Question about Indesit Washing Machines
My indesit washing machine wie 167 uk has f-04 flashing and when filling water just runs through it when filling
4 Suggested Answers
Richie_asg1
  • 1036 Answers
SOURCE: Indesit WIE 167 says "test".
There is a fault on the program board. It more than likely needs a replacement.
Posted on Nov 05, 2008
beltronic205
  • 1461 Answers
SOURCE: Indesit wahing machine WIE 167 keeps filling with
You need to clear out pressure chamber the part the at tube plugs into the chamber it will be clogged, stopping air going to pressure switch...This should cure..
Posted on Oct 07, 2009
Chesc
  • 59 Answers
SOURCE: My Indesit Washing Machine (Model
F09 - Setup error
Book a washing machine repair
Posted on May 24, 2011
Indesit wie 147
I think you have to fill it with water first. My machine won't work unless the previous cycle has a chance to complete. i.e., it has to fill with water before the wash cycle starts, or it has to have water before it rinses/spins dry.
Mar 14, 2014 | Washing Machines
Indesit wahing machine WIE 167 keeps filling with water and did flash H2O have replaced the switch mechinism inside but to no avail tube is not punctured or coroded - will not go onto wash cycle but will...
Oct 07, 2009 | Washing Machines
Bearings on a indest wie 167 washing machine
You can download a user manual for your m/c, but not a repair manual, Go to>
www.indesit .co.uk
Follow the links. To remove the spider, remove the rear panel, remove drum belt, undo drum pulley, you may have to heat the screw holding the pulley,undo all screws that you can see holding the spider to drum rear.
Withdraw spider, you may have to use some force to pull it off.
Fit new bearings or spider, and reassemble..
plz rate this solution.
Dec 15, 2008 | Indesit WA 115 Front Load Washer
Indesit WIE 147 - Display 'F-03' fault
Indesit washing machine error code 3 (F03) On certain Indesit washing machines, if the on off light is flashing 3 times, with a slight pause, followed by flashing a further 3 times, or if it is didplaying F03 you have an error code that is explained as follows -
NTC fault - check Thermistor and module connections.
The NTC is the thermistor, which is a modern-day thermostat. It’s inserted into a tube in the heating element and is filled with heat sensitive crystals that change their electrical resistance according to their temperature. By knowing what electrical resistance the crystals have at given temperatures they can tell the water temperature.
With this fault the NTC is either faulty, or there’s a dodgy connection to or from it or there’s a connection problem where it connects to the main PCB.
It’s not something you can easily fault find yourself unfortunately, apart from if there was an obvious broken wire.
Feb 10, 2008 | Indesit W 123 Front Load Washer
Washing Machines Logo
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
