Question about VIA Gigabyte GA-7VT600P-RZ KT600 Socket A DDR 400 ATX Motherboard w/SATA,LAN, USB 2.0&Audio (M7VT600PRZ)
NOT WORK SATA HDD - VIA Gigabyte GA-7VT600P-RZ KT600 Socket A DDR 400 ATX Motherboard w/SATA,LAN, USB 2.0&Audio (M7VT600PRZ)
  • 656 Answers
When the system restart press del and go to bios in bios you have to click optimised defults then save and exit still the hard disk isnot detected then change the hard disk
Posted on Dec 30, 2010
How can I use a SATA HDD in a 7NF-RZ motherboard? What cables/adapters are required?
Hey there. To install SATA devices on any motherboard follow these steps:
1- Make sure your Motherboard supports SATA, a 7NF-RZ works fine.
2- Install the HDD on your case, usually you have to screw it in or if you have a newer case you can lock it in place with a latch.(The SATA slots on a case are usually above the optical drive slots).
3-If you have another HDD already installed, and you don't want the new HDD to have system files, make sure it's designation is set to Slave. To do this, remove the jumper on the HDD pins(a white plastic connector) with tweezers, and, according to your HDD specifications, move it up or down to Slave designation.
4-Use a SATA cable from your Power Supply and connect it to the HDD, then, use a SATA adaptor cable which should have come with your HDD and connect it to the HDD, then to your Motherboard SATA adaptor(these vary from motherboard to another, so use your Manual to specify where it is).
5-Boot up your computer, and enter BIOS. Usually press either F2,F5,F12 or Esc. After that go to Auto-Detect drivers. When you're done, Save & Exit.
You should have successfully installed your new HDD!
Aug 21, 2011 | Gigabyte 7NF-RZ (GA-7NF-RZ) Motherboard
Controller MSI K8N Neo4 does not work
SHUT DOWN COMPUTER AND CLEAR CMOS BY RESETTING JUMPER ON MOTHERBOARD AND THEN RETURN JUMPER TO NORMAL POSITION OR USE RESET BUTTON. UNPLUG ALL HDD SATA CONNECTORS FROM HDD. BOOT COMPUTER TO BIOS. MAKE SURE ENABLE ALL SATA IS ENABLED, PRESS F10 AND EXIT.YOU WANT TO SHUT DOWN AGAIN. NOW REATTACH SATA HDD AND CONNECTORS AND BOOT TO BIOS AGAIN. NOW HIT F10 AND LET COMPUTER RESTART AND LOAD INTO THE OS. LOGON AND CHECK DEVICE MANAGER..SHOULD BE THERE. IF NOT CHECK MOTHER BOARD WEB SITE FOR BIOS UPDATE. IF BIOS UPDATE DOESN'T DO THE TRICK, SHUT DOWN AND DISCONNECT THE IDE DRIVE, UNLESS IT CONTAINS YOUR OS. TRY BOOTING TO BIOS AND CHANGE ORDER OF 1ST BOOT OPTIONS, HIT F10 AND EXIT AND ALLOW COMPUTER TO BOOT TO OS, THEN LOGON, GO TO DEVICE MANAGER AND REMOVE IDE AND RESTART, ONLY IF THIS HDD DOES NOT CONTAIN OS. YOU SHOULD BE FINE AFTER THIS, OR INSTALL YOUR OS ON THE SATA HDD.
Apr 09, 2010 | MSI K8N Neo4 Platinum nForce4 ultra K8...
MSI RC410 - cannot detect Sata HDD
i think the problem is with ur SATA HDD. To confirm, try another SATA HDD on ur mother board and see if the problem persists
Sep 20, 2009 | ASUS P5RD1-VM Motherboard
Mother board cant detect my Sata HDD, please advise me urgenly...
I will advice you to exchange the HDD with someone or with brand new one as it seems to be problem with drivers of the sata.
Sep 20, 2009 | MSI RC410M-L Motherboard
Sata hdd not detected
Yes, go into the bios and make sure that SATA is turned on. Sometimes with motherboards that have two ide controllers the SATA is turned off by default. Also another thing to check is whether the motherboard is SATA I or SATA II. If it is SATA I then change the jumper on the hard drive to peg back to SATA I. Your new hard drive is SATA II and the motherboard may not support it.
Jun 10, 2009 | Biostar K8T80-A7 Motherboard
Cannot detect external sata hard disk
I would start by swopping the Internal Sata Cables around and check if that solved it.
If not then there's probably a problem with either the E Sata HDD Controller board or Even the HDD or the Sata cable going from the Motherboard to your input E Sata Port.It's a matter of elimination.
So Remove the HDD from the Enclosure and plug it directly into the Motherboard and see if thats picked up.If it is then the HDD is fine.If not, get it replaced and it might still be under warranty.Check with the manufacturer.Continue reading if the HDD is fine.
Then use the Sata Cable from another HDD and connect it straight to to the E Sata Enclosure and see if the Operating System picks it up,Make sure the HDD you removed is plugged back into the enclosure.If that doesn't work then the problem lies with the Enclosure itself and you should get it replaced.
If it does the the problem lies with the cable itself and you should replce that.
Hope this helps you out.
May 08, 2009 | ASUS P5QC Motherboard - Intel P45, Socket...
I have Intel 845GVSR Motherboard, 2.4GHz Processor, 1GB RAM
Yes it will. Just make sure to buy the proper hdd. If your board has SATA II connections then you would need a SATA II hdd. If it is just SATA then a SATA II drive would not work. Your other option would be an IDE hdd. If your system has a cable that looks like a big ribbon connected to your existing hdd then it's an ide drive. Hope this helps & please remember to rate my answer. Thanks.
Jan 27, 2009 | Intel D845GVSR Motherboard
Asrock Motherboard problems with SATA HDD
It is possible that you are trying to use a SATA II HDD in a system that supports SATA. SATA II devices are not backwards compatible usually,
Dec 20, 2008 | Asrock P4V88 (P4V88 RAID) Motherboard
Sata hard disk drive on asus p4v8x-x motherboard
i think you should install via raid tool from asus driver cd then check in control panel --> administrative tools--> computer management and you click to disk management
the sata hd will dectected by the computer so you can format it
you must reboot first after via raid tool instalation
i manage this way and succeed on my 500 gb sata drive
try it
Jan 28, 2008 | ASUS P4V8X-X Motherboard
VIA Gigabyte GA-7VT600P-RZ KT600 Socket A DDR 400 ATX Motherboard w/SATA,LAN, USB 2.0&Audio (M7VT600PRZ) Logo
157 people viewed this question
Top VIA Computers & Internet Experts
David
David
Tony
KG John Justin
KG John Justin
Are you a VIA Computer and Internet Expert? Answer questions, earn points and help others
