Question about Honeywell Heating & Cooling
Honeywell t8601d showing a square symbol error - in past this has indicated low refrigerant. Tech came out, said need to replace thermostat, as compressor would not start, but if manually connected wires, compressor would start. So, had thermostat replaced. Tech then said need refrigerant. Did the t8601d actually need to be replaced?
    Problem Solver:
  • 11 Answers
There is a sensor that shuts the compressor down when the freon (refrigerant) is low. The tech probably "shorted" out this sensor. If the unit went on when he did this, the charge is low.
Posted on Jul 08, 2008
My refrigerator is a double door and top portion is not cooling yet it reads 38 degrees. Why is it not cooling?
unplug the power cord for 10 minutes, then set again the thermostat at your temperature required.plug it again and wait for two hours.
Dec 31, 2014 | Refrigerators
My thermostat has a low battery indicator that will not turn off. I have changed batteries several times and there is no change. The furnace still puts out heat but I can't change the settings at all. We...
Fortunately the price of thermostats has dropped over the past couple of years, so you probably know where I am taking you. It is time to replace that faulty thermostat with a new one. Simply remove the old one pay attention to where the wires come from and put them on the same lettered terminals to the old one. It is best to kill power to the furnace before replacing begins.
Dec 14, 2010 | Honeywell Programmable Thermostat Heater
Flame symbol showing on theremostat
It's not your thermostat. Go to where your heating system is and give us a make and model number so we may help you.
Feb 11, 2010 | Honeywell Programmable Thermostat Heater
I have an older square mercury Honeywell thermostat in my apartment. Furnace works fine in the main house using same model Honeywell thermostat. There is no heat coming from the apartment baseboards. I...
should have 24 volts @ t-stat. if tis is a boiler system it could have air in the zone that stays cold. bleed the radiator out and this should get the heat into the area you want.
Dec 06, 2009 | Honeywell Programmable Thermostat Heater
I have a Honeywell Thermostat CM67NG The flame symbol is showing on the thermostat, but there is no heat from radiators. The status code on boiler says there is ' no heat demand'. Boiler shows radiator...
You may have a broken thermostat wire. Disconnect the wires from the thermostat and please note what colors are hooked to which terminals. Cross the R and W wires and see if your heating system turns on. If it does not, you have a broken wire or bad connection at the heating system. If it does start, you have a bad thermostat or bad connection at the thermostat.
Nov 30, 2009 | Honeywell Programmable Thermostat Heater
EEE display code error on CT3600 Honeywell
I am a honeywell dealer and this stat is obsolete and no longer supported. I am not able to pull any info on this. It might be time for a new one.
Oct 01, 2009 | Honeywell Electronic Programmable...
Honeywell humidistat stuck
what i would do is make sure tha the hole for the wires that go to the humidistat is completely closed and that you are sensing the true humidity for the space also have the tech wire the so that the heat comes on instead of the ac for the de-hiumidification process.
Feb 10, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
Flashing battery symbol
I had this same problem today.  I called Honeywell and they said the flashing broken battery symbol may mean low batteries, or it may mean the battery type is incorrect.  They recommend only non-rechargeable alkaline batteries.  I was using rechargeable NiMH batteries.  Even though they were fully charged, I had the flashing battery symbol and the thermostat relay would not work.  I replaced with alkaline, the flashing battery indicator went out, the thermostat works again.
Odd that it worked for 3 months on the rechargeables after first install. I did notice the broken battery symbol came on after the first few days, but I checked the battery charges and they were good, so I disregarded the symbol until the thermostat stopped working today.  Apparently there is something about the NiMH performance characteristic that the thermostat doesn't like.
Jan 31, 2009 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
140 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
