Have a coleman evcon heating & cooling furnace froze up had ice on coil / top of unit. Husband cut the unit off to thaw out not the unit will not come back on.
  • gotbear63 Dec 01, 2008
    mine does the same thing and it smokes sometimes and gets stuck on
    Problem Solver:
  • 11 Answers
Freon (charge) is low. Contact a service man with the proper gauges to check theunit. It will have to be evacuated, nitrogen pressure tested, and then recharged.. Depending on the size of the unit, this cold be about 200-400$.
Posted on Jul 08, 2008
Do I need a outside cooling unit for a Coleman 7900 Presidential lll gas heat and cooling unit
Yeah, youd have to look at the model on the Indoor coil box, furnace will be setting on top of it. Youll need the model off that coil box to get the correct tonnage of the outdoor condensing unit, you can go 1/2 ton smaller on outdoor for greater efficiency.
Feb 12, 2015 | Coleman Heating & Cooling
Coleman electric furnace
You don't say whether you replaced the blower but that could be the next thing to check
Jul 23, 2013 | Heating & Cooling
I have a Coleman Evcon Elec Furnace with the added AC Unit. The blower works great with the AC but only on & off with the heat, what could this be?
Replace the sequencer...which is just a series of snap disc relays that are staged. The first snap disc should kick on the first element & low speed of blower. Depending on how many elements you have, determines how many snap discs are on the sequencer. It could be a 2,3,4, or 5 stack. Generally the coil is 24 volts.
Dec 01, 2012 | Coleman Evcon Furnace Control Circuit...
I have a coleman Evcon model AH16-0 . I am
Typical Thermostat Wiring for 4 or 5 wire Heat/Cool Thermostat (not heat pumps)
4 Wire Termostat
R = Red One Side of 24 volt Transformer
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
with one transformer for both units
Rc One Side of 24 volt Transformer
Rh Jumper Rc to Rh
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
With 2 transformers one for indoor unit
And one for outdoor unit
Rc = Red One Side of (outside) 24 volt (outside transformer)
G = Green Blower (outside transformer)
Y = Yellow Cool (outside transformer)
Rh = Blue One side of (inside) 24 volt (inside transformer)
W = White Heat (inside transformer)
COOLING ONLY Thermostat
G = Green Blower
Y = Yellow Cool
HEATING ONLY
R or Rh One Side of 24 volt Transformer
W = White Heat
Jan 06, 2010 | Heating & Cooling
I have a Coleman/Evcon Presidential ser# 074878. The plumber says the Heat exchanger is cracked. Is this something I can fix myself or is it less expenxive to buy a new furnace?
The heat exchanger is a bear to change. depending on the age of the unit it might be more practical to replace the unit. However unless you trust this service tech I'd get a second opinion, because it is rare that a heat exchanger will crack, plus by law he or she should have shut the furnace down do to carbonminoxde. Especially rare in Coleman Evcon series units.
Oct 21, 2008 | Heating & Cooling
I have an coleman evcon furnace when i turn a/c on the outside unit will run but the inside wont run
put the just the fan on turn off the ac and the heat and just fan on make sure the blower motor works cause thats really the only thing you utilize from the furnace in the summer and let me know
then if so does your heat work fine
May 30, 2008 | Heating & Cooling
Heating & Cooling Logo
113 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
