Question about Panasonic Viera TH-42PZ80U Plasma TV
I recently purchased a Panasonic TH-P46G10a flat screen TV but the headphone connection (located on left side of TV) does not work. There is no sound through the head-set (have tried 3 different sets) and the sound does not cut off on the TV. Is this an equipment defect or is there something that needs to be 'switched on' through the menu? Can anybody advise? Thanks.
otacon
  • 1944 Answers
SOURCE: Panasonic TH-37PX70BA
Yes there should be a headphone conenctor.
Posted on Apr 13, 2008
  • 7 Answers
SOURCE: Connecting Sony PS2 to Panasonic HT32LZD85
First off you need to retire that ps2 and join the PS3 revolution, well worth the money although with the recent drop of the inferior x-box 360 the PS3 may follow suit shortly.
Now, I'm gathering from your discription limited as it may be that you had an adapter that connected the the stock cable that was included with your ps2 which consists of the end that interfaces with the ps2 and the end that is ment to provide the signal to your tv which includes your composite video (yellow) and your left and right audio (red&white).
If this is case then it should be a simple matter of removing the adapter that changed the source (ps2) signal to aerial and pluging the yellow red and white cables direct to your tv (standard imputs at the rear of the television should be video 1,2,3 ect.
Then just make sure your tv is on and set to the correct imput and you should be rockin and rolling in no time.
Posted on Oct 03, 2008
  • 8457 Answers
SOURCE: Panasonic plasma viera tv will not auto tune, can
Reboot all cables,satalites,and telicoms boxes.Like unplug,replug the box an hour later.Let the boxes up grade software,go to ur tv menu setup rescan all channels again well get them back.Ur signal not there after that, than ur Tuner Signal board is dead.Need it replaced.
Posted on Mar 13, 2010
  • 33 Answers
SOURCE: I want to connect wireless
Most TVs these days do not come with headphone out jacks. If your TV has RCA audio out, you can get a RCA to Headphone jack.
If your TV has no audio outputs at all, you're out of luck.
If your TV is equipped with audio out, there will be an option in the speaker or sound menu of your tv to turn off internal speakers and transmit directly to external speakers. If there is no audio out on your tv, this will not be an option.
Posted on Mar 11, 2011
SOURCE: Sony Viao HDMI to Panasonic Plasma TV HDMI Input handshake
My TV turns off while watching and message pops "Plasma no signal " . Please tell me what to do . Thank you
Posted on Jul 11, 2011
Apr 13, 2008 | Panasonic TH37PX60 37 in. Plasma...
Panasonic plasma TH-42pz700 has left hand side of screen distorted
The set uses two boards to drive the screen --one for each half or side.
Different names are used like sustain or in LCD sets inverter.
Apr 02, 2012 | Panasonic Viera TH-42PX80U Plasma TV
Whereis the headphone socket in panasonic viera th-42pz85u?
hi,
ur tv doesn't have a headphone connection. it only have an RCA audio out. if u wish to use head phone with ur tv, then bought a head phone amplifier and connect it to the audio output of ur tv.
ok
Dec 17, 2010 | Panasonic Viera TH-42PZ85U 42 in. Plasma...
How to connect headphones to this tv.
The only way to accomplish this will require an external amplifier.
Connect the program out to the input of the external amp and use the headphones from there. Disconnect the speakers or turn them off in the audio menu.
Hope this helps,
Dan
Jul 11, 2010 | Panasonic TH-42PX60U Television
Panasonic plasma viera tv will not auto tune, can not pick up any signals at all. All cables are plugged in correctly. Model number TH-P46G10A
Mar 13, 2010 | Panasonic Viera TH-46PZ85U Plasma TV
Sound distortion comes and goes...
First of all, try to have this repaired under warranty. Usually these sets have a 1 year warranty. Second, make a recording of the problem. That will help the servicer to understand the problem.
If you are not successful at the warranty repair, the first thing to look for is a power supply problem or poor connections at the audio amp area. I will attempt to locate more details while you persue the warranty claim.
Please keep us posted.
Thanks,
Dan
Sep 19, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
Panasonic Plasma TV not working properly
It sounds like your Plasma was dropped on the right side and some of the internal wires came lose from the circlet board. 1. Is Panasonic or Vendor willing to replace it; if not, I say go ahead and open it up and see if you can find the damaged circlet. 2. Easy way trash it and purchase a new one just not from the same vendor.
Jun 21, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Panasonic Viera TV with black band on left hand side
disconnect the x and y sustain boards from the power supply. then check the flex connector to the screen and reseat them. check connections on c boards at bottom and screen connectors. reconnect the power supply only after all flex cables are reconnected or charge from supply will burn flex cables. if still preent replace correcsponding c board. if still no fix replace panel.
Apr 25, 2009 | Panasonic TH-42PX60U Television
Yellow lines going down the side of the screen
It's a warranty issue. Back to the dealer for replacement.
Dec 27, 2008 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Panasonic Viera TH-42PZ80U Plasma TV Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
