Question about Grohe 28444000 Chrome Movario Movario Five Function Hand Shower Only 28 444
Noise from triton as2000st shower but no water. What is the problem?
Triton cara shower has power and water to it but nothing comes out
CHECK YOUR POWER SUPPLY BOX MAKE CERTAIN THAT IT IS INDEED ON IF SO IT MAY BE A BAD CIRCUIT BRAKER MAY NEED TO REPLACE IT.
Apr 15, 2014 | Camp Chef Triton Hot Water Shower Heater
The water flow from my triton electric shower does not stop even after unit is switched off
28487001 is not an electronic shower head made by Hansgrohe. It is an overhead shower head that has no electronic parts. Triton is a completely different company. If you have an electronic shower system by Triton you will need to contact Triton. If you have a Hansgrohe product feel free to contact Hansgrohe at 1-800-334-0455.
Apr 13, 2013 | Hansgrohe Showerhead Shower Power ...
I have a triton t90 shower it was workin grand until 2day when i was fillin my daughter paddling pool wit the tap in the garden that is connected to the hot water and it must of empty the tank as there was...
As per my view, you should immediately contact to a professional who can fix this shower problem very easily and quickly. You can also explore latest shower enclosures that are available at reasonable price.
May 26, 2012 | Home
Hi i just installed a triton cara shower and the water wont turn off
It is probably the water solenoid valve wich is stuck or bunt out.
If it is brand new, maybe you have warranty.
May 20, 2010 | Home
My triton T100xr shower is flashing low pressure
my triton t100xr shower will work for a while then the low pressure light comes on and the shower shuts down not restarting for quite some time, any suggestions please
Nov 03, 2009 | Kitchen Appliances - Others
Triton shower noise in motor
May have calcium buildup in the system from hard water. See if you can get lime away inside the units passages for a short soak then lube it with a silicone based lubricant or vasline.
Sep 23, 2009 | Home
Triton T80si shower will not switch off
its the water solenoid valve stuck in the open position so when the shower is turned off the shower stays running
Dec 09, 2008 | Home
TRITON Trance electric shower
I have a triton trance shower not working with power and water both connected properly! low pressure light coming on and nothing happening????
Mar 27, 2008 | Dishwashers
Grohe 28444000 Chrome Movario Movario Five Function Hand Shower Only 28 444 Logo
51 people viewed this question
Top Grohe Home Experts
Mike
Donni Steen
Are you a Grohe Home Expert? Answer questions, earn points and help others
