Question about Cooling System for Volvo S60
Keeps on saying coolant low but have no leaks and runs hot
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Volvo Master
  • 1,949 Answers
Check sensor in over flow tank sometimes tapping on it will unstick the sensor /or replace
Posted on Dec 30, 2010
My temperature guage stays in the middle, is this ok?
Yes, the temperature gauge should normally stop in the middle, between the cold and hot points on the gauge. When the engine is cold the thermostat will be closed and will keep recirculating the coolant in the engine block until it warms up sufficiently. Then the temperature of the warm coolant will cause the thermostat to open the channel to the radiator to get rid of excess heat, which should stop the coolant from over heating. So the effect of the thermostat keeps the coolant at a fairly stable temperature. When the coolant runs low, it can't transfer enough heat to the radiator and the coolant and engine then over heats. Watch for radiator leaks under your car after you have been driving it. If the coolant goes low again fairly quickly you could have a leak in a hose or the radiator itself.
Apr 19, 2013 | 2003 Mazda Protege
Coolant ran out of the bottom of the car. Nechanic found hose leak. Car is running rough while sitting. Could it be a Gasket?
if you haven't had any coolant in your car for a week and you have been driving it you may have blown your head gasket, even though you haven't got 'milkey goo' on your oil dip stick. check for goo under your oil cap to see and have it tested at a garage. but from what ive read im almost certain its your head gasket. hope this helps you and beware of the dangers of a running engine so keep hands and loose clothing out of the way of moving parts and engines get very hot so be careful what you touch.
Feb 11, 2013 | Volvo S40 Cars & Trucks
1999 grand am low coolant light on but temp on car is not running hot
the low coolant sensor is located inthe over flow bottle thay go bad
Nov 07, 2012 | Pontiac Grand Am Cars & Trucks
2002 saturn sl1 blows hot air when ac is on heater works idles and coolant leeks out just bought a new radiator still not working
Not sure where to start with this - - if you are saying the engine is running hot could be a thermostat or low coolant or other issues.
The hot air with the ac on could be the ac not being charged or a blend door stuck in one position.
Where is the coolant leaking from ?
Oct 06, 2012 | Cars & Trucks
My oldsmobile aurora 1996 keeps saying low coolant level and is leaking.
It's the upper and lower manifold gaskets, take it to a service shop and get them to replace your manifold gaskets, it's not the water pump
Sep 27, 2017 | 1996 Oldsmobile Aurora
The light came on looks like a pipe of some sort and the screen keeps saying coolant low.
I don't know what the 'pipe' means but if the coolant low screen comes up, I would add some coolant (50/50 concentration coolant to water) to the overflow reservoir or to the radiator, whichever is easier for you.
If it is a false coolant low indicator, then I wouldn't worry about it unless the engine overheats or runs too hot.
Good luck on this repair.
Dec 17, 2010 | 2002 Jeep Grand Cherokee
My car keep over heating
Some things to look for if your car is overheating: THermostat stuck in the closed position, cracked head, blown head gasket, leak in radiator, punctured hose, low coolant, cracked block.
Examine the cooling system for obvious leaks in any hoses or parts of the radiator. Let the car run until hot and check the upper and lower hoses. They should both be hot and firm to the touch when the thermostat opens. If the top one is hot and the bottom one is cool and flexible then coolant isn't flowing through the system which most likely is a stuck thermostat. If the coolant level is low you have a leak spomewhere in the system. Have someone pressure test the system if you can't do it yourself. Good luck!
Aug 20, 2010 | 1992 Lexus Ls 400
I have a 1989 Pontiac Bonneville that is running hot after water pump replacement. I found out that after replacement I should have driven it to seal the gasket. Was that too damaging or could it be...
First off you never have to drive to seal any gasket! If it did not run hot before the replacement of the pump it should not run hot now unless something is defective or improperly installed.Presure test the system for leaks first and repair any leaks before doing anything else.Be sure to make sure that the Head Gaskets are not leaking as well!
Aug 05, 2010 | Pontiac Bonneville Cars & Trucks
I have a 2000 Olds Silhouette that keeps running hot. The thermostat keeps going between the 1/2 mark (when driving) to just above the 3/4s mark (when sitting still). I replaced the engine, radiator, and...
First make sure your cooling fans are working properly. As far as the coolant having to be added there has to be either a leak externally or internally on the engine unless your letting it get hot enough to boil over into the reservoir tank. One way to find a leak quickly is to do a pressure test of the coolant system. You will need a special tool to do this. It attaches to the radiator filler neck and you use a small hand pump to pressurize the coolant system to the rated psi on the radiator cap. If you don't have the tool you may be able to rent it from an auto parts store that has a loan-a-tool program. If not a repair shop can do it for you. Once you start to pressurize the system if it's leaking externally you should see it or hear it or both. If you don't then your leak may be internal meaning a possible head gasket leak. Even though your car is running fine a small head gasket leak can cause it to run hotter than normal and loose coolant. Also don't rule out the other items in your coolant system if you find no leaks like your thermostat, water pump or something as simple as a good coolant system flush may be all you need. One note, if you do the pressure test your self and your system will not hold pressure but you find no external leaks, that's another indication of a possible head gasket leak. Once you pressurize with the tool a good coolant sytem it should maintain pressure and not bleed off. Hope that helps, gl.
Nov 20, 2009 | 2000 Oldsmobile Silhouette
Cooling System for Volvo S60 Logo
98 people viewed this question
Top Volvo Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Volvo Vehicle Part and Accessory Expert? Answer questions, earn points and help others
