Question about Asrock P4VM8 Motherboard
Where is the ram memory slot in my p4vm8 motherboard
    Genius:
  • 1,288 Answers
Http://www.asrock.com/MB/overview.asp?Model=P4VM8
The TWO blue long connectors on the board with clips at either end are the ram slots, this model uses DDR1 ram, make sure you align the ram module correctly in the slot
Posted on Dec 30, 2010
What is the max size of ddr400 memory you can fit into ddr1 & ddr2 dimm slots on a p4vm8 mother board
1) Total maximum amount for motherboard is 2GB.
2) There are 2 Ram Memory slots.
3) Maximum amount for EACH ram memory slot is 1GB.
Either DDR Sdram at 266MegaHertz, or 333MHz, or 400MHz.
PC2100, PC2700, and PC3200, respectively.
http://www.asrock.com/mb/VIA/P4VM8/
There is no DDR1 and DDR2 slots, in a manner of speaking.
May be marked on your motherboard that way, but stating it that way on a computer product support website = No.
You're going to make someone think, you don't know what you are talking about.
They may think you are referring to DDR Sdram, and DDR2 Sdram, and they know the motherboard only uses DDR Sdram ram memory.
Suggest state Slot 1 and Slot 2; or DIMM 1 and DIMM 2.
For additional questions please post in a Comment.
Regards,
joecoolvette
Mar 18, 2013 | VIA ASRock P4VM8 P4(S478)/...
What's your problem?bit ix38 quad gt motherboard with 2 gig of ddr2 ram i want to add a 1 gig stick of more ram that ive bought how do i do this? thanks windows seven
Top view of motherboard, scroll down. (Thought you might also like to read the reviews, and Comments)
http://www.bit-tech.net/hardware/motherboards/2007/12/06/abit_ix38_quadgt/2
Motherboard User Manual,
http://www.theraptorpit.com/forum/index.php?/forum/124-abit-motherboard-tech-support-unofficial/
1) On the motherboard the Blue ram memory slot that is closest to the copper heatsink, is ram memory Slot 1.
Also known as DIMM 1.
Ram memory ALWAYS has to be in this ram memory slot.
The Processor reads ram memory Slot 1 first.
2) The Blue ram memory slots are Slot 1 (DIMM 1), and Slot 3.
(DIMM 3)
The Black ram memory slots are Slot 2 (DIMM 2), and Slot 4.
(DIMM 4)
To run Dual Channel ram memory, means there are two LIKE ram memory modules ('Stick'), and they are installed in the SAME channel.
This would mean to alike ram memory modules, in both Blue ram memory slots, or both Black ram memory slots.
Since the ram memory modules need to be alike, they are generally purchased from the same manufacturer, and are the same kind.
Running ram memory in a dual channel configuration, is supposed to increase ram memory 'speed', up to 30 percent.
This is Baloney!
May look good on paper, but in actual use in the field it's cr@p.
Actual performance increase is more like 1 to 2 percent.
This has been proven by Tom's Hardware, and many, many motherboards, ram memory, Processors, etc.
So you have 2GB of DDR2 Sdram, huh?
Is it just one 'stick' of ram memory, or are you referring to two 1GB sticks?
If the above holds true install them in Slot 1 and Slot 3.
If not, and it is a 2GB stick of ram memory, be sure it is installed in Slot 1 (DIMM 1)
Install the 1GB stick in Slot 2.
It isn't the same as the 2GB stick.
It is 1GB.
Does NOT go in a dual channel configuration.
(Catching all this? There is NO dual channel ram memory!
It is ram memory that is -> ALIKE, and used in a -> dual channel configuration.
Used in two separate ram memory slots, that support the dual channel configuration.
Sold with the advertising scheme of 'Dual Channel', but really just means the two ram memory modules, (Or four), are -> alike.
1) Same Voltage used
2) Same Ram Timings
3) Same Chip Configuration
4) Same size in amount
5) Same frequency rate ('Speed')
With ram memory in a dual channel configuration, the ram memory modules team up on the task.)
Regards,
joecoolvette
Oct 31, 2012 | Computers & Internet
My problum is when i attached ram 1 gb after its system restart and show belue screen and i sure my rem is ok tell me what is problum here????
A) FixYa T.O.S. (Terms of Service) states to NOT post your email address.
The TOS is read when you join.
B) How about posting the MOTHERBOARD manufacturer name, and Model Number?
Also post what ram memory ,manufacturer, and manufacturer code on the ram memory module.
Ram Memory HAS to be in Slot 1. (May state DIMM 1 next to the ram memory slot. Can also be Slot 0, or DIMM 0 )
Slot 1 is the ram memory slot nearest the Processor.
A Processor reads ram memory Slot 1 first.
Do you know;
1) What is the Maximum TOTAL Amount of ram memory, for the motherboard?
2) What is the Maximum Amount for EACH ram memory slot?
3) What type of ram memory is supported?
For an example;
Can it use DDR Sdram at either 333MegaHertz, or 400MHz?
(PC2700 and PC3200, respectively)
4) What ram memory slots have you put ram memory in?
Post back in a Comment.
Regards,
joecoolvette
Feb 18, 2012 | Computers & Internet
BSOD keeps on flashing during installation of Win XP
I think the problem is with your RAM installed, try to swap other memory on your computer or try your RAM to other PC to determine if its working.
Jul 11, 2010 | Asrock P4VM8 Motherboard
List of graphics card for asrock P4VM8
hi
this moptherboard has PCI slot you can go for any of PCI graphic card
May 21, 2010 | Asrock P4VM8 Motherboard
Asrock p4vm8 beep codes
How does it sound? Does it beep with memory card seated? one long- 3 shorts beep bad graphic card, one long repeated 3 times bad memory card
Apr 12, 2010 | Asrock P4VM8 Motherboard
Vga
try to connect PC speaker and listen his sounds for diagnostics
  1. one short - system is good
  2. one long, three short - poor video card
  3. three ore more long - poor memory RAM module.
Mar 01, 2009 | Asrock P4VM8 Motherboard
Memory upgrade for Windows Vista
Yes this motherboard supports up to 2GB of RAM so you can use 2 stick of 1 GB to those slot ...
Jan 16, 2009 | Asrock P4VM8 Motherboard
Graphics card:Nvidia EN7300GE
The Asrock P4VM8 motherboard does not have a PCIE slot. Only a AGP. Listed below, click the link:
http://www.asrock.com/mb/overview.asp?Model=P4VM8
Unless you have given the wrong information. Please clear this issue before I can help.
Feb 08, 2008 | Asrock P4VM8 Motherboard
Asrock P4VM8 Motherboard Logo
55 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Computer Links
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
