Question about LG 42LC2D 42 in. LCD HDTV
My tv wont pick up ditital channels - LG 42LC2D 42 in. LCD HDTV
Cant pick up any channels on the kec tv in my chevy suburban
Please elaborate on the age of the tv. If it is an older tv it is analog, and wont pick up stations that are all digital.
Mar 19, 2014 | KEC Mobile Applications KEC Mobile Vision...
Tv wont pick up all cable channels
may be the tuner, a cable provider, these channels are not programmed or are not attached, lack of voltage on the tuner.
Sep 07, 2013 | Samsung Televison & Video
Why wont my casio tv 600 pick up eney channels
I HAVE THE SAME PROBLEM BUT LAST NIGHT I PLACED THE TV NEAR THE FREEVIEW BOX AND THE TV JUST PICKED UP THE SIGNAL.A DIGITAL CHANNEL AT THAT ASWELL.NEAR PERFECT IMAGE.I DONT KNOW HOW THIS COULD BE ADAPTED TO USE THE PORTABLE AWAY FROM OFF THE FREEVIEW BOX.ANY SUGGESTIONS?
Aug 18, 2012 | Casio Portable Hand Held Tv - Model...
Channel scan only finds 1 channel with basic cable setup on LG 42LD520
if you have a cable box just plug the cable box into a scart socket on the tv, switch the tv to the scart input and use the cable remote to change channel?Scanning for channels wont find anything because you are receiving the channels on a cable box. If you are refering to standard or digital tv signals and your not receiving any channels then either you are only scanning analogue tv and therefore wont pick up any digital tv channels, or your ariel is inadequate to receive an acceptable digital reception and will need to be upgraded. please state country you are in and what you are expecting to receive
Apr 13, 2011 | LG 42LC2D 42 in. LCD HDTV
My tv wont pick up any channels i have a 42 inch lg tv and its connected to the household antenna but wont pick up any channels i have tried other ariels and still have the same problem?
have you switch the broadcast to Air from Cable using the remote go to this and also let it scan for channels auto...hopefully this will do the trick
Jul 26, 2010 | LG DU-42PX12XC 42 in. Plasma HDTV
I have a polaroid hdtv model TLA-d1911c that wont get a local channel.I bought a new antenna and hooked it up but it still wont pick anything up.
You may be looking in the wrong place or have the wrong kind of antenna. With the digital conversion, TV channels shifted from the numbers they used before. In my area, the previous Channel 6 is now broadcasting in the UHF band.
It can be harder to adjust the antenna for a digital TV because it is either working well or totally off - no gradually decreasing "snow" as a clue.
It is possible your TV is not equipped to pick up digital TV. There are converters to translate digital TV to analog signals for older TV. They cost between $30 and $70 depending on features.
Oct 06, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
Can a digital tv and a analog dvd recorder be hooked up to a converter box using a spilter?
Not sure of your question.It's Apples n Oranges.The Digital TV does not need a Ditital converter box, the DVD if an older model does.The DVD recorder also needs a remote sensor and needs to learn how to switch channels if it was able to do so before.The issue is your DVR go to the Manufactures Website for more info.If you just want to record what you watch on the TV connect the TV Audio Video out to DVR IN.Good Luck
Sep 14, 2009 | Vizio VX32L Television
Sanyo TV
check with your cable company some channels are switching to digital already and if your tv is analog it wont pick them up. tell them you want a box and you wont have this problem. i know you ddont want to pay extra for the box but come febuary no box no tv so best get it overwith now sorry its sucks i know
Sep 21, 2008 | Sanyo Televison & Video
LG 42LC2D 42 in. LCD HDTV Logo
20 people viewed this question
Computer Repairing
Computer Repairing
