Lenco Xemio 260 battery will not charge The unit turn off when disconnected from the USB
3 Suggested Answers
SOURCE: Unit won't work when disconnected from usb on computer
danm it ! dead when disconnected form USB
Posted on Oct 09, 2008
SOURCE: SIR.
I have a problem with my lenco xemio 766 . When i no my lenco xemio 766 it's not working . every time he is loading.
Posted on Aug 11, 2011
Garmin Nuvi 260 Car GPS Receiver
When the charger is plugged into the unit, look at the main menu screen. If the charger is working correctly, the green battery icon in the upper right-hand corner eill go out. If the charger is plugged in and there is a light lit on the charger but you see the green battery icon in the upper right-hand corner of the screen on the main menu, then the unit is on battery power and the battery is not getting power from the charger. Common problem with these units are loose rear USB ports. More information can be found here:
http://www.sharc.net/gps_charger_repair.htm
Sep 06, 2013 | Garmin nuvi 260 Car GPS Receiver
I have a John deere 260 riding lawn mower and the battery doesn't charge and when I disconnect thebabattery it dies
Check the charging stator usually under the fly wheel. Check wiring first before condemning the unit.
Aug 22, 2013 | John Deere Garden
Garmin nuvi 260 battery does not hold a charge
If a wall powered charger is used it could be bad or the connection from it to the unit damaged---happens if the charger is connected/disconnected a lot----same thing can happen if using the lighter plug adapter for charging.
Nov 06, 2012 | Garmin nuvi GPS
SIR. I NEED LENCO XEMIO 766 8GB MP4 PLAYER DRIVER. THANK'S BABUL HOSSAIN
Feb 12, 2011 | Audio Players & Recorders
The USB port on the NUVI 260 is loose and will not charge
You will not be able to refasten it yourself. This is a surface mount part and you need a very small tip soldering iron to fix it, plus you ned to know how to modify it so it wont break again. Please see this link:
- Jim
Oct 19, 2009 | Garmin GPS
My nuvi 260 will not display anything . It turns on okay with the Garmin introduction and then screen goes blank
Sounds like a battery problem. You may have to send to Garmin for replacement of the battery as it's not user fixable. I also highly suggest using a Garmin approved charger/ car charger if you don't have that!!
Or understand this:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} There are three ways to charge the internal battery in your automotive GPS unit.1
  1. Use the provided vehicle power cable that came with your GPS unit. The unit will charge while powered on and using the device as well as when the GPS unit is powered off and plugged into a running vehicle. About 3 hrs for a full charge. If the unit will not charge in the vehicle, check the fuse in the power cable for the unit and the power outlet in the vehicle.
  2. Use an AC power adaptor. Some units come with this power cable to plug the GPS unit into a wall outlet allowing the GPS unit to take a charge. For units that do not come with this cable, one can be purchased from Garmin's online store.
  3. For most units, the final way of charging the battery is to plug the GPS into a powered on computer with a USB cable2. This method of charging will be a trickle charge and it may take longer (like a full day) than the other two options, however it will still charge the battery. A USB cable is provided with a few GPS models. For those that don't come with this cable, one can either be ordered from the online store or you can use a standard USB to mini-USB cable that fits the unit and plugs into your computer.
Oct 06, 2009 | Garmin nuvi 200W GPS Receiver
Battery dead unless pluged into computer. Charges
Friend, the power switch is damage thats why the charger acted as switch. replace the power switch
Jul 17, 2009 | Sony NWZ-E436F MP3 Player
Nuvi 260 won't turn on at all.
Had the same problem with my Garmin Nuvi 260w. It just needed to be reset. Lift up the sticker strip on the bottom of the unit and press the reset tab. Worked like a charm for me. HTH!
Jun 13, 2009 | Garmin nuvi 260W GPS Receiver
Garmin nuvi unit was indicatig battery charging when i . conneted to my computer. I removed and tried to turn this on ...it did not and then I have re-connected to my computer again and even tried to...
It take a day to charge the 260 WITH the correct cable for your computer as it will only trickle charge it.
Car charge does it in 2 - 3 hrs. If car is not charging it check the fuse in the end of the charger
And:
  3. For most units, the final way of charging the battery is to plug the GPS into a powered on computer with a USB cable2. This method of charging will be a trickle charge and it may take longer than the other two options, however it will still charge the battery. A USB cable is provided with a few GPS models. For those that don't come with this cable, one can either be ordered from the online store or you can use a standard USB to mini-USB cable that fits the unit and plugs into your computer.
1 - Please note that temperature can play an effect on the charging of a device. If the battery registers a temperature of 0°C and below or 45°C and above (32°F and 113°F
Jan 04, 2009 | Garmin nuvi 260W GPS Receiver
Garmin nuvi 260w not operating while plugged in
Based on your description, you are doing it right. You said....
"when i connect it to the car charger it shows the computer sysmbol and starts charging. there is no other usb port on the device"
That is correct. It takes about 2-3 hours to fully charge a low battery.
There is only a mini USB port on a 260.
It's used for charging and downloading updates of software or maps.
Sep 02, 2008 | Garmin nuvi 200W GPS Receiver
278 people viewed this question
 Grubhead
Grubhead
