Question about HP PHOTOSMART PLUS B209A All-In-One Printer
HP Photosmart B209a-m Through the solution center, can only print and scan through USB cable. Wireless setup doesn't work. Can set up the wireless printer only through Add new Printer in config panel, but then the scanner doesn't work. I've tried all the solutions I could find to setup the wireless through the CD (adding ports in firewall...etc) to no avilability
  • 193 Answers
How can i setup HP Officejet 6830 to print with USB and wireless?
There is a solution for install the hp office jet pro 6380 with USB cable connection and wireless connection on your PC.
Follow the below steps:
Configure device:
• In your printer to select Network setup.
• Then select wireless settings.
• Check the wireless is on.
• Next to choose your network name as SID.
• Now you have to enter the wireless password.
Install wireless device:
• First, download the latest Mac OS X 10.10 driver for your printer.
• Run network install.
• Now you have to test wireless printing to confirm that functioning.
Install USB device:
• First, plug USB cable on your printer to the PC.
• Click the apple menu to select the system preferences.
• Select the print & scan option to check your printer name.
• Now click plus sign to select the add printer or scanner.
• Ensure that hp Officejet driver is selected.
If you still have any doubt or issues you can also contact our customer support to help you regarding your HP printer issue @ +1-800-836-3987 or visit 123.hp.com 6830 oj.
Jul 21, 2017 | HP Office Equipment & Supplies
HP photosmart c309 printer continues to not print or will only print the header and stops printing. How do I fix it?
Network troubleshooting
If you are encountering issues using your HP Photosmart over a network, try the following steps in the order listed:
  1. Turn off the router, product, and computer, and then turn them back on in this order: router first, then the product, and finally the computer. Sometimes, cycling the power will recover a network
    communication issue.
  2. For wireless networking issues, run the Wireless Network Test from the product control panel.
    1. Press Setup.
    2. Press the down arrow button until Network is highlighted, and then press OK.
    3. Press the down arrow button until Wireless Network Test is highlighted, and then press OK.
      The Wireless Network Test prints.
    If a problem is detected, the printed test report will include recommendations that might help solve the problem. If you need to change the network settings on your product or have never run the Wireless Setup Wizard, do so now.
    Double-click the HP Solution Center icon, click Settings, click Other Settings, select Network Toolbox, and then select the Wireless Setup Wizard link.
  3. If the previous steps do not solve the problem and you have successfully installed the HP Photosmart Software on your computer, run the Network Diagnostic tool.
NOTE: The diagnostic test might prompt you to connect a USB cable between the product and your computer. Position the product and computer near each other and have a USB cable readily accessible.
To run the Network Diagnostic tool. In the Solution Center, click Settings, click Other Settings, and then click Network
Toolbox. On the Utilities tab, click Run Network Diagnostics.If you are unable to run the Network Diagnostic tool or it does not help solve the problem, check the following sections for additional information:
  1. Make sure that the computer is connected to your network
  2. Make sure that the product is connected to your network
  3. Check to see if the firewall software is blocking communication
  4. Make sure the product is online and ready
  5. Make sure the HP Device Discovery software is running
Sep 09, 2014 | HP Office Equipment & Supplies
How do i change the ssid on my photosmart plus b209a-m printer
Step 1: Click on Windows icon (bottom left hand screen)
Step 2: Select Devices and Printers
Step 3: Right Click on "HP Photosmart Printer Plus B209a-m"
Step 4: Select "Printing Preferences"
Step 5: Click on Tab "Features"
Step 6: Select "Printer Services" in the bottom right hand corner
Step 7: Click on tab "Network Settings"
What you click on there depends on what's wrong with your setup, I think. Mine had a "Configure Wireless" option where I was stepped through the process.
Good Luck!
Jul 10, 2012 | HP Photosmart Plus B209A All-In-One Color...
My hp 3310 will not print either by usb cable or wireless - always asks for wpa number, can't turn off wireless on printer
Hi there!
Normally on the printer itself, you can turn off the wireless functionality of it by going to Setup > Network > Wireless Radio. You can also press the Wireless Icon to get into the Setup settings.
Hope this helps!
Aug 07, 2011 | HP Photosmart 3310 Printer
I bought my daughter an HP photosmart D110 Series printer for xmas. I set it up here at home using wireless, not USB, and it worked great. Now when she gets to her apartment which also has wireless, we...
start new,
use the D110 full setup instructions from scratch.
install the software from HP.
then on some printers, like mine, the USB way works or wifi
if you set it up to wifi , usb is dead.
and the reverse.
so must be reset , per the manual to get it the way you want.
it is a very complex device, this all in one e-printer
https://support.hp.com/us-en/product/HP-Photosmart-e-All-in-One-Printer-series---D110/4023244
wifi, is complex.
first the user must know the routers settings to make it connect.
but some times you have no access to that router, due to owners
are ISP or landlord.
to use wifi , i must force my router to use a fixed IP (reserved)
or will not connect , reliably, the manual covers this too.
use the HP install package,
rule 2:
NOTE: If the printer is connected with a USB or Ethernet cable, the printer cannot connect wirelessly.
click does not maintain wireless....., seen here.
it tells you to run the hp print and scan doctor there.
Aug 21, 2017 | HP Computers & Internet
How to set my ho photosmart c4600 series to work
Your photosmart c4600 series printer is a USB printer. It is designed only to work with USB cable. However you can use HP Wireless Upgrading kit to print wirelesly.
Apr 05, 2010 | HP Office Equipment & Supplies
I just brought a new HP Photosmart B209 and as long as it is hooked up to the usb port it is fine but as soon as i disconnect it from the usb it says it is offline. how can i get it to stay connected to...
I suggest that you turn off the printer power, then unhook from usb. That disconnect from usb can sometimes scramble the printer driver and control firmware, and require a reinstallation. Also, plug the printer directly into a wall socket, especially for scanning.
Nov 28, 2009 | HP PHOTOSMART PLUS B209A All-In-One...
How to get the laptop to connect to the HP Photosmart C7200 All-in-one series for scanning. Printing works from the laptop but I can't get it to scan into the laptop.
Can connect through USB or Wireless
Need to download the 64 bit OS driver from hp.com
First uninstall the complete Software from the computer
Unplug the USB cable;
Then put the CD in the computer ;
Goto My computer- Right click on Black HP logo - Click on Explore - Open
UTIL (Folder)- Open CCC (Folder)- Double Click on UNINSTALLATION
L3 file;
If you don't have the Cd Uninstall the software from Add and remove
programs
Restart the computer ;
Click on the below given link it will help you download the software :
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=320478
5&lc=en&cc=us&dlc=en&lang=en&cc=us
Select your OS;
Select the Full feature Driver;
Click on Download ;
Save to your desktop;
On the printer :-
Press the setup Button (button with the monkey range)
Goto Network Press Ok
Goto Run Wireless Setup Wizard
Run it (make sure you should have the WPA/WEP key ) ready with you
Select the Network and get it connected to the network
On the computer:
Run the application that you have downloaded and install the software
Try to scan from "Hp Solution Center"
it should work
Oct 23, 2009 | HP Photosmart C4580 All-in-One InkJet...
I just bought a new HP photosmart C5580 with bluetooth wireless
Your printer can print wirelessly through bluetooth only.
note that your computer must be bluetooth capable also.
here's an instruction. Bluetooth Setup of Hp C5580
Apr 07, 2009 | HP Photosmart C5580 All-In-One InkJet...
HP PHOTOSMART PLUS B209A All-In-One Printer Logo
471 people viewed this question
Seeker5211
Seeker5211
