AFTER SWITCHING ON,THE PICTURE WOULD GO BLANK WITHIN MAYBE 2 TO 3 MINUTES NOW IT DOSENT COME ON AT ALL. THE SOUND IS OK, AND THE CHANNELS CHANGE WITH THE REMOTE ON THE SET TOP BOX AND THE SOUND CHANGES WITH IT OK. ( HAS MY SCREEN GONE,) OR WHERE IS THE LOCATION OF THE FAULT. IF I REMOVE THE SCART PLUG AND SWITCH ON MANUALY OR BY REMOTE THERE IS A QUICK FLASH ON THE SCREEN AND AFTER A MINUTE OR SO IT SWITCHES BACK OFF AGAIN. THANK YOU FOR LOOKING AT THIS PROBLEM FOR ME, I HOPE THIS INFORMATION IS OK. RON.
  • normaron Dec 30, 2010
    THANK YOU FOR YOUR SPEEDY RETURN, WILL CHECK THIS LATER. RON.
  • 11,800 Answers
No, it's not the screen itself, it's the board that commands it - T-con if it's an LCD or Y-Sus if it's a plasma. The processor on that board is defective due to overheating.
The only thing you (as a regular person, without any experience in electronics) can do is to take over the back of the tv and try to clean, with a fine brush, the dust from in there, and - if possible - reglue in place the radiators that are located on the failed board. If this doesn't fix it (the damage has progressed beyond recovery) the failed board will have to be replaced. This is a job that you should leave to a pro, the parts are sensitive and can be easily damaged.
Depending on the model of your tv the new board and the labor for its replacement will cost you around $250.
Posted on Dec 30, 2010
  • Azrael SRL Dec 30, 2010
    Put the tv face down on a large table with a thick cover on it before attempting to remove the back cover
I have a 50inch LG TV that when switching between programmes the TV goes blank for a moment
Are you using cable and if so which company and box?
ELECTREPAIRUSA@ELECTREPAIRUSA.COM
Dec 07, 2016 | LG Televison & Video
Tv problem
Check its horizontal output section circuit for any loose solder terminals. Resolder all suspected solder terminals by applying little more fresh solder. Replace the horizontal output transistor. If this transistor have some leak, it will overheat within minutes will shut down the picture.
May 26, 2012 | RCA 27F530T 27" TV
Black Screen
Now turn on tv.Have picture flicker few sec.than dies,have sound only left?Yes,than the 1 or 2 long LCD inverter boards are dead.Tries websites liike shopjimmy.com,Ebay.com to buy these refurbishes 1 or 2 long LCD inverter boards for the replacement.
Jul 17, 2010 | Sony Bravia KDL-40S4100 40 in. LCD TV
Samsung T.V. goes on for 30 seconds then no picture
If this is a flat panel LCD tv, this is a sure sign that the panel itself is bad. I have seen this before. Tv comes on works fine then within 5 minutes goes blank.
Aug 07, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
No Picture, No Sound
You can try troubleshooting the power supply section, which actually the only thing you can fix in these tv. check for leaking capacitors, bad semiconductors, such as diodes, transistors, which may be overheating and causing a short. troubleshooting electronic circuits is a pain unless you know a little about it. You may want to learn a bit about electronic first before you actually start taking parts out of a circuit.
Aug 04, 2009 | LG 32LC7DC 32 in. LCD HDTV
Blank screen with other displays still working
1. By View your DVR, Do you mean you can actually see a picture?
2. By "Switch Channels", are these channels being tuned by the TV Tuner?
Your LCD Panel is OK Since you have a Picture (input display in right corner)
If you can see a picture with your DVR, VCR, DVD or any external source then your TVs Video Processing is OK....if not you will probably need to replace the responsible PWB for this function
If you can see a picture with the external sources and only the TV's Tuner is not showing Video, The PWB responsible for Tuning within the TV should be replaced.
Also, if all problems are associated with only the DVR (I assume this is Sat or Cable), then it is most likely that this device is not functioning properly. Possibly lost signal or deauthorized.
Apr 29, 2009 | Sharp Aquos LC-32D40U Television
TV blank, sound okay, picture comes for half a second while switching channels
i am a technician and i too have this issue. if any of you can get a schematic and service notes, send them to trae3@live .com and i WILL find the problem and report to each of you. i cant get any help from sears all i need is to speak with a technician who actually works on these things, get the paperwork and then i am sure it is a matter of a module swap. any info will help us!
Jun 23, 2008 | Protron PLTV-26 26 in. HD-Ready LCD...
Popping sound from speaker when changing channels
This noise is normal with the cable box unless you set the cable box on HDMI sound
Dec 26, 2007 | Bose 3 2 1 GSX System
2 problems- 1-gasket is hanging loose on top of protection screen. 2- TV goes blank and I lose the picture and sound only on some channels at 9:00pm every night
unscrew the screws along the sides and top at back. gently lower screen forward and look inside--you should see the gasket--reattach it or remove it...I just removed it after staring at it for a year or more
Sep 10, 2007 | JVC AV-48P575 48" Rear Projection...
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
