Hi i have a problem with my LG Fuzzy logic WF-T507 Washing machine where after the water goes in during the beginning of the cycle, it suddenly stops with the letters dE appearing on the screen along with a beeping sound. The manual says its a door issue so I checked the magnet and its totally rusted causing a gap between the door and the machine. How can I replace/fix it and where can I find another magnet please?
SOURCE: LG Fuzzy Logic WF-T7030TP Turbodrum Sensor
Error Peurta
Posted on Mar 24, 2008
canbruce75
  • 1776 Answers
SOURCE: LG WF-T700 Troubleeshooting DE blinking
The "DE" code indicates a door open error. This can be caused by the door not closing all the way (this could be because of bent door/hinges or the door gasket bunching up and not permitting the door to close properly), loose electrical connections at the door switch or powerboard assembly, or the door switch itself is faulty. It can be tested using a multimeter or ohmmeter and checking for continuity. A lack of continuity would mean a bad switch. Also check the door gasket for "bunching" and you can unplug and reseat electrical connections. These are some areas to look at. Be sure to disconnect unit from power before attempting any repair/troubleshooting. Really sorry for your trouble and I hope this helped. Best wishes.
Posted on Sep 28, 2009
SOURCE: my lg fuzzy logic wf s6607tc water level indicator
my daughter and myself give the lid cover a very hard knock and suddenly the washing machine works again.
Posted on Jan 11, 2010
  • 343 Answers
SOURCE: where is the door magnet located in the LG Fuzzy
If you know the position of the reed switch under the top of the machine the magnet will be where the lid closes next to it. Check under the top with a light and a mirror or carefull undo screws under small plastic covers and visually check under hob. There should be a slight bulge or a clip in lid to indicate the magnet posn.....Nomess
Posted on Apr 18, 2010
  • 472 Answers
SOURCE: Hi, we have a LG
working on lg for a while we have talked to tech suport and they don't want to admit they have a issue with these units.. first of all they say if on a pedastal they will give you problems but yet they sale the darn things... what we have found though is there is a device called a haul densor and it is very easy to replace you have to remove the backof unit panel and gain access to the back of tub... make sure it is connected well as it is on a rotor looking device called a stator assembly... if it is connected well and you have made sure it is level you have a bad haul sensor...thsi is what determines the speed of drum and slows down unit if getting out of balanced.. it is not that expensicve and pretty easy to fix.... hope this helps you out...
servicer 18 years
Posted on Jan 06, 2011
We have a LG Fuzzy logic 5.0kg WF-T507. When not working, cold water is slowly leaking into the tub. The hot water is also not flowing when needed.
The fill valve could be defective but the leakage into the machine when idle could be caused by supply line(s) above the fill valve level. Some manufacturers recommend turning off the supply between wash sessions but in practice that tends to be impractical.
Feb 12, 2017 | LG Washing Machines
LG Fuzzy Logic 8.5 kg washing machine WF-T855A Turbo Drum I sensor will not fully spin, stops with 2 minutes to go till end and clothes are in a ball, not spun properly,never had a problem until now??
Unplug the machine over night and then plug it back in the morning. this should reset the internal cycle back to manufacturers specs.
This problem occurs because someone may have opened the door during operations and the onboard computer recognized and remembered this, so it is now part of the standard operating proceedure.
Nov 10, 2016 | LG Washing Machines
What causes my LG fuzzy logic fully automatic washing machine model WF-T1050TP does not do washing cycle but can spin during spin cycle
it appears the motor's sensors could be going bad on it so the diagnostic computer doesnt know what to do but spin the motor in a spin cycle contact LG for a replacement motor for this washer
Sep 11, 2016 | LG Washing Machines
I have a LG top loader Fuzzy logic 6.5kg model WF-T655th spin cylce not working, the light is flashing. I have a load in the machine, how do I emppty the water out of it. Have misplace the manual.
I have a LG washing machine WTF655TH, it has stopped working, its full of water, but when you push the one button, it trips, how do i get it working again
Jan 16, 2012 | LG Washing Machines
Hi i have an LG 5kg Fuzzy logic top loader and it will wash and fill the water but wont rinse or spin it does not beep or anything it just stops and the time displays stays on the same numbers and i can...
Need to check during the wash cycle that the power goes to the motor during the rinse or spin cycle. Try and see if you can manually go to the spin cycle without the fuzzy logic. If so the program controller unit is a suspect as the microprocessor internal memory is faulty and executes the program with error or no output.
Jan 21, 2011 | Washing Machines
LG Fuzzy Logic 6.5 Kg WF-F733PC washing machine not spinning
hi...I have an LG Fuzzy Logic 6.5 Kg WF-F733PC washing machine & it's stop when 3-4 second start washing, wash and spin led appear also the buzzer bip contibuosly...any ideas?it's software problem....need advice
Apr 16, 2010 | Washing Machines
Washing machine won't drain
i think you can fix it , does it stops when it reaches RINSE cycle ?? if yes , your gonna open the front panel or back panel so you can see inside machine . follow the DRAIN HOSE thats attached to SMALL DRAIN PUMP MOTOR , YOU NEED TO TAKE OUT and check for anything thats blocking the impellers and causing it to stop ( pins , buttons , etc ) let me know by your smile . . . . . .
Apr 22, 2008 | Washing Machines
Washing Machines Logo
226 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
