Beko wm5100.water not emptying from drum - Washing Machines
  • Washing Mach... Master
  • 1,527 Answers
Hello. it sound like the pump is blocked or not energizing also check for kint drain hose hope it helps
regards
shaun
Posted on Dec 30, 2010
My beko washer is only six months old its washed all day. On last load it has started to make a loud metalic noise while emptying and spin its like something is stuck but filter empty
Is it out of warranty?? It sounds like the washer drum bearing failed. Do you use approved super low suds detergent? You can not use regular detergent it will corrode the drum bearing.
Jun 01, 2016 | Beko Washing Machines
Beko dryer
i have had this problem and its usually the pc board is faulty
Mar 28, 2014 | Dryers
I have a beko wm5100 washing machine and the pump impeller has come off Ive tried glueing it but to no avail is there anything else that I can do
Robert! Am I to understand that you...Never Mind! My Friend come over here I want to tell you a secret. Glue-Water-Pressure! They NEVER work! If it is an impeller it is probably a pump. most washers have two 1) Drain Pump (impeller) and circulating Pump-impeller. You need to REPLACE either or both the entire Pump, install it. Then use/store the glue to build Model Airplanes...Not on Washers?!
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
Mar 15, 2014 | Washing Machines
Beko wm5100 w won't agitate but is filling and empting
A week ago I had similar problem with beko wm3552m model (~ 10 years old). In may case was enough to replace the carbon brushes of the engine. It took me some time to figure out where they are locates, so I put some pictures on the net:
how to replace carbon brushes beko washing machine wm3552m
Jan 26, 2014 | Washing Machines
I have purchased a second-hand BEKO WM5100 instruction manual - can you supply one,
log on 2 the website of the manufacturer 2 download it 4rm there
Jul 06, 2011 | Washing Machines
My WM5100 BEKO is not pumping excess water out and is not completing cycles
sounds like you have something caught in the drain pump remove the panels and inspect the pump to see if you have something caught in the pump
Aug 15, 2010 | Washing Machines
Drum does a small turn then stops but wont empty -wont wash either beko 1000 rpm
Hi if your beko 1000 spin washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor
Aug 23, 2009 | Washing Machines
Beko washing machine wont drain or spin water stays in drum
the pump itself could be blocked or broken check inside pump first for any obstructions
Jul 01, 2009 | Washing Machines
Washing Machines Logo
137 people viewed this question
Top Washing Machines Experts
