I can not disable touchpad of INSPIRON 1545 of DELL Computers There is no option for disabling touch pad in the MOUSE option of Control Panel
    Sergeant:
  • 223 Answers
Go to the Control Panel. Under the 'Hardware and Sound' options, click 'Mouse'I can not disable touchpad - immortal4u.png
Since you have a Dell laptop, you'll have a special tab called 'Dell touchpad' in the window that pops up. Click on the touchpad picture in the window.
In the new window that appears, click 'Device Select'
Click on the 'Disable' radio button to disable the touchpad completely. If you want to disable the touchpad of your Dell laptop only when an external device like a mouse is attached, check the last option that says 'Disable Touchpad/Pointing Stick when external USB mouse is I can not disable touchpad - immortal4u_2.pngr />immortal4u_2.png
That's it. You've disabled your laptop's touchpad for good. If you don't find an option to manage your touchpad in Mouse settings, you have to install Synaptics drivers from here. Similar options can be found in other laptops as well.
Good luck ! if your problem is solved don't forget to rate
Posted on Dec 30, 2010
Go to Dell website and download the driver for the touchpad. Then you can disable the touch pad from the Icon tray.
Posted on Sep 26, 2011
How to enable touchpad I disabled by mistake and
Step 1: Click on Start and then click on control panel.
Step 2: Hardware and Sound......Devices and Printers....Mouse.....Mouse Properties.....Device Settings.....Touchpad.......Enable........(Windows 7).
In Windows XP
Dec 18, 2010 | Dell Inspiron 1545 Notebook
My my touchpad doesnt worrks
----- control panel - mouse - see if touch pad disabled there ----- have a look in the bios/setup and see if the touch pad is disabled there, as the PC boots - you should see which key to use to enter the bios/setup F2, F10, DEL KEY are often used ----- On some machines a combination of FN and F key can disable/enable the touch pad - F7 or F9 ----- If you point the mouse to the top of the screen you may get a menu dropdown, which will also tell which key to use to disable/enable the touchpad ----- control panel>system>{vista}lefthand side device manger or {XP}hardware>Device Manager>Mouse and other pointing devices>Touchpad>highlight touchpad and right click, Properties, option here to Disable,
Feb 23, 2010 | Dell F3534 Touchpad
How do I disable touchpad when mouse is used DELL 1525 vista home
Follow these steps to change the touchpad settings on your laptop:
1. From the Start menu, click Control Panel. With Control Panel in Category View, click Printers and Other Hardware.
2. In the Printers and Other Hardware window, click the Mouse icon.
3. In the Mouse Properties dialog box, click the Device Settings tab, and then click Settings.
4. There is a setting calleed "Disable Touch Pad when USB Pointing Device is present"
Jan 28, 2010 | Dell F3534 Touchpad
HOW TO DISABLE TOUCH PAD DELL LAPTOP
You should have a "FN" key on the keyboard and one of the "F" keys should have a symbol that looks like the touch-pad, hold FN while using this key should disable it, failing this in control panel, then mouse and pointers, you should have touchpad setting there should be a disable button/radius.
Sep 04, 2009 | Dell Inspiron XPS M140 Notebook
Dell Inspiron 1545: I accidentally disabled the touchpad and can't get it to enable again.
ok so if your touch pad isn't working you need to get in to your control panel there look for device manger then look for the disable touch pad and enable it hope this helps
tip plug in a external mouse so you can get to the control panel
Jul 29, 2009 | Dell Computers & Internet
How do I disable the touchpad?
Try disabling the touch pad in the device manager. If that don't work unplug it from the motherboard. You will have to take the bezel and the keyboard off to unplug the touch pad.
Jul 11, 2009 | Dell Inspiron 1521 Laptop
Inspiron 1545 "t"key randomly opens new tabs
This is caused by the touchpad zoom feature; when it is enabled, brushing the touchpad registers a pressing of the ctrl key. Disable touchpad zoom and this behavior should stop occurring.
Apr 16, 2009 | Dell Dimension 8400 power supply ** FREE...
DIsable touch pad on Inspiron 1501 laptop with XP
You should see a touch pad icon in the task bar. Right click it and disable device in the device select tab. Good luck. Let me know how you made out, and please rate my answer.
Jan 20, 2009 | Dell Inspiron 1501 Notebook
Touchpad/mouse problem
Same thing here, I can not find out how to diable the touch paid. I spent an hour chatting on-line with Dell Tech support and they did nothing to help!! I am starting to think it can not be done on this machine. Please someone tell use how to do this?
Jul 10, 2008 | Dell F3534 Touchpad
Computers & Internet Logo
3,995 people viewed this question
David Payne
David Payne
