Question about HP DeskJet F380 All-In-One Printer
Power could not start by pressing power button but power is coming as the blinking is done for once when connected to power
  • HP Master
  • 7,733 Answers
Solution one: Make sure the electrical outlet works
  1. Unplug the power cord from the electrical outlet.
  2. Plug another appliance into the electrical outlet to make sure the outlet works.
    • If the electrical outlet does not work , plug the product into another outlet that does work.
    • If the electrical outlet works, but the product still does not turn on , continue to the next step.
Solution two: Make sure the power supply is compatible with the HP product
Follow these steps to test the power on the product.
  1. Reconnect the power supply to the rear of the product.
  2. Press and quickly release the Power button (power could not start by pressing power button but - c01602202.gif ) to start a Power On/Off cycle. Do not hold the button down. Figure 1: Press and quickly release the Power button c01733891.gif If you press and hold the Power button too long, the product might turn on power could not start by pressing power button but - c01602202.gifwithout restarting. If this happens, press and quickly release the Power button (c01602202.gif ) again.
  • If these steps resolved the issue , there is no need to continue troubleshooting.
  • If the issue persists , see the next step.
Solution four: Test the power with a compatible power cord from a different product If you have another available power cord that is compatible with your product, use the alternate cord to repeat the steps in Solution three: Reset the power module and test the power .
  • If the product turns on with the alternate power cord, the original power cord caused the issue. Contact HP to replace the power cord. Right-click the following link, How to Buy HP , to buy a compatible power cord.
  • If the product does not turn on with the alternate power cord, continue to the next step.
Solution five: Service the HP product If you have completed all the steps listed above and are still experiencing a problem, service the product.
Posted on Dec 30, 2010
My ps3 controller doesnt connect with my ps3 :( . when i press the ps botton no lights come .but when i charge all 4 lights blink .please help !!!!!!!
I had just fixed my controller with that problem. Theres a tiny hole on the back of the controller. That is the reset button. Get something really small and thin so it can hit the button. Once done turn on your PS3 and plug up the controller with the usb connector. Once done press the PS button then it will start blinking and then assign a controller number
May 29, 2012 | Sony Dual Shock 3 Controller for...
Trying to set time on Timex 1440 sport with mode button top left, start/stop upper right,adjust bottom right,indiglo bottom left..no instructions match or work.
press and hold the mode button until the digits blinks then press it again once, (digit that are blinking is changeable) use the "start/stop button to choose what will you change and adjust buttton to adjust it. if your done, press the mode button again once.
i hope i had been helped you.
Aug 10, 2011 | Timex Watches
How do i tune the remote to my t.v.
Press and hold "device", select device until blinks 3 times, press power until menu appears, once menu appears try volume button, if volume works, press device, wait until you get two blinks, then quickly press power. If the device responds then you are done ! otherwise go back to step 2. good luck!
Jul 24, 2011 | Televison & Video
Where is the code search button
The power button is used as code search button.
To programme the URC-3021 please follow the steps
1.On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice,
then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly alternate
between pressing POWER and TV. Stop when the TV turns off
(after pressing POWER).
5. To lock in the code, press and release SET.The LED will
blink twice.
6. Your done with programming.
Thanx
Jul 23, 2010 | One For All URC-3021 Remote Control
Cant enter bios menu
The AA1 has a built-in BIOS recovery routine, which makes it possible to flash the The AA1 has a built-in BIOS recovery routine, which makes it possible to flash the BIOS even if the system doesn't boot anymore. It's only meant for emergencies, that's why it's also known as crisis disk mode. Use at your own risk.
First format an USB flash drive with FAT.
Download the latest BIOS, extract all files from the zip file, put both FLASHIT.EXE and the BIOS file with FD suffix in the root directory of the drive. The files must not be in a folder. Rename the BIOS file toZG5IA32.FD, that's important.
Turn the AA1 off, with the USB drive still connected, and make sure both battery and AC adapter are also connected.
Press Fn+Esc, keep it pressed and press the power button. Release Fn+Esc after a few seconds, the power button will be blinking. Press the power button once. The AA1 will now initiate the BIOS flash, do not interrupt it under any circumstances. After a while the power button will stop blinking, and the AA1 will reboot shortly after. Wait patiently.
The BIOS has been flashed and all settings reset to default.
If it doesn't reboot by itself, but the power button still blinks, wait a few minutes before turning it off, and try again. BIOSeven if the system doesn't boot anymore. It's only meant for emergencies, that's why it's also known as crisis disk mode. Use at your own risk.
if that doesn't work the link below sells help http://www.badflash.com/
Mar 13, 2010 | Computers & Internet
Resset ink absorber is full canon ip3600
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jan 08, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
Blinking orange 5 times and 1 green
Try this:
Most of the time when a printer used for a certain period the ink would dry out and caused an error message. What you do is to replace with a new inks pad inside the printer and reset that error message. Once it is done, your printer will work again!
For Printer Model: Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000:
1. Turn off printer
Please remember to rate all Techs who assist you for free :)
Oct 04, 2008 | Canon BubbleJet i560 InkJet Printer
Free Pulse
The following procedure will re-establish the communication link between the Headphones and the Wireless adapter, this is called "pairing". Before you start please make sure both the headphones and the wireless adapter are fully charged and turned off.
Note: The headphones and the wireless adapter come pre-paired from the factory.
1. Press and hold the power button on the headphones. See Figure 1.
Figure 1
2. Continue to hold the button down until the LED starts flashing red/blue in an alternating pattern. Release the button when the LED starts flashing red/blue. See Figure 2.
Figure 2
3. Once the headphones LED is flashing red/blue, press and hold the power button on the wireless adapter. See Figure 3.
Figure 3
4. Hold down the button until the LED starts flashing red/blue in an alternating patter. The LED will blink blue, then turn off for a few seconds then blink red/blue. Release the button when the LED starts flashing red/blue. See Figure 4.
Figure 4
5. Once both the headphones LED and the adapter LED is blinking red/blue, press the volume up button once on the headphones. See Figure 5.
Figure 5
Once the headphones is paired with the adapter, the LED on the headphones will blink blue once every two seconds. See Figure 6.
Figure 6
When the adapter is paired the LED will be solid blue. See Figure 7.
Figure 7
The adapter may continue to blink red/blue for a few seconds even after the headphones LED starting blinking blue. This is normal; the adapter may take a few additional seconds before the LED turn solid blue.
Once the headphones and the adapter are paired, it is not necessary to pair them again even if the batteries on both units are completely drained.
Additional Note: Repeated pairing will not improve the sound quality or give the headphones and the adapter a cleaner connection.
Mar 11, 2008 | Logitech FreePulse Wireless Consumer...
Timex 1440 sports digital watch time setting
  1. Press and hold the mode button until it starts to blink, then release.
  2. First the alarm time will come up.
  3. Press the mode button once to get to the time and date.
  4. The seconds will flash first.
  5. Press the st/stop button to toggle between the seconds, hour, minutes, date (month and day) and day of the week.
  6. Press the lap/reset button to change the values.
  7. When done, press the mode button again to return to normal.
Mar 09, 2008 | Timex 1440 Nylon watch
HP DeskJet F380 All-In-One Printer Logo
183 people viewed this question
Seeker5211
Seeker5211
