Question about Saeco Odea Go
I need a wiring diagram for a Saeco odea go - Saeco Odea Go
EsWorld
  • 1618 Answers
SOURCE: I have an saeco odea go model. I need to descale
Here are the steps for descaling:
Posted on Jul 15, 2009
SOURCE: Saeco Odea Giro - disassembly
Hope this can help:
I managed to take mine apart because I was having a lot of leaking steam from the steam wand (as posted earlier). I followed your instructions, and all worked very well. Just to prepare readers, this is what I found. The green seal on the steam end was torn, as previously described. I noticed it start to "drag" a bit during use (daily for the past year), and it must have stuck and torn over time. See photos. I replaced with a part from ACE, see photo. Be sure to lube before re-assembly. Hope the photos help!
BA
Posted on Aug 26, 2009
EsWorld
  • 1618 Answers
SOURCE: Saeco Odea Go - slow to brew coffee, comes out of steam valve
The steam valve needs to be replaced, because the pins have been damaged from high pressure buildup, could have been caused from a very fine grind. You can also check the screen in the brew unit that might be blocked and causing the high pressure backup.
Posted on Nov 15, 2009
  • 81 Answers
SOURCE: New Saeco Odea Giro machine not working
That is the machine is saying to empty the drip tray, pull out the tray on the side and wait until the red light start flashing then put back the tray.
Posted on Jan 21, 2010
  • 81 Answers
SOURCE: I Have descaled my Saeco Odea Go but still it doesnt brew coffee
That is serious, that means the grinder is jammed or not working. To check the components of the machine follow these instructions.
Press and hold the steam button and turn on the machine, when you see the lights going around in anticlockwise direction, release the button. Turn the coffee dial to the left and press the steam button, the grinder should turn. Dial on the right and pressing coffee ****. water pump runs. Press steam ****. brew group go up, dial 1/4 to left B/Group down.
If grinder not turning the motor is bad. Hope it will help to find out.
Posted on Mar 28, 2010
My saeco odea go doesn't seem to make coffee with crema anymore
At this machine the cream needs : correct coffee quantity - correct milling of coffee and correct temperature.Usually at this Saeco model it appears problem with the quantity of the coffee.
Apr 26, 2014 | Saeco Odea Go
How do I descale my Saeco Odea Giro Plus Coffee Maker
do you have a video on how to operate this machine
Nov 27, 2011 | Saeco Odea Giro Plus Coffee Maker
Det røde lys slukker ikke på Saeco Odea Giro plus Kaffemaskine er helt ny kun brykket to kopper kaffe
is it the green flashing light? If so it is the thermostat that needs resetting. You can return it for repair, or I have made a website explaining how to do it yourself. http://odeago.zxq.net/Odea_Go_Repair/Welcome.html
hope it helps
Andrew
Dec 12, 2009 | Saeco Odea Giro Plus Coffee Maker
Nov 14, 2009 | Saeco Odea Go
My Saeco Odea Go always seemed very noisy?
maybe pump make noise,check holder of pump,or replace pump
Aug 29, 2009 | Saeco Odea Go
Need manual for Saeco Odea Go
You can downlaod the manual from this link:
http://www.saeco-usa.com/en/manuals/manuals.html
Hope this helps.
Aug 24, 2009 | Saeco Odea Go
Need to adjust coffee dose for odea go
SEE THE VIODEO AND OTHER LINKS ON TYHAT SAME PAGE:
ALSO:
Saeco Odea Go adjusting coffee dose Questions
May 21, 2017 | Saeco Odea Go
Saeco Odea Giro tuning on/off
turn off each night and when going away! the machine will last longer.. without repair! also saves money (they use alot of power!
Dec 09, 2008 | Saeco Odea Giro Plus Coffee Maker
Saeco Odea Go
You can get it from the Saeco website, following this link:
this is the complete document, the english version begins page 89 of 176: enjoy ! !
http://products.saeco.com/prodotto.asp?id_linea=1&id_lingua=ENG&id_paese=15&id_articolo=10001593
have a great day
Michel
Mar 15, 2008 | Saeco Odea Go
How to descale machine
you can download and print a manual for your Saeco here
ttp://www.manualnguide.com/download/manual-guide/saeco-odea-go-instruction-manual.html
Dec 11, 2007 | Saeco Vienna De Luxe Espresso Machine
Open Questions:
See all Saeco Odea Go Questions
Saeco Odea Go Logo
222 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
