Question about Frigidaire FAH106N1 Wall/Window Air Conditioner
Frigidaire FAH106N1 Thru-Wall/Window Air Conditioner
At first it would turn on but not blow air i have that working now it blows cold air but the fan is makin lot of noise its a hollow load noise
    Problem Solver:
  • 11 Answers
Check for blockage of the air pathway. Check that the fan turns freely, as the bearings or bushings could be shot. The fan blades could also be loose. You might just want to replace the fan, as it is cheaper than replacing bushing/bearings.
Posted on Jul 08, 2008
Frigidaire in wall air conditioner making noise fan/ motor?
Is it a clicking or banging sound? The fan is most likely not kicking up the moisture to cool the evap coil off enough in the unit so you might here more noise for a little while. Monitor it and let me know if anything changes.
Sep 05, 2012 | Frigidaire FAH106N1 Wall/Window Air...
How to replace coolant in air conditioner...
fan motor is bad stuck or relay or capictor if fan dont pull air thru condensor it does not turn to liquid and then wont evaporate or cool in evaporator
Aug 28, 2012 | Friedrich QuietMaster SM24L30...
Displaying code 8
That is the temperature setting I would believe - meaning not the ?F setting but on a level of say 1-10 scale.
Aug 09, 2012 | Frigidaire FAH106N1 Wall/Window Air...
Air conditioner isn't blowing cold! Fan works okay but air isn't cool. Can hear hissing sound that sounds like normal compressor function. Do I need a coolant recharge?
You will need the condenser coils repaired before you can charge it. These come from the factory sealed and they should not ever need a charge unless you have a leak. The hissing sound is more likely air in the system being pumped by the comressor and it is coming out a hole in the coils.
May 29, 2011 | Frigidaire FAH126N2T Thru-Wall/Window Air...
Can a 12000 BTU thru the wall AC be installed as a
Yes... no problem... just need to use cardbord of something to seal off the open spaces around it...
heatman101
Jul 21, 2010 | Frigidaire FAH106N1 Wall/Window Air...
Cleaned the unit and it won't turn on?
was it plugged in when you cleaned it? check circut breaker. Otherwise you may have damaged your electronics on the unit.
Jul 07, 2010 | Frigidaire FAH106N1 Wall/Window Air...
Ac doesent blow air
If the fan is not working,then the fan motor is bad,or the start capacitor is bad.Pull the unit out so you can work on it,near the plug in.Be carefull,and use a stick,backscratcher,or something like that.Turn the ac on to cool,high blower,and turn the fan bladeclockwise to see if it will try to start turning on it`s own.Careful not to gouge the coils,and try to turn the fan reall good.If it starts,let it run,for about 15 minutes.If the fan,does not quit,then replace the start capacitor.If the fan wont start turning on it`s own,or the fan stops after a while,replace the fan motor.I hope this was some help.
Oct 06, 2009 | Frigidaire FAH106N1 Wall/Window Air...
Thru-the-wall air conditioner won't turn on
Check for power at the plug in, if it's got power take it back under warranty.
Jun 10, 2008 | Frigidaire FAH106N1 Wall/Window Air...
Frigidaire FAH106N1 Wall/Window Air Conditioner Logo
257 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
