Question about Vacuums
Steamer doesnot work, no pressure - Vacuums
  • ronvh Dec 30, 2010
    it is aSaeco Starbucks Barrista
    ok, took wand off, blew air through it. turned machine on and when light came on I turned the dial to turn on the steamer.
    steam came out at a fairly high pressure but quickly the pressure dropped to almost zero (say 5% to 10%).
    Next check?
  • Vacuums Master
  • 19,396 Answers
Hi.
Heating and release of steam is usually regulated by a pressure switch, that will probably need to be replaced. The explanation is very general and may not apply to the specific model. To be more specific I need to know make and model of the steamer.
Regards.
Ginko.
Posted on Dec 30, 2010
  • Ginko
    Ginko Dec 30, 2010
    Hi.
    The problem was originally posted in steam washer. I am glad to see that the problem is concering a Saeco espresso maker.
    If problem is steamer only, then start checking the steam wand and the valve at the end of the steam wand. The valve is operated by the steamer knob mechanism. This parts may get clogged and may result in no steam getting out of the wand. Steam valve parts must be checked and eventually replaced.
    If apart from having no steam you also have no water pressure with brew being cold and/or watery, then the problem is different. In that case perform a complete descaling. Scale on top of thermostat and membrane sensor may preventing chamber from reaching the right temperature and pressure. If descaling does not help, then parts like pump, element and thermostat must be tested and eventually replaced. The thermostat for steam are the 127C and 175C ones.
    Here all parts and diagrams for Barista.
  • Ginko
    Ginko Dec 30, 2010
    Next check is taking apart the machine, removing the steamer valve connected to the knob. See the schematics in my previous comment.
    Before doing anything else perform a complete descaling.
    Also remember that disassembling invalidates warranty. I assume that machine is not covered by warranty anymore.
My unit heats up, has plenty of water, but will not spray, pressure is at 4
Sounds like a blocked nozzle. I would soak it in line Away or used a safety pin to clear it
Apr 28, 2016 | Vapor WhiteWing Steamer Canister Vacuum
I need a manual for the oreck floor steamer
Hi! Since you didn't mention the model type of your floor steamer, i'm giving you the link where you can see the user's guide for all oreck floor steamers. So, access this link (http://www.oreck.com/Owners-Guides) and go to the floor machines category (under electric brooms).
I hope this will work for you! Have a nice day!
Sep 02, 2011 | Oreck steam-it Stick Vacuum
Hi -- For my White Wing Steam Cleaner: After I plug in the unit, and wait over 10 minutes, the Pressure gauge shows that the pressure at 2 (maybe 2.5, I can't recall as I'm typing today) -- not...
Re: Low pressure on WhiteWing steam cleaner
1. Make sure the safety switch for the hose handle on the right side of the hose handle is turned to the closed position. To do that, push it away form the hose.
2. Make sure the steam release button (next to the on/off button on the control panel on the steamer) is in the Off position.
3. Make sure the safety cap is tightened.
4. Make sure you have enough water in the tank (at least half a bottle of water)
I hope this helps.
Jul 31, 2011 | Vapor WhiteWing Steamer Canister Vacuum
The steam in my handheld steam shot does not seem to be very hot therefore the surfaces, specially cloth ones do not get clean properly. What should I do?
If it steams it is as hot as it is going to get. Water steams at 212 degrees F at sea level so the only way to increase that heat is to pressurize that steam to a higher density than sea level which is about 32lbs per sq. in. Your steamer has no method to pressurize that steam to increase that heat. Conversely, as the pressure decreases, say you live in Denver which is about 5000 ft above sea level, then that steam will only get to about 203 degrees F. (See: http://whatscookingamerica.net/boilpoint.htm) Steam Cleaning at best is a poor method of cleaning as all it does is saturate the clothing item with water, which in theory loosens dirt, but no way is provided to remove the dirt. A rug shampooer has a vacuum that sucks the dirt away from the carpet along with the suds for a better cleaning method. In my opinion a hand steamer will only remove wrinkles at best.
Mar 20, 2011 | Bissell Vacuums
My euro pro s3300 shark steam cleaner heats up but doesn't steam when you press the button. It is gray in color and the light turns on and is hot to the feel. What is the problem can it be fixed by me or...
if you use it for more than an hour theres an automatic kill switch located on the inside designed to make you buy another one , but you can take it apart and hardwire it to bypass that kill switch , and your steamer will work once again.
Feb 23, 2010 | Euro-Pro S3325 Handheld Steam Vacuum
I need a new manual for dirt devil easy steamer deluxe
CLICK HERE for the owners manual in PDF format.
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
Jul 19, 2009 | Dirt Devil Easy Steamer Upright Wet/Dry...
My power steamer will not squirt water. Seems to
it migh be that the formula you mixed together is notcreating enough pressure to force the mixture out is it the formula the company sells or did you pick up some other formula
Jul 10, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
SC505H Portable Steamer with broken hose in the handle
I also have the Shark steamer worked great for a while lots of pressure but then pressure started coming out of the insert part for the wond not sure if its the o rings that need replaces or just the wond it self can any one help me
Jun 24, 2009 | Euro-Pro Shark SC-505 Handheld Steam...
No steam in scunci steamer will not work lights uop hear pressure and heats up
no steam in scunci steamer, it does gets warm but no steam at all. like if it was blocked
Aug 29, 2008 | Scunci 52001 Handheld Steam Vacuum
Scunci ss1000 handheld steamer
My Scunci MS 1000 heats and builds up steam, but the steam does not release from the spout when the release button is pushed. Plenty of pressure is built up inside (escapes when cap is opened). What is the problem?
Aug 03, 2008 | Scunci 52001 Handheld Steam Vacuum
Vacuums Logo
24 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
