Question about Trilogy Alarm Lock T2 TRILOGY® Digital Locks DL2700
Morning, I have a narrow stile alarm lock. why would I have to move lever twice to get latch to retract after entering code from exterior, and getting green light. Thanks .
  • 963 Answers
This is the website for Alarm Lock, the manufacturer:
http://www.alarmlock.com
Contact them for technical support for your lock.
Posted on Nov 08, 2011
Exterior door stuck closed manually retract ****** remove knobs KWIKSET
You will probably need to replace the latch assembly. There is a small rivet that holds part of the latch together, and it also acts as a pivot point for a small piece that retracts the latch. If it gets bent, the latch won't retract fully, but you might be able to push it back and get the door open.
May 24, 2014 | Kwikset 740ll 3 Smt Lido Keyed Entry Lever...
I have to punch in the code twice to retract the bolt, new batteries installed, no change!
Be sure the bolt is able to move freely. After the first try, does the lock try to move the bolt?
If it behaves like the wrong code was entered, the keypad might be part of the problem.
Jun 29, 2011 | Weiser Lock POWERBOLT ELEC DEADBOLT
How to change entry code
First, remove the control cylinder with your "DF59" control key. The cylinder unscrews to remove. Next, turn the knob all the way to the right, and release it.
Step three: Enter the existing code
Step four: Using either the spanner wrench that came with the lock, or a medium-sized flat-tip screwdriver, reach into the hole the control cylinder came out of; and turn the cam inside, about 1/4 turn (as far as it will go), and then back.
Step five: Turn the knob as far as it goes, ONLY ONCE, then release it.
Step six: Enter your new code.
Step seven: Turn the knob (this time, it should retract the latch).
Test it by turning the knob again: The latch should not retract. Now enter your new code and it should retract the latch as you turn the knob. If so, you have successfully changed the code.
Dec 23, 2010 | Simplex Kaba Ilco Unican 1000 keyless...
How do I change the combination on my Unican 1000 keyless lock? thx john
The door must be open.
On models with the passage feature, make sure the passage feature is disengaged: turn knob or key should be in vertical position (A) (see figure 1).
1. Insert the DF-59 control key (B) into the combination change plug
assembly (
C) and unscrew the cylinder by turning the key
c
ounterclockwise. Remove the combination change plug to gain access to the combination change sleeve (see figure 1).
2. Turn the outside knob/lever once clockwise (all the way, until it stops) then release. The latch should not retract (see figure 4).
3. Enter the existing combination. On new installations, use the factory- set combination: depress 2 and 4 simultaneously, (release), then 3
(r
elease). You should feel a slight click as each button is depressed.
4. Insert the spanner wrench as shown in figure 2 to engage the combina- tion change sleeve (A). Gently turn the spanner wrench clockwise to the stop position (a slight click should be felt), then turn the spanner wrench counter-clockwise to the stop position (A) (see figure 3). Remove the spanner wrench.
5. Turn the outside knob/lever once clockwise all the way until it stops, then release. The latch should not retract (see figure 4).
6. Choose your new combination, write it down, then enter the new combination-depress buttons carefully (a slight click should be felt as each button is depressed).
Note: You can use one button or all five for a combination, but each button can only be used once. You can depress two or more buttons simultaneously as a step in the combination.
7. Turn the outside knob/lever clockwise once, all the way, until it stops, hold in position and make sure the latch is retracted (see figure 5).
R
elease the knob/lever.
Note: If your lock is opening on every turn of the knob or lever, except upon entering a code, this may be a ZERO CODE. Before attempting to remove the lock from the door, refer to the troubleshooting procedures outlined at bottom of this document for a zero code symptom/solution.
1000/L1000 Series FAQ
Changing the Code/Combination
hope this helps
and here is the link to the change code web site
http://www.locksonline.co.uk/files/pdf/Simplex_1000_CodeChange.pdf
good luck
please take the time to rank my advice
merry christmas
Dec 07, 2010 | Simplex Kaba Ilco Unican 1000 keyless...
Toyota G6 alarm keeps going off for no reason please help
just to let you know i had the same problem with my g6! it went off at 6 in the morning and woke the whole street up!
basicly if ur battery is running low or getting flat the alarm will automaticly go off because it thinks the car is being hot wired! it u press the alarm button one "lock" it will enable interior and exterior of the car, if u press it twice u enable only the exterior of the car, if u are getting this problem arm the exterior of the car by pressing "lock" twice and this will enble it and it shud not go off because its not using any interior sensors.
check ur alarm if its an old style battey "not a maintaince free one" then top up the cells with distilled water only run it about on a good journey and it shud give u a bit more time but my advice change the battery or check ur alternator but the alternator is the last cause.
josh
Dec 02, 2010 | 1997 Toyota Corolla
We are trying to reset a security code for our existing weiser lock and it isn't taking the new code entered.
  1. To program the first code, press the reset button once, then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. This signals that your code has been accepted.
  2. To program the second code, press the reset button twice , then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. This signals that your code has been accepted.
  3. To program the third code, press the reset button 3 time, then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. This signals that your code has been accepted.
Good lock
Good unlock
Nov 08, 2010 | Weiser Lock Powerbolt 1000 Lock
It's working in reverse order - I have to put the code in first to lock it, which leaves it ready for someone to break in because all they have to do is press the lock button and it will open. How do I fix...
http://www.weiserlock.com/en/Products/SmartSeries/Powerbolt.aspx
his should help:
https://s3.amazonaws.com/Kwikset/Powerbolt%201000%20-%20Installation%20Instructions.pdf
Kwikset and Weiser are part of the same company now.
If the above link doesn't work, this is from their site:
Resetting the code: - please follow these instructions to reset the code on your Powerbolt 1000 unit:
Remove the inner cover plate from the lock.
Locate the small round program button near the left side of the circuit board (Red or Black).
* To program, the latch should be extended out in the lock position, press the reset button once, then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. Re-enter the same 4-8 digit code to confirm, the latch should retract. This completes the programming. This signals that your code has been accepted.
* To enter a second code, follow the same procedures as in step 3, but this time press the reset button twice then enter your code.
Apr 14, 2010 | Weiser Lock Powerbolt 1000 Lock
How to reset kwikset pwerbolt 1000
6. Resetting the code: - please follow these instructions to reset the code on your Powerbolt 1000 unit:
  • Remove the inner cover plate from the lock.
  • Locate the small round program button near the left side of the circuit board (Red or Black).
  • To program, the latch should be extended out in the lock position, press the reset button once, then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. Re-enter the same 4-8 digit code to confirm, the latch should retract. This completes the programming. This signals that your code has been accepted.
  • To enter a second code, follow the same procedures as in step 3, but this time press the reset button twice then enter your code.
7. Replacing the batteries: - please follow these instructions to replace the batteries on your Powerbolt 1000 unit:
  • Remove inner cover plate located above the thumb turn on the inside of the door
  • Replace all 4 batteries with quality alkaline AA batteries. (Do not use rechargeable batteries.)
  • Ensure that the batteries are correctly oriented or unit will not function properly.
8. Changing the password code: - please follow these instructions:
  • Manually put the bolt in extended (lock) position. Press PROGRAM button once, enter new 4 - 8 digit code and then press LOCK.
  • Press PROGRAM button twice, enter the same new code and then press LOCK once.
  • Press PROGRAM button three times, enter the same new code and then press LOCK once.
    These stept will program only the new code you enter for your unit.
9. Why is my Powerbolt 1000 unit beeping? - To determine why your lock is beeping, please follow these steps:
  • Take out batteries and unplug powerstrip.
  • Let is sit for 1 minute then put the batteries back in and wait another minute.
  • If it does not beep, the keypad needs to be replaced (17733-1).
  • If the unit beeps, the powerboard needs to be replaced (A17734-4,3 Powerboard 1460 brass finish; A17734-4,26D Powerboard 1460 satin chrome finish; A17734-4,5 Powerboard 1460 antique brass finish; A17734-4,11P Powerboard 1460 bronze finish).
Nov 02, 2008 | Kwikset Powerbolt/Electronic Deadbolt-...
Trilogy Alarm Lock T2 TRILOGY® Digital Locks DL2700 Logo
54 people viewed this question
Top Trilogy Locks & Locksmithing Experts
ray gallant
Tom Chichester
Are you a Trilogy Lock and Locksmithing Expert? Answer questions, earn points and help others
