Question about Canon imageRUNNER 5000 Copier
Sir Canon ir600 copier Problem TCP/IP) Printer hard disk software croput) I want ps/pcl driver for printer harddisk dirver & how can install Please solve my problem....
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 183 Answers
Canon is big mistake use ricoh
Posted on Jan 01, 2011
2 Suggested Answers
muntejaya
  • 10421 Answers
SOURCE: Sir Canon ir600 copier Problem TCP/IP) Printer
Hi, please get new driver here: www.driversdown.com/
www.nodevice.com/driver/company/Canon/Printer.html
www.usa.canon.com/cusa/office/products/.../hs_1200ts
Jay pnecy
Posted on Feb 12, 2011
Hi there My computer crashed and have it up an running again. I am a complete newbie and dont now how to get my Ricoh Aficio AP 400N printer to work again. I went to the ricoh site and downloaded (I...
Please download RPSC driver for needed OS version and then try find do you install the printer on correct printer port (USB or TCP/IP port)
pifonski
Feb 20, 2011 | Ricoh Aficio AP410 Laser Printer
I WANT TO BE ABLE TO PRINT FROM MY COMPUTER TO MY PRINTER
  1. Either set a static IP for the printer or attach your computer directly using USB.
  2. Setup the printer on your computer using the driver for the printer. If the printer has Postscript capabilities the PS driver is better than the PCL driver.
  3. If the printer is USB setup like any other printer, if the printer is IP then specify a local port in the Wizard and type the IP.
  4. Choose the driver and install
  5. Afterwards go under properties and select the printer components such as duplexer, extra trays, etc.
May 03, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
I HAVE ONE IRC 3200 AND I DONT KNOW WHAT DRIVER INSTALL FOR SCAN AND PRINT, I HAVE WIN XP
Go to http://www.usa.canon.com
Select Downloads
Select Office/Production
On next page from the dropdown select Office/Production products again
Next page Select Networked Office Systems/Copiers
Next Page select Color ImageRunner Series
Next Page Select Color ImageRunner Series
From List select Color Image Runner Irc-3200
From the choices select the driver needed. PCL or PS (postscript)
Select either Setup or INF.
If Setup or INF file. Download the zipped file. Create a folder on desktop or downloads. Call it Canon Copier or whatever. Download the zipped file to this folder. Go to the folder you downloaded the zipped file to and double click on the file. When Win-Zip started and asks where you want the file un-zipped to enter a period (.) this will unzip the file to the folder you created.
Once the file is un-zipped if you downloaded the setup file run setup exe.
At somepoint in the setup process you will be asked which port you want to use. You will need the IP Address of the copier ( which can be obtained by pressing the additional Functions key on the copier, selecting report settings, selecting Network and print report. If the IP address needs to changed select additional functions again, Select System settings Key, Network settings key, TCP/IP settings, Check or Set IP Address here or select DHCP to get new address. Repower the copier if any changes are made.
At the which port to use select New Port, select Standard TCP/IP port and create new port. Enter IP address in the new port window.
If using INF file after INF is unzipped. Go to Printers folder and select create New Printer. Follow Printer Wizard. Create New Standard TCP/IP port. When the Wizard Asks for Driver, select have Disk and browse to the folder you created and click the unzipped file and continue clicking until the file installs.
Mar 20, 2010 | Canon imageRUNNER C3200 Copier
Can not print printer only prints test page
you have the wrong print driver installed (either wrong model or wrong OS) also check if there is a PCL or PS print driver and printer port is correct (USB, tcp/ip, Serial)
Aug 04, 2009 | HP LaserJet 1012 Printer
Ir400 copier HDD fomat and sytem softwear update Problem
it's formatting possible in few city only in india like MUMBAI - DELHI - INDORE etc. because it's not a common or general format process. Try nearest used copier dealer.
Jun 14, 2009 | Canon imageRUNNER 400S Copier
My ir3300 xerox machine not print out.please solve thins problem.
How are you trying to print? You need N boot rom. Press Counter Check. Do you see IR3300(IR2200N) or IR3300(IR2200). If you see the N then you should be able to print with it. If not, you can't.
In Service Mode (to get into this press Additional Functions (button with * on it) > 2 then 8 > Additional Functions) go to Copier > Display > Version. What do you see for BOOT-ROM (does it have a N at the end?). For PS/PCL what do you see?
If your BOOT-ROM is N and you don't have a number for PS/PCL then call a technician to install networked system software.
If BOOT-ROM is not N, buy a Network Multi-PDL Kit C1 and get a technician to install it and load N system software.
If BOOT-ROM is N and you have number for PS/PCL check your IP settings. Make sure that DHCP is turned off. Set up your printer using an IP port with the static IP address assigned to the copier.
Use PCL5e or PS drivers, don't use PCL6.
Jan 23, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Canon imageRUNNER 5000 Copier Logo
222 people viewed this question
old marine
old marine
