We bought the latest washer and dryer with steam cycle a week ago only .( Prod. No.MFL51768152 . ) BUT unfortunately the smell of the laundry as the smell of plastic.I don't know why ? We called LG maintainance ,they came and they didn't do anything.We are surprised ,the technitian insists that there is no smell .when you smell the tub itself ,the smell is the same ????????? our previous washer and dryer was also LG but it was amazing the smell was as the sofener and detergent smell but now the smell is awful .
SOURCE: LG washing machine has AWFUL mildew smell
What is a P trap & why then didn't my old top-loader make my clothes smell? I think we've all been had.
Posted on Nov 02, 2008
  • 42 Answers
SOURCE: LG Tromm - WM2688HNM - Detergent dispenser full of water & some detergent after wash.
sounds like you have calcium build up, this happens alot with LG's. need to take out the dispenser and clean the calcium with industrial lime away, that only works good for me, but others will do, also use a sharp object, like a ice pick or finishing nail, to scrape off any left over hard residue.
the calcium will clog all the holes in the dispenser.
if this doesn't solve your problem, then there is one thing left
just email me and ill give you the other solution.....
Posted on Dec 12, 2008
  • 5 Answers
I have an LG washer that had the same problem. Go to the site and read all about why this is happening, how to fix it and how to keep it from comming back. A few different ways of cleaning the machine are explained.
The site sells a product that you may or may not need but the explanations are really good.
Posted on Mar 12, 2009
  • 4 Answers
SOURCE: detergent dispenser stuck
Had the same problem here today, the softener dispenser blue plastic piece was loose jamming the whole dispenser tray, to resolve remove top cover, two screws on top rear, slide the cover towards the back, you will then see the detergent dispenser, press the right clips and pull it off slightly at the back; do not put too much pressure and try to remove the cover completely, just pry the plastic cover a bit then pull the detergent tray it should come right out.
Posted on Jul 14, 2009
  • 5 Answers
If you're not used to seeing water come down the front of the inner glass portion, then your return tube, and/or gasket drainage is most likely clogged. I have the LG WM2277HW front loader and this is what worked for me:
1. Locate water recirculating outlet at the top inside of the gray rubber door gasket- it will have a white plastic piece that directs the water flow inward.
2. Check for blockage at that outlet. Mine had one about 2 inches long. Pull it out with your fingers or tweezers.
3. Check the 3 small rectangular drain holes at the bottom of the gasket; make sure they're not plugged up as well. This is where the smelly water pools from bacterial growth
4. Run through a sanitizing cycle- no detergent, just bleach and watch for more blockage that might come out the tube from the collects on the glass before falling all the way in. Don't wash any clothes before this step, or the gunk will end up in your load.
Hope that posted.
Posted on Jan 20, 2010
Burning plastic smell from washer dryer combo
You have something between inner and outer tub remove top cover smell coming from air vents of outer tub then that is were it is
fun job its has to come all apart
Jun 28, 2016 | LG WM3987HW Front Load Washer / Dryer
Electrolux Insight Iron Aid. Why does it steam up kitchen?
Electrolux Wave Touch Dryer Problems. It Leaks! - YouTube
? 2:12
Sep 27, 2012 - Uploaded by erik malewski
My less than a week old Electrolux Wave Touch Dryer leakedfrom the perfect steam inlet all over my ...
Water under my Steam Dryer (May: condo, appliances, house ... > City-Data Forum > US Forums > Oklahoma
Aug 15, 2012 - My washer and dryer is an Electrolux designed in Italy to Sears ... wasleaking; but the repairman said it wasn't and that the dryer just had built ...
Electrolux steam dryer Questions & Answers - Fixya
Jan 01, 2016 | Dryers
The water spray for steam cycle in Samsung front load dryer smells musty. The clothes smell bad from steam cycle only.
water build up in the steam water resevore sitting to long and getting that mildew smell check the hose lines going into it and from it. for blockage
May 27, 2014 | Samsung Dryers
Clothes smell after drying
I don't think the problem lies with the dryer, I would suspect the washer has mold, this is especially true on front load washer, they make products designed just for this problem, check with a large retailer, not sure who makes the mold and mildew remover, I think Home Depot or Lowes may have the product or know about it..
Jan 29, 2012 | GE Profile DPXH46EA Electric Dryer
Frigidaire FEX831CS Top Load Stacked Washer / Dryer will not spin - burn smell
The transmission is burnt out. Happened to my mother in law a few months ago.
Nov 13, 2011 | Frigidaire FEX831CS Top Load Stacked...
I have exactly the same problem!
Try using the tub clean cycle and use a good dose of bleach or vinegear. Here is how to run the tub clean cycle.
To start the TUB CLEAN cycle:
1. Remove any clothing or items from the washer and close the door.
2. Open the dispenser drawer and add liquid chlorine bleach to the bleach compartment.
NOTE: Do not add any detergent to the detergent compartments. Excessive suds may be produced and leak
from the washer.
3. Close the dispenser drawer slowly.
4. Power On and then press the Extra Rinse button for 3 seconds. (Prewash option will be selected.)
5. Press the Start/Pause button to start.
6. After the cycle is complete, leave the door open to dry around the washer door opening, door seal and
door glass.
Jul 11, 2009 | LG WM2688HWM TROMM SteamWasher
Burnt Rubber smell and spin cycle didn't work
the main motor needs to be serviced , sounds like the couplings broke , hope this helps , AJ
May 18, 2009 | Maytag Dependable Care LAT9416
New HE5t steam dryer will not turn on
What was wrong with your dryer? I am having that same problem?
Dec 27, 2008 | Kenmore Dryers
Clothes come out of washer smelling musty
It sound like lint bult up under agitator orIn Between inner and outer tub it would have to be manualy cleaned thanks and good luck:)
Nov 16, 2008 | Maytag MAV3855A Top Load Washer
Strong ozone-like burning smell
Sounds to me like the motherboard inside the unit is on it's way to thermal overload. This is a common problem with this particular model. You'll smell electronics burning and one day it'll quit altogether with a burst of smoke. I had this happen to me and I traced the problem back to a faulty triac (transistor-like device) that overheated and caused the circuit board and wiring harness to burn up from excessive current draw. I repaired my motherboard with a new triac ($6) and rewired the harnesses. A cooling fan on the heatsink of the board would solve this problem.
Nov 12, 2007 | Equator EZ 3612 CEE Front Load...
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
