Question about Whirlpool Washing Machines
The water drains out simultaneously as it fills itself automatically.
  • Whirlpool Master
  • 43,501 Answers
The hoses are not hooked up right ...
Here is a tip that tells you how to fix that problem...
Water will not stay in Washing Machine
heatman101
Posted on Dec 30, 2010
Why is water automatically draining as it is filling?
There is most likely a leak with water getting into the cabinet of the washer activating the anti flood switch which in turn drains all water out to stop flooding check for damaged door boot
Dec 21, 2014 | Kenmore Washing Machines
I have a ken more top loading washer it's new . The water is not filling up it's just going straight out
There isn't a normal path for water to just drain, it has to be pumped out.
Assuming you didn't turn on the timer to a cycle that allows the pump to run, the time may be defective since 'fill' and 'drain' shouldn't happen simultaneously, you may have a warranty repair need.
Dec 11, 2014 | Kenmore 24032\24036 Top Load Washer
My wash machine tries to fill, but it sounds like the pump is pumping it out as fast as it fills.
The number one suspect reason for simultaneous fill and drain would be that your washing machine drain hose is inserted into your wall drain too far. The drain stack pipe in the home should be as high on the wall as the top of the washing machine main top/lid, and the hose from the washer inserted no deeper than 10" and properly secured to one of the adjacent water shut offs with a zip tie. If this is your issue, your drain system in the home is creating a siphon through the washer drain hose and literally sucking the water out of the washer. Pleazer Appliance...
Apr 15, 2014 | Admiral Washing Machines
Water drains back through the fill lines.
THE COLD AND HOT WATER CANT GO BACK IN TO THE WATER VALVE ! NOW IF THE DRAIN WATER COMES BACK IN AFTER DRAIN MODE LEFT DRAIN HOSE UP A FOOT TALLER THIN THE WASHER OR CLEAN YOUR PUMP THIRS A CAP ON THE PUMP YOU CAN REMOVE TO CLEAN . NOW IF THE WASHE IS FILLING UP WITH WATER WHEN ITS OFF THE WATER VALVE IS BAD
Apr 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I need a manual for WA13UP Top load(samsung) washing machine
water running out at the draining pipe the while the machine fill itself with water
May 04, 2009 | Washing Machines
Washer fills with water, then stops
OBVIOUS REPL LID SWITCH AND SHOULD SOLVE YOURE PROBLEM 100 % MAYBE INSTALLED IN CORRECTLY,, TAKE A LOOK AT YOUR LID MAKE SURE BUMBER IS ON AND NOT TWIKED
Nov 29, 2008 | Kenmore 22422 Top Load Washer
Won't fill
Probably a siphon condition. Remove the drain hose from the wall. Now re-insert only 6" of it. If you put it too far down inside the wall it can cause an intermitent siphon condition. Make sure you tie down your drain hose so it does not pop out durring the drain cycles.
Apr 26, 2008 | Admiral AAV7000A
Water gets drained automatically without fills the water
HI there. You drain out pipe need to have a kink and the kink need to be higher than the highest point of when the machine is filled with water or else gravity will let the water drain out as you fill it up. HOpe it works.
Feb 05, 2008 | LG WFT1071TP Top Load Washer
Washer fills then drains
Daisy, check your drain hose going into the drain. It sounds like you have a siphoning problem. If the drain hose does not have a air gap the water filling will siphon right out. Check this first and post back, Catriver.
Sep 21, 2006 | Kenmore 98702 Stacked Washer/Dryer
Washing Machines Logo
Dan Webster
Dan Webster
Sal DeAngelo
