Question about Microwave Ovens
My oven take 5-6 min to heat up. - Microwave Ovens
  • Microwave Ovens Master
  • 43,501 Answers
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems
Replacing the Igniter
heatman101
Posted on Dec 30, 2010
How do I set power level?
I can't get it to heat up....it keeps showing the red cool setting.what do I do to make it heat up again?
Nov 24, 2015 | Hamilton Beach Microwave Ovens
My microwave quit heating. everything seems fine but it doesn't heat
IF YOU ARE A TECHNICIAN THEN OPEN THE OVEN REMOCE TWO WIRES FROM MAGNATRON CONNECT A AC VOLT METER TO THOSE WIRES, PUT THE OVEN ON SET THE TIME FOR 1 MIN AND PRESS START IF 3 TO 5 VOLTS COMES THEN MAGNATRON IS GONE REPLACE IT.IF VOLTAGE IS NOT PRESENT THEN LOOK FOR DIODES AND CAPACITER.
Apr 01, 2010 | Magic Chef MCD1311ST Microwave Oven
Microoven model 860A is not getting heated
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101p][p[]p
Feb 25, 2010 | Daewoo KOR-860A Microwave Oven
Stops working after 5 mins
make sure it has a good airflow around it, check the vents to see they are not blocked off by some object or dust. I suspect the safety sendor is turning the unit off to perevent overheating.
Microwaves that are contained in nooks and cabinets suffer from this problem regularly
Please rate my help++++Thanks for using FIXYA
Nov 22, 2009 | Microwave Ovens
MY SAMSUNG MW6574W OVEN FUSE BLOWS AFTER 4-5 MINS OF REHEATING-NO SMELL OF BURNING -EVERYTHING ELSE WORKS FINE- NO LOOSE WIRING-ALL BULBS WORK FINE TOO- THE FOOD HEATS UP FINE EXCEPT THAT THE FUSE BLO
the insulation of the wiring has detiorated and with temperatue rising it further deteriorates. thus increasing the current consumption and blowing the fuse
May 21, 2009 | Samsung MW6575G/MW6574W Microwave Oven
Blinking lights
unplug wait 5 min then turn back on
Dec 09, 2008 | Sharp R-303CW Convection / Microwave Oven
Sanyo microwave EMS667W, diff high power ratings
A couple of things: If the dinner is in an aluminum pan, DON'T put it in your oven. Typically, high power units need about 3-5 minutes to heat a dinner so you should have heated it through. The power default is usually full power. Usually, there is a minutes button that should give you incremental minutes for programming.
Try using a standard nonmetallic cup (beaker) and fill it with water. Heat for 2 minutes. The water should be boiling hot. If not, your oven is not doing it right.
Mar 10, 2008 | Microwave Ovens
Microwave Ovens Logo
15 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
