Question about Tecnik TKR6265 Stainless Steel Bottom Freezer Refrigerator
Light on but no freezer working - Tecnik TKR6265 Stainless Steel Bottom Freezer Refrigerator
  • 5,370 Answers
Is the freezer temperature getting set?Is the ice maker making ice?Also is the refrigerator working properly?If only the freezer is not working but refrigerator is cooling properly then it can be problem with temperature control and thermostat.First check the thermostat.If its faulty then temperature will not get set on required temperature.But if temperature is getting set in freezer section and its not cooling properly,then check the evaporator coils in the freezer inner section.If there is over frost build up in the evaporator coil section then its defrost assembly fault.Also check if the fan in the freezer is running.If its not running then the fan is problem and it has to be replaced. Before doing any thing first try the manual defrost procedure:---
First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. It will take near to 4 hours to get run in its proper cooling cycle. Then check, if the problem returns again. If the same problem occurs then it's defrost problem. The defrost board and the defrost thermostat/heater is not functioning properly and it has to be checked and replaced.You can get the required parts from online sites like:---
www.repairclinic.com or from searspartsdirect online site.---------This will help.Thanks.Helpmech.
Posted on Dec 30, 2010
What is the orange light for on unidentified freezer?
If that orange light is on the front of the freezer, on the top or bottom, it is very likely a light telling you the freezer is not cold enough inside, and the food is in danger of spoiling.
It may also be a "on" light.
If you will find a freezer thermometer and put it inside, you can tell whether it is an "on" light or a warning light.
Usually freezers run temperatures of about 10 degrees Fahrenheit or lower if they are working correctly.
God bless your efforts.
Feb 11, 2016 | Freezers
Freezer doesn't work
my freezer defrosted it self and the red tryangle light stays on what is it
May 05, 2010 | Hotpoint 4.2 cu. ft. / 119 liter Upright...
Green light does not come on for settings 0 to 4
the ice cream is the clue,if it goes hard then the temp is too low (ice cream best kept at -18C)
either the defrost is not working or interior temp sensor duff.
Mar 26, 2010 | Engel Freezer 22 Qt. Fridge/Freezer
I have a ge gss22kgpacc side by side, the freezer is working, lights, etc. all working, but the refrigeratoe side is not working, any insight? thanks, mike
on most units they have two controls refrigerator control is electric t-stat that runs compressor freezer control think of it as a door colder freezer door is barely open warmer freezer door all the way open all cooling coils are in the freezer and a fan moves the air to refrigerater side possible problem fan not running
door freezer control all the way closed
light switch broken light staying on door gasket not sealing tight find door switch press verify light shuts off and fan starts
look for torn or damaged door gasket can look from outside with light and see if gasket contacts case on all four sides
freezer is cold enough so compressor is ok hope this helps good luck ron
Dec 12, 2009 | GE Refrigerators
Model gss20iepcbb freezer side works fine ...fridge
freezer is cold enough so compressor is ok hopr this helps good luck ron
Dec 10, 2009 | Refrigerators
No light in refer but works in freezer
Check the door switch to see if is working and try another light bulb or try the light bulb somewhere else to see if the light bulb is good. Check to if vent holes coming from the feezer are blocked by something in the fridge. This will make it feel like your fridge is not working.
John
Sep 28, 2009 | Smeg FAB32 Bottom Freezer Refrigerator
My chest freezer shut off (the outside light was
Try to plug somthing that you know it works ,in that outlet ,and if it doesn't work or goes on and off , the problem is in the outlet, but if works without trouble ,the problem could be in the freezer plug , the cord or the cord conections to the freezer.
Sep 13, 2009 | Kenmore Freezer 8.8 cu. ft. Chest Freezer...
Bottom freezer suddenly had condensation and light wasn't working
That could be the fan in the freezer with ice build up in the area of the evaporator coils which would indicate a problem with the auto defrost system the evaporator coils are behind the back panel of the freezer .
Aug 30, 2009 | Amana ABB1927DE Bottom Freezer...
Kenmore refridgerator 78285892 Freezer light won't work
probably a bad socket. 10-12 years old metal would not likely to last inside a freezer box.corrosion could have eaten the metals...
Feb 11, 2008 | Refrigerators
Tecnik TKR6265 Stainless Steel Bottom Freezer Refrigerator Logo
62 people viewed this question
Top Tecnik Refrigerators Experts
Rick Arnold
Charles T Nevin
Charles T Nevin
Steve Oakes
Are you a Tecnik Refrigerator Expert? Answer questions, earn points and help others
