Hello, spd071980 and thank you for asking your question on Fixya!
Here is a simple process that will walk you through a few steps that
will pinpoint the overheating problem on your 2005 Land Rover Range Rover,
without even using any tools. It has helped millions of people, and I am
certain that it will help you, because I wrote it for people in your exact situation.
How to diagnose an overheating 2005 Land Rover Range Rover
Pay close attention to the Block test part of the instructions.
Get more great money saving tips and tricks about your vehicle from: twitter.com/acoates23234
Thanks for the vote, and good luck!
Oh, here are some cool money saving links, if you are interested:
Insurance for $34 a month
Never pay for auto repairs again!
Hello and welcome to FixYa!
If you have overheating problem, it can lead to multiple
issues. You may be running on low coolant that's why the vehicle overheats. If
that's the case, please add coolant and make sure that it sits on the right
level, too much coolant can cause overheating too for coolant will overflow.
The vehicle may have a faulty or worn out radiator blower
motor that's why it overheats. If that's the case then you will need a blower
motor replacement to resolve the issue.
If the radiator is clogged with dirt and rusts this issue
occurs too. The coolant doesn't flow normally on the cooling system if it's
clogged. If that's the case, I strongly suggest that you have the radiator
flushed to drain out dirt and rusts. If you think that the radiator served you
enough then it's better to have it replaced.
Please do check the radiator hoses, If you have worn out
hoses it can cause coolant leakage which can result to overheating. A tiny hole
is good enough for the vehicle to overheat.
A faulty thermostat sensor can cause the issue too. If you
have worn out thermostat, the fan may not trigger that's why the fan won't work
when under stressed conditions. A blown radiator blower fuse can cause this
issue too so I suggest that you check the radiator blower fuse and replace it
when necessary. What causes the radiator blower fan fuse to blow? It's because
of a failing radiator blower motor, If that's the case have the radiator blower
fan motor replaced.
Hope you find this information helpful enough and thank you for using FixYa! Have a good one!
