Question about Minolta DiALTA Di183 Copier
Cannot close the M1 part of Minolta Di 450 - Minolta DiALTA Di183 Copier
  • Minolta Master
  • 6,680 Answers
M1 is a counter for maintenance need to get service mode access to clear the counter and clear the message.
Posted on Mar 01, 2015
4 Suggested Answers
  • 126 Answers
SOURCE: minolta ep3000 service m1 ? and how to reset ? can you help
M1= main motor
1. Does the transport motor (M1) operate during power up?
NO, Ensure the connection of the connector (PJ21A) is secure.
2. Replace the transport motor.
YES, Check if there is excessive load on any of the rollers,gears,etc.
3. Replace PWB-A.
Posted on Jan 24, 2009
  • 1297 Answers
SOURCE: minolta copier di-450 code : c-143e
The correct error code is C 143E - EDH malfunctions.Please reset the malfunctuion code to open and closed the front door,or turn OFF wait 5 sec. and turn ON the power switch.If the problem persist change the image processing board.
Pick up motor malfunction
Whwn the document handling tray goes to up the pick up raised position sensor is not unblocked when the motor started turning forward.Whwn thw DHT goes down the pick up lower position sensor is not unblocked after the motors started turning backward.
During ascent motion check :
1.Foreign matter on pick up motor gear
2.Pick up motor operatio.The voltage across PJ11A 1 of main control board and GND is 0V when the motor is deenergized and 24 V when the motor is energized when the DHT is raised after the malfunction reset.
3.Pick up raised position sensor operation.
Change the motor,sensor or main control board.
During descent motion
1.Check the pick up motor gear.
2.Check the pick up motor operation
3Check the pick up lower position sensor operation.
Posted on Aug 28, 2009
  • 1739 Answers
SOURCE: i dont,ve driver but i
The drivers for your printer can be found here. Make sure to select the correct driver for your Operating System.
http://onyxftp.mykonicaminolta.com/download/SearchResults.aspx?productid=462&filetypeid=0
Posted on Jan 29, 2011
Hello sir, i have a problem with my copier minolta di 450. The problem code is c-0990. Plz help me!
Main Draw (large Capacity) has a problem open and close front door if the code comes back then you probability have a broken gear in the 3 draw lift system. Usually the gear gets rounded out in the center. gear is black and located behind several gears behind the front cover of the draw
Aug 28, 2015 | Minolta Office Equipment & Supplies
Minolta Di 450 code 13 & 14
need additional numbers codes are c-xxxxx
Mar 03, 2014 | Konica Minolta Minolta Di450 Di470 Di550...
How to remove the Code 13 & 14 of DI 450 Minolta copier
open and close the front door. If not replace the Laser or PWB-B Board
Mar 03, 2014 | Minolta DiALTA Di183 Copier
My konica monilta di 450 is giving error code c-13fa please help and give me its solvation?
The problem is the print head that is were the LASER is located open close the front door to reset if it comes back replace the print head
Feb 01, 2014 | Minolta DI-2010F Copier
Error code cof32
C0F32
Faulty ATDC Sensor
- The measurement taken by the ATDC Sensor (UN1) at a time 2.0 sec. after the Main Motor (M1) has started turning is less than 5% (greater than 4.63 V).
- The measurement taken by the ATDC Sensor (UN1) at a time 2.0 sec. after the Main Motor (M1) has started turning is 19% or more (1.41 V or less).
Jan 31, 2014 | Minolta DI-2010F Copier
Di 450 earer coad c13f8
Print Head error. The print head is what houses the LASER for printing/copying. Open Close front door to reset. IF not replace the Print head. Worse case the image control board is bad. Also check all connections between the print head and the image control board.
Sep 14, 2013 | Minolta DI-2010F Copier
PRINT HEAD failure that is the unit the LASER is in. try open close front door, check connection between print head and image control board if not need a new print head.
Dec 28, 2011 | Minolta DI-2010F Copier
Minolta di450 error code c0201
please sir, minolta copy di 450 ditected c 133b
Oct 22, 2011 | Konica Minolta DiALTA Di200 Copier
DI 450 KONICA MINOLTA ERROR CODE C0070 AND C0F24
if it;s not the bottle home position it may be you toner happer motor...clean it and try to take the bottle our and close the door and than put bottle back in
hope that help
Feb 25, 2009 | Konica Minolta DiALTA Di200 Copier
Minolta DiALTA Di183 Copier Logo
85 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
