Question about GE PFS22MIS
I have had this problem once already with my GE Profile PFS22MIS fridge. It would not cool at all in the freezer or fridge section and they replaced the circuit board and it worked great for a few days. But now, only 3 weeks later, it is acting up again. It is running really fast constantly and the freezer will not get above -10 degrees (0 is recommended) and the fridge will stay around 37 which is fine. But now the freezer is still around -10 and the fridge will not get below 50.
  • 1 more comment
  • Jason Green Dec 30, 2010
    I am confused. You say that if the wires are not touching it is open but then say that I need a meter to test it. Where do I find instructions on removing the panel because I have no idea where that panel is or what I need to remove and check.
    Where is the evaporator assembly located? It does not show that in the diagram, it only has it out front. Is it in the freezer, behind the fridge, etc? Do I need to remove the evaporator assembly from the fridge so I can get to the thermostat?
    But how do I get to that panel? Do I have to remove the freezer door and drawers and kill the power to the fridge? It is almost impossible for me to get to. I don't even see the screws that hold that panel together.
  • GE Master
  • 5,370 Answers
If the temperature is not getting set to its required settings then it can be due to faulty thermostat.Check if the thermostat is open. That thermostat is clamped to the evaporator ,and the contacts inside the thermostat are suppose to be touching each other to allow the current to flow to the defrost heater, so if they don't touch thats what we call open. You can check that part with a meter to see if it is open.Its a round part with two wires to it. once the freezer panel is off you will see it.You need to remove few screws to remove the panel to remove the thermostat.As per the problem,which you have indicated,its Thermostat.replacing the thermostat should solve the problem. --------------- Its a $13 part.TO get this part or to see this part.Please click on the link below:--- http://www.partselect.com/PartDetail.aspx?Inventory=1155318&SourceCode=5&ModelNum=pfss5njw ---------------- This should help.Thanks.Helpmech.
Posted on Dec 30, 2010
  • 1 more comment
  • raj somaiya Dec 30, 2010
    Dont get confused.
    I will explain:--First see this fig of thermostat
    In this thermostat there are two wires.One is orange and one is pink.If this wires get loose or if this wires are got burnt then the meter will show open circuit.In this case the thermostat has to be replaced.
    For location on thermostat i have disassembly diagrams for you.It will help you exactly how and where it is located.
    The thermostat is located on the side of evaporator assembly.Beside the heater assembly.
    Check this link by clicking on it.
    Part number 621 is thermostat.Part number 826 is defrost heater.Part number 228 is evaporator assembly and part number 241 is temperature sensor.
    Click on this link and see the diagram:---
    this should help.Thanks.Helpmech.
    The evaporator and fan are behind the rear panel inside the freezer usually held in by a few screws up the sides. The evaporator coil behind the cover on the back wall inside the freezer .
    The defrost thermostat is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.--------------This should help.Thanks.Helpmech.
    The evaporator coils are in the inner side of freezer panel.See any thing like white rubber butches above the screws.Some times screws are hidden under white rubber butches.just remove that white rubber by thin knife.
    ---------------------This should help.Thanks.Helpmech.
    Keep updated.
Ge tfg27pfxa profile with cooling problem
Remove the back panel in the freezer to see if the defrost heater is running continually.
Nov 06, 2012 | GE Refrigerators
GE Profile refrigerator Model PFS22SISBSS is not cooling, the digital temp control is at 74 when I try to lower it will go to 34 then immediately back to 74. The fan and freezer are both working. A repair...
The problem is damper assembly.In the damper assembly there is a door.This door opens and close with the help of motor.The damper is located between freezer and fridge section.The cold air from freezer section enters to fridge section via this damper door.---------- What repairmen did was proper, but may be that door is not properly got open, it got closed again.Or there is ice got collected between the freezer and freezer section, so this is not letting the cool air to pass from freezer to fridge.----------- ---------- This damper assembly needs to be replaced.Actually this door functions correctly with motor.He open the damper door manually and thought, the cool air will enter the fridge section non stop, but that door is again got closed, by some how.--------- You will have to get the damper assembly part replaced, to get the air flow work properly.------- As the repair man has already ordered the part, otherwise you can get this parts from online sites like www.repairclinic.com or from sears parts direct site.-------- Getting the damper door assembly, replaced will help.Thanks.Helpmech.
Sep 08, 2011 | GE Profile Stainless Bottom-Freezer...
I have a GE profile model # PFS22MBSAWW and about a year ago the digital display for the temperature reading would work intermittently. After some time I realized that when the condensor motor was on, the...
ou need to replace the main control board . in the back pt # wr55x10526 and you may also need the display pwb pt # wr55x10522 .. do the main board first and if diplay isn't working properly replace it also .. mm hope this helped .. feed back lps ..
Jul 10, 2011 | GE Profile Bottom-Freezer Refrigerator...
Refrigerator Noise
Most likely the fan is hitting some frost inside. Defrost the fridge by unplugging it for 24 hours and see if it helps.
GE refrigerator repair in orange county, ca
appliance repair orange county, ca
Feb 06, 2010 | GE Profile Bottom-Freezer Refrigerator...
Water build up on inside of fridge door of ge french door fridge
humid air in the house. any time you open the fridge, house air is sucked in. when you close it, the fridge cools the air and moisture from the warm air condenses on any cold surface. also check to see if there is a gap in the seal.
Aug 26, 2009 | GE Profile Bottom-Freezer Refrigerator...
Coil fan will not run.
Replace the master control circuit board on the rear of the fridge.
Jun 22, 2009 | GE Profile Bottom-Freezer Refrigerator...
GE Profile - Fridge Doesn't Cool But Freezer Works Fine
Had a similar problem with my Kenwood Fridge Freezer
If you're mechanically minded you could check if there's an opening and motorised flap (usually behind a cover) at the top of the fridge - Cold air from the freezer enters the fridge through this flap) The Sound you heard could have been the motor trying to open / close this flap. This flap can become frozen in the closed position - so cold air is unable to enter the fridge compartment) My fix was to thaw it with a hairdryer and reassemble. Another fix would be to empty the freezer and open the doors - it might take more than 24 hours but once completely defrosted if the flap is the issue it will have defrosted. Once plugged in again the door will open and cold air will start to flow into the fridge compartment. I had a quote for €195 for a call out / repair
I fixed it myself in an hour - Hope it works for you ...
Sep 20, 2017 | GE Profile PDS22MHR Bottom Freezer...
GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
Nov 13, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE PFS22MIS Logo
145 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
