that I am using the wrong wall charger as a previous writes stated. But the nuvi still worked in the car plugged into the nuvi charger. I hope this helps.
Jan 24, 2009 | Garmin Nuvi 660 GPS Receiver
Astar ltv-1701
It sounds like your power source module is defective. I suggest you try to replace it from one your might find at a second hand store. Look on the back side of the power source device. It should list the output voltage (usually DC or direct current as opposed to AC or alternating current) and also lists the current in amps that it produces. Also inspect the connector to your TV so you can try to match the connector when you buy a replacement. Armed with that information (output voltage and current ability from the power source) pick through the modules you find at a second hand store. Make sure the voltage exactly matches. You can also purchase a power module which can produce more amps of current, but never less. If you are successful in finding a match, buy it - but you may need to cut off the old connector and some of the wire that plugged into your tv so that you can reuse the connector on the used unit you just bought. You will need to splice the old wires from the tv connector to the wires coming out of the used power unit. Assuming the connector on the used unit you purchased did not match your tv connector, you will also need to cut off the connector and splice the tv connector to the wires coming out of the used power unit you just bought. If this is too complicated, go to the manufacturer and try to buy a replacement or look at other places like eBay for a matching power unit to the original TV unit.
There is a possibility your TV itself has a short and is defective, although from you comments I think it is more likely you power source unit.
Jan 23, 2018 | Astar LTV-1701 Television
Error screen trouble shooting
If you have the USB cable and a dvd/cd that contains the software/maps, then it needs to be loaded. Install the software on your computer. With the unit off, plug it into USB, then turn on unit. run program installed from dvd/cd. you can also try resetting the unit by holding down the Menu and Nav key, hopefully a small box appears and you can use the stiff stick to change the numbers. if this does appear, change the numbers to read 32 then press the stiff stick in (pressing enter). _Daniel
Apr 13, 2007 | Magellan eXplorist 200 GPS Receiver
Frigidaire PLD2855RFC Dishwasher Logo
129 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
