Question about Panasonic PT-53WX42 53" Rear Projection Television
Convergence- blue 3d
I have a panasonic 53wx53g. i took it in to a tv repairman, he said the convergence board was bad. at first he said it was about $400 then he said they didnt make it anymore. can you help me find the part i need.
  • Scott Lucero Jul 19, 2008
    Thank You for the help! I changed the two ICs myself. I bought the tools I needed and went for it. The TV is perfect now just needed to adjust the convergence and its good as new! Thank You again!!!
  • 4,234 Answers
The board may not be available, but hte defective components are. There is no reason for the service center to replace the bopard when a couple of ICs and resistors or fuses are all that are defective. The parts that are bad are large black ICs attached to a heatsink and are most likely marked STKxxx. He/.she should resolder the pins on these ICs first. That may resolve the problem. If not, replace the ICs.
Keep us posted.
Dan
Posted on Jul 07, 2008
I am getting a blurry picture that kinda makes it look like a 3d movie without the glasses on with alot of blue
The tv have a problems known as a convergence pictures problems.Tv have any colors lines R,G,B mis alignments,tv have any colors shadows pictures or have a 3D pictures look alike?Yes,than the tv convergence board it is the causes and already dead to have many of these convergence pictures problems.The tv convergence board must have to be repair like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures many problems.The tvs shops will cost u like $300-$350 for parts and labors.
Sep 07, 2011 | Panasonic Televison & Video
The blue coloring is way off center
Tv have a problems known as a convergence problems,it is dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?Yes,than the tv have a dead convergence board.The tv convergence board require changes 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The tvs shops will cost u like $300-350 for parts and labors.
May 20, 2011 | Panasonic PT-47WX53 47" Rear Projection...
The picture has double images and looks kind of like it is 3D.
The tv have a problems known as a convergence problems,it dead.The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.The tv convergnece board,must have these parts changes on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Dec 31, 2010 | Panasonic PT-47WX49 47" Rear Projection...
I have a Panasonic Multimedia Projection HDTV when tv is turned on it has red & blue color spots & red verticle lines showing on the screen what could be causing this to be happening
Tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignments,have shadows colors pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all it resistors are dead too.These parts on the convergence board,must be replaced to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 20, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Everything looks like its in 3D vision. Im pretty sure somthing isnt alined right so i was wondering what i can do to fix it.
Replace convergence output ICs in your tv to fix this 3D look picture, it happens due to convergence output chips failure.
Local tv repairman will fix it for you if you have no prior experience of part replacement in tv circuit board with proper tools.
Sep 26, 2010 | Panasonic PT-53WX53 53" Rear Projection...
MY PT-53WX53G turns off when powered on. The
Thats the error for convergence failure. Heres a link to the repair kit for your model which contains the parts and the CD with detailed instructions.
http://servicemanuals.vstore.ca/product_info.php/pName/panasonic-projection-tv-convergence-repair-kit-1/cName/convergence-repair-kits
Jul 06, 2010 | Panasonic PT-53WX54 53" Rear Projection...
I'm getting an overlapping of two colors on the screen.
It is common problem with rear projection tv and 3D type picture problem occurs due to failure of convergence output ICs, replacement of convergence output ICs will fix the issue and tv will again show correct converge picture as before.
Let me know tv model number written on back of tv if you want to fix tv by yourself as it needs soldering parts in circuit board expertise and if you feel uncomfortable working in tv circuit boards than local tv repairman will do this job for you.
Thanks.
Jun 30, 2010 | Hitachi 61SWX01W 61" Rear Projection...
Blue/yellow shadows
This is a common problem. Your convergence has gone out.
Common symptoms are...
1) 3D Video
2) Warped Video
3) Convergence menu does not adjust the red or blue correctly.
Go here for a solution...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Sep 06, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic 53wx53g rear projection tv
The ONLY place I know might have one is PTS Electronics: http://www.ptscorp.com/
Good Luck!
Bill
Sep 12, 2007 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic PT-53WX42 53" Rear Projection Television Logo
46 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
