Question about Car Audio & Video
The front panel on my farenheit car stereo wont respond while pressing...to operate i have to use te touchscreen..then suddenly it too went blank
5 Suggested Answers
SOURCE: Fuse number for stereo and front drivers panel
Based on AutoZone.com repair manual section, it looks like if the car has premium sound the fuse is #18, and if you don't the fuses are #32 and 34. More details can be found here:
http://www.autozone.com/shopping/repairGuide.htm
Select the year, make, model, and engine size of your car; then select Wiring Diagrams and then Audio System.
Posted on Jul 16, 2008
SOURCE: Touchscreen
U have to:
eject any cd from unit
press and hold eject button then press resey key (small pin above the right nob)
Hold down eject until screen goes in and back out.
then it will ask you to press reset do not
on right nob pres up up down down center
it will take you to the cal screens
caution do not do anything else other than
enter the touchscreen calibration and perform steps 1-4
this units touchscreen does have tricky set points gl
Posted on Oct 16, 2008
JCLeftie
  • 4 Answers
SOURCE: my zen suddenly went blank!
Your device lockup isn't uncommon, and in most cases is easy to fix. You need a small paperclip or straight pin to reset the device. When you reset, be sure to hold it in and wait for the blue light to turn off. Once you power the unit back on, it will rebuild and should operate as normal.
Posted on Dec 28, 2008
danoyachtcap
  • 2907 Answers
SOURCE: control panel on Range Rover 2006 wash car yesterday windows went up and down this morning driver side passenger side front does not operate but rear windows work off control panel. Could the front be
Some people pour warm water on the door top to thaw it out.
Hope this helps.
Posted on Feb 25, 2015
I was setting up bluetooth when suddenly the screen went blank and it wont start
Check with your manual to see if there is a radio reset code that needs to be entered to restore operation. Also check with the dealer to cover all bases.
Aug 28, 2015 | Lexus RX 400h Cars & Trucks
I have a DP video car stereo on my 1999 corolla. The volume knob suddenly didnt respond when I turned it but The press down function works, switching to bass, treble etc but I cant change those settings...
Sometimes multifunction controls fail because the button cannot be fully depressed. This is caused by shaft slippage inside the knob. The bottom of the shaft cavity in the knob can be shimmed to restore proper operation.
Oct 31, 2013 | Car Audio & Video
Bush 24 inch tv/dvd combi screen went blank as if it's on standby. won't respond to remote control. one week old. is it seroius?
try switching on tv point remote at the tv pressing the menu/exit button and holding for 10/20 seconds hope this works for you
Oct 07, 2012 | Bush Industries IDLCD26TV16HD LCD TV
Brother mfc-6490cw lcd screen shows no display (just the backlight is on)
Procedure1: Changing the LCD Contrast setting
  1. Press Menu.
  2. Press the Up or Down Arrow key to choose General Setup.
  3. Press OK. (For touchscreen models, skip this step.)
  4. Press the Up or Down Arrow key to choose LCD Settings.
  5. Press OK. (For touchscreen models, skip this step.)
  6. Choose LCD Contrast and then choose Light, Med, or Dark.
  7. Press OK. (For touchscreen models, skip this step.)
  8. Press Stop/Exit.
Procedure 2: Changing the Backlight Brightness setting
(This option may not appear depending on the model of your Brother machine.)
  1. Press Menu.
  6. Choose Backlight.
  7. Do one of the following (The menu varies on your model.):
    • Choose Light, Med, or Dark.
    • Press the Left Arrow key to make the backlight darker or press the Right Arrow key to make the backlight lighter.
  8. Press OK. (For touch screen models, skip this step.)
  9. Press Stop/Exit.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
May 28, 2011 | Brother MFC 6490CW InkJet Printer
Ipod screen went blank when watching bbc iplayer and wont turn back on have tried chargeing but wont respond
there is a ipod reset you can do, that might sort the problem. you will lose all data on the unit. there are different sires of buttons for each model. reset can be found on apple site.
Jan 12, 2011 | Computers & Internet
I had a cracked screen but everything was fine i had no problems what so ever with the itouch i went to take it in and got a brand new screen but when i try to touch the screen it wont respond to me it...
That means you have a bad digitizer. When the screen was changed so was your digitizer which is a part of the touchscreen on the back. When your glass was changed so was the digitizer which is attached to it. You a new touchscreen...
Oct 16, 2010 | Apple iPod touch
My zen suddenly went blank!
Dec 25, 2008 | Creative Labs Zen Digital Media Player
Wash temperature scale
TEMPERATURE - CELSIUS OR FARENHEIT
If you want to change the temperature indication from Celsius (C) to Farenheit (F), proceed as follows:
Turn the main switch, off and turn it on again. Press the Enter button five times, then press the P2 button five times. These ten times must be completed within fifteen seconds. Within three seconds after pressing P2 the last time, use the < > buttons to select temperature indication.
Sep 22, 2008 | Asko W640
Car Audio & Video Logo
18 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
