Question about Sony DCR-HC52E Mini DV Camcorder
My lcd touch screen doesn't work. According to troubleshot, I make calibration rule connected with ac adaptor. But it can be use a few minute, next time reopen screen rehappen like previous (not usable), Pl help on my need.
  • 90 Answers
There is problem with the battery .try another one.your cam is not able to remember the settings for long time.
explanation
when you plug in ac supply and do callibration,it works fine.after you remove ac power.capictors are charged for 5min.thts why it can retain settings for few minutes only or when you reopen lid.
Posted on Dec 30, 2010
Touch screen not working
The same thing happened to mine all you have to do is unplug you're car battery then plug it back up then it should work but first u have to calibrate before it works should calibrate very fast
Feb 15, 2013 | Soundstream VR-738NB 7-Inch Lcd...
How to calibrate the touch screen on my innotab
1. Take the batteries out of the toy and press and hold the power button for 1 minute. (Awkward silence on the phone for 1 minute.....). Then put batteries in and start it up again. Try the screen again. If that doesn't help: contact supplier.if my suggestion was helpful please rate it.
Jul 02, 2012 | Cell Phones
My sony ereader prs-650 is stuck on sleep mode and it wont do anything ,, it wont charge when connected to the computer
The Sony Reader used a special type of display; the LCD can retain an image without having power. It takes power while changing the pages. In most of the cases, if the power is fully discharged, the LCD will keep the last image that was displayed it makes an impression that the Reader is frozen. However, the Actual thing is, the screen retains the last image on the screen and there is no power to change the pages. These type of situations can be resolved by charging the Reader sufficiently.
Each step in my solution is a possible resolution. Hence I suggest that you perform each step and check the operation.
Charge the battery fully by connecting to a computer or by using a compatible AC Adaptor. It may take a few minutes (up to 15 minutes) to display the charging symbol if the Reader is fully drained in its last use.
Once the reader is charged fully (at least 45 minutes), slide the power button to turn ON.
Perform a soft reset. We can perform a soft reset by pressing the reset button on the Reader.
After the RESET button has been pressed, slide the POWER switch to activate the Reader device again. If the Indicator light next to the power button on the Reader device is yellow, the unit is attempting to start up. If this is the case, allow it a few moments to complete startup.
If the Reader is still not charging up properly, connect the Reader to computer or AC Adaptor and then press the reset button.
Disconnect the Reader device from the computer (if applicable) and then slide the POWER switch to activate the Reader device. Check if the Indicator light next to the power switch on the Reader device is yellow (indicating it is turning on) and if the unit is responding
If the unit is still frozen, connect it again to the computer or AC adapter and while connected, check if the Indicator light next to the power switch on the Reader device is red . If this light is red , allow the Reader device to charge for one hour so there is sufficient charge for troubleshooting.
If the issue persists, perform a hard reset to resolve the issue. Please follow the steps to perform a hard reset:
Under certain circumstances, moisture condensation can occur. Moisture condensation can be caused by moving the Reader device between temperature extremes or if the Reader device has come in direct contact with moisture. If you suspect moisture as the cause, allow the Reader device to sit for a few hours before attempting to turn it back on
Jan 12, 2011 | Sony Reader Touch PRS-600
My Sony Cybershot DSC-N2 touchscreen will not work.
if the initialize and calibration settings cannot be accessed if the touch screen is not responding, try to power reset the camera: turn cam off, remove the battery, make sure the cam is not connected to an optional ac adaptor, set mode switch to play, press and hold down the power button for a minute, let go and turn cam mode back to off, reinsert battery and turn cam on. if touch screen is still not working, unit may require service. hope this helps. thanks:)
Aug 25, 2010 | Sony Cyber-shot DSC-N2 Digital Camera
I have a HP dv7 laptop it does not work with the ac adapter but worked with the battery, whenever it is working with the battery and the ac adapter is connected it shuts down.
Remove the battery and plug the ac adaptor in check wethere the light on the port where you connect the ac adaptor glows or not, if no then check the wethere the ac adaptor is getting warm or not after you plug it in for few minutes if not then ac adaptor has to be replaced.
If the light on the port is glowing then it is likely that the power supply of the notebook has gone bad as it is not able to switch to ac adaptor or the port where you connect the ac adaptor to the notebook has a short circut when the acadaptor pin is connected , better try with a different ac adaptor to be sure wethere the issue is with ac adaptor or the notebook.
My best wishes
Mar 19, 2010 | HP Pavilion dv7-1130us laptop
Calibration wizard.you have to calibrate the touch screen
calibration wizard. you have to calibrate the touch-screen mobile model No: JC 777s
Jun 13, 2009 | Handmark Software MobileLists (950142) for...
Touch LCD points not opeating properly
How often have I heard the phrase - Read the Manual - however I admit to a slight case of panic as I have an important bit of videoing coming up soon....however as the Manual says... The solution to LCD touch screen hotspots not working is re-calibration.
With the Sony DCR-HC22E (also the HC17E/HC19E and HC 21E still Digital Camera this is achieved by
Eject the Tape
Disconnect any Connecting Cables except AC Adaptor or the Handycam Station
Slide the Power Switch Down to turn on the Play/Edit Lamp WHILE pressing the Disp/Batt Info for about 5 seconds
You should then get a screen with a cross in one corner
(The manual recommends touching this with the corner of a memory stick however I GENTLY touched it with a biro. In my case a further 2 crosses appeared and after touching them the LCD Was Re Calibrated.
I re-started my Camera and all the touch spots ( Fast Forward, Menu etc all worked perfectly) Remember you cannot Re-Calibrate with LCD rotated
May 25, 2008 | Cameras
Sanyo camera shuts down and won't power up
I connected my Sanyo VPC - 603 digital camera to an AC/DC adaptor due to battery malfunctions. After about 5 seconds, i heard a spark sound and the camera went off. What might have gone wrong? How can it be repaired?
Apr 10, 2007 | Sanyo Xacti DSC-S4 / VPC-S4 Digital Camera
Sony DCR-HC52E Mini DV Camcorder Logo
49 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
