Question about Dishwashers
No water getting into dishwasher; pump is working
  • Dishwashers Master
  • 43,501 Answers
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble
No Water entering Dishwasher
heatman101
Posted on Dec 30, 2010
The dishwasher tablet is dispensing but is not dissolving or washing the pots. Can you tell what is wrong with it please
I would suggest getting some dishwasher cleaner and run a cycle to make sure you aren't having issues with water flow. Poor water flow built up by mineral deposits can wreak havoc on dishwashers. Wal-Mart carries dishwasher cleaner at a good price.
Just so you know, there may be a water pump issue as well. I would try the cleaner first and, if that doesn't work, then your water pump may be failing or you aren't getting enough water to the dishwasher itself.
Hope this helps.
Mar 16, 2016 | Dishwashers
Does not wash
9 times out of 10 when I get this call there is glass in the pump motor. Remove the pump underneath and spin the impeller a few times. Look inside the casing for debris. Put pump back on. Also take apart the spray arm and assembly inside and clear of any debris. It should work now. I hear this problem all the time. Good luck :-)
Nov 28, 2011 | KitchenAid Dishwashers
Dishwashing detergent isn't dissolving
Either:
  1. the water does not get into the dishwasher open the dishwasher 3-4 times during cycle, you should see some water at least once, if not - check water valve, water level float and water pressure.
  2. the pump is clogged - there is water, the motor will run but no water is circulated. Check pump filters, check chopper and impeller.
  3. motor in main pump is not working - could be caused by something stuck on the impeller or chopper or could be a problem with the motor itself or control board. Check if line voltage is coming to the motor during wash/rinse cycle.
Good luck,
Vlad
First Choice Appliance
Jan 18, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
I have beko dishwasher works fine but no hot water is it just the element which needs replacing or could it another problem MODEL DWD4310S
How far is your water heater from your dishwasher. I knew someone who had to get a circulating pump. His dishwasher was so far form the water heater so when the dishwasher would fill, it used the cold water that is sitting in the pipes and by the time the hot water got there, the dishwasher didn't need any more water. the pump will keep the water circulating back and forth to and from the hto water heater. Or you an get one of those electric small heaters that heat on the spot as well.
Dec 10, 2009 | Beko Dishwashers
DWF 415 Ikea Whirlpool Dishwasher as constant
DWF 415 Ikea Whirlpool Dishwasher has constant green blinking light. Drain pump works ok (as it will pump out a jug of water if I tip it into it!) but no water comes in. Cycle stops about 30 seconds after thre is no more water to pump. Any ideas on how to fix?
Oct 09, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Kenore Elite Dishwasher
Either:
Good luck,
Vlad
Sep 22, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
My dishwasher is not filling w water
check filter or drain hose it probably have a dirt,try to fill with water manually and turn on pump to dispossess water,if water not go out and pump work then you have dirt in hose or filter,if pump not work then pump is broken.
Jul 05, 2009 | Neff 24 in. S5443X2 Built-in Dishwasher
Will not wash
sounds like the circulating pump. could be a foreign object stuck in the pump impellor. could also be the pump capacitor - cheap part
Sep 03, 2008 | Kenmore 24 in. 16693 Built-in Dishwasher
Kitchen aid dishwasher
Either:
Good luck,
Vlad
Sep 01, 2008 | KitchenAid KUDMO1FK - Multiple Color...
Neff dishwasher continuously attempting to pump out water
I have just encountered the same problem on my S5433 XO GB/13. Did you manage to get a solution.
Jan 17, 2007 | Neff 24 in. S5443X2 Built-in Dishwasher
Dishwashers Logo
70 people viewed this question
Top Dishwashers Experts
