Question about Jamo DMR 60 DVD Player/Receiver
My receiver loading for a while then is saying no disc after i inserted a DVD. This just started happening after i had a movie on pause for a few seconds. Now nothing is playing CD or DVD/
    Problem Solver:
  • 9 Answers
I had a similar problem:
Found two failed electrolytic capacitors on the powersupply of the DMR unit
(One was 1000 microF, the other 2200 microF) Can tell by the tops being slightly bulged out instead of being flat. I replaced them both, now unit works like new.
Posted on Aug 23, 2011
Is there an easy fix when the dvd keeps spinning and screen says loading but does not play?
You have to clean the dirt off the laser lens inside as it cant see the codes on the disc.Use a cleaning disc first or it will have to come apart to clean.
Dec 06, 2013 | RCA 9" Lcd Portable Widescreen Dvd Player...
Tip
ISkysoft DVD Copy for Mac Guide
Want to copy D9 and D5 DVD movies on Mac OS X? iSkysoft DVD Copy for Mac is specially designed for Mac OS X users to lets you copy your DVD movies and remove their protections with just a few click. iSkysoft DVD Copy for Mac allows you to output DVD folder and directly burn your DVD movies to new DVD discs with no protections.
Step1. Please download iSkysoft DVD Copy for Mac; you can know more about it by visiting here.Then install the software and run the software.
Step2. Select DVD Source
In the “Select Source” field, click and select “Select source DVD folder”. Then browse your computer hard disc and select your DVD movie (either in a folder or from your DVD ROM).
Step3. Select DVD Copy Method
iSkysoft DVD Copy for Mac allows you to copy DVD to a folder on your hard disc or directly burn DVD to a new DVD disc.
In the “Select DVD Copy Method” field, click to select a method to output the selected DVD movie:
If you want to output your DVD movie to a folder on your hard disc, you can select the “Output DVD Folder” option, and specify a directory to save the copied DVD movie.
If you want to directly burn your DVD movie to a new DVD disc, you can just select the DVD ROM where you have inserted a blank DVD disc.
Step4. Program Settings
Set Buffer Directory: Specify a directory on your hard disc as the buffer directory to store the temporary files generated during the conversion. We recommend that you select a folder on a hard disc that has relatively big free space.
Select Language: Select an interface language for the program. The currently available languages are English and Simplified Chinese.
Step5. Start Copying DVD
Click the Start button to start copying your DVD movie and/or burning it to a new DVD disc.
Note: If you are copying a DVD disc from your DVD ROM to a new DVD disc, iSkysoft DVD Copy for Mac will ask you to insert a blank DVD disc when the program gets ready to burn. Then you can just take the original DVD disc out and insert a blank DVD disc.
on Mar 31, 2010 | Computers & Internet
Coby TF-DVD7100 (portable dvd player) says "no disc"
when it says wrong disc, optical pickup assy needs to be replaced J.D.W.
Jun 20, 2009 | Coby TF-DVD7100 Portable DVD Player
I put a disc (dvd) in and it will start saying it's reading the disc and then will tell me no disc is inserted. CD's play well and so do picture DVD's. But no movies. The movies are brand new and not...
Picture dvds are read with different software than that required to play movies. Make sure that you actually have dvd player software installed on your system, like WindDVD or Power DVD. See this link for a few.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Apr 30, 2009 | Audio Players & Recorders
Every disc i insert into mschine takes ages to load and then says disc error, even movies I have previously watched on this machine
That happens when the lens are dirty or defective.
You can try using a cleaner DVD to clean the lens, that may not work.
Being the unit only 6 months old this is probably a fault concerning the lens, rather than dirt and dust on the lens.
I think the best thing to do is contacting Pioneer at the number listed on the owner manual, since there is one year factory warranty cover on all Pioneer products.
Apr 19, 2009 | Televison & Video
Unlock LG DVD
The following hack worked for my player. It works for most LG and Aiwa players too. To hack the player try this:
  • Power on player with no disc inserted and wait for "No Disc" message on screen
  • (using the remote) Press PAUSE
  • Press the numbers 314159 in order. (player should now show "COdE - -" the same as below)
  • Press the number of the region you desire ( 0 = any region, 1 = US&Canada etc.)
  • Press PAUSE
  • Power off the player for a few seconds..power back up and insert your DVD disc
Jan 08, 2008 | LG Televison & Video
Dvd video player
Your DVD player is having a problem reading the disc. This is what is accounting for the pausing and the slow loading times...especially if it plays other movies without hitches. Even if the DVD is cleaned, some scratching on the disc will prevent it from being viewed properly. Blockbuster shoudl give you another disc to try of the same movie if you ask. Also, you can try getting a cleaner for your DVD player to remove dust and help it read discs better.
Dec 26, 2007 | Toshiba SD-3980 DVD Player
Bad disc
I have the same problem with some of the Discs I have burned. Most people say the power supply, but I have 2 of these units so I swapped the power supply to see if that was it. The problem stayed in the one machine, ruling out the power supply.
Aug 26, 2007 | Cyberhome CH-DVD 300 DVD Player
Jamo DMR 60 DVD Player/Receiver Logo
156 people viewed this question
Top Jamo Televison & Video Experts
Greg Cann
Greg Cann
Adorjani Laszlo
Demonic-2011
Demonic-2011
Are you a Jamo Televison and Video Expert? Answer questions, earn points and help others
